Question about Garden
Operations manual for 171.25467 Craftsman Mortise and Tenon Fixture
2 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: need manual
I checked Searspartsdirect.com and they only sell the manual for 10.13. If you want to buy it go to the site I listed and type in your model number and down at the bottom of the schematic you will find the manual.
Posted on Mar 30, 2009
What are the different types of cabinet doors?
wikipedia provides a good explanation, quoted below:
Frames
. In the U.S. solid wood frame and panel construction, using either mortise and tenon or cope and stick jointed frames, is traditional, with maple, cherry, oak, birch, and hickory among the most commonly used species. Mortise-and-tenon frames, with their greater strength and permanence, are more costly to produce and less commonly used as compared to cope-and-stick frames. As an alternative, miter joint frames, which may be identifiable by face-surface relief that follows continuously around the frame, have become popular. Miter-jointed frames typically employ embedded metal fasteners to secure frames elements (stiles and rails) cut at a 45 angle. Captured within frames, panels may be either solid or veneered engineered wood (either particle board or medium density fiberboard). Laminates, including those designed to resemble hardwood, can typically be identified by a more rounded appearance associated with the minimum bending radii necessarily entailed by the manufacturing process of applying laminate to an underlying substrate. By comparison, solid surfaces, and solid hardwoods in particular, can be milled with more sharply defined corners, edges, or grooves on either a panel or frame.
  • Panels. Panels used in frame-and-panel kitchen cabinet doors may be fashioned either of solid wood or covered by paint, veneer, or laminate in which case they are fashioned of engineered wood. The panels are typically not fastened with glue or nails but rather "float" within the frame to accommodate seasonal expansion or contraction of the wood frame.
  • Solid-door construction. Doors may be fabricated of solid material, either engineered wood (particle board or medium-density fiberboard, but not typically plywood) or solid wood. Engineered wood panels may either be used as slabs or may be shaped to resemble frame-and-panel construction. In either case, engineered wood panels are generally painted, veneered, or laminated. Solid wood panels are typically formed of multiple boards of the selected wood species, jointed together using glue and may either be painted or finished. Solid wood construction offers the possibility of refinishing in case of damage or wear.
  • Decorative panels. Cabinet doors panels can be used decoratively on cabinet sides, where exposed, for a more finished appearance.
  • Glass door construction options. Doors may have glass windows constructed of muntins and mullions holding glass panels (as in exterior windows). Other designs either mimic the divided-light look of muntins and mullions with overlays, or may dispense with them altogether. Cabinets using glass doors sometimes use glass shelves and interior lighting from the top of a cabinet. A glass shelf allows light to reach throughout a cabinet. For a special display effect, the interior rear of a cabinet may be covered with a mirrors to further distribute light.
Jan 30, 2013 | Hardware & Accessories
I need carfterman ower manual om205680
Sears has it available through their online operations. Just go to the main site and enter the manual number in the search and it will drop you right at the page. It is only 6 dollars and 9 cents.
Sep 28, 2012 | Welding Tools
I have Sears/Craftsman KS 4800-174 but I don't have a manual for it
Go to: www.searspartsdirect.com and enter the complete Sears part number minus the decimal point. The will give you a series of component drawings and should list the repair manual as well as the operations manual. Good luck!
Dec 30, 2010 | Craftsman Garden
I would like to install a used mortise lock in an old door which has the cut out for a smaller mortise lock. I am hoping to use a power tool and not a chizel because the door is a 100 year old hard wood...
Can't think of a bit which will do what you want but you could stitch drill it to the desired size then chisel the holes square this should reduce any chance of cracking
Jun 29, 2009 | Eagle EKB-2020 Key-2020 Key Box w/ Mortise...
Need manual for craftsman mortist and tenon jig model 171.25467
Mar 30, 2009 | Craftsman Tools & Hardware - Others
Baldwin 6321 mortise:when locked can open from either side
It sounds as if the lock is installed backwards or more specifically in inside mechanism. The inside lever/handle when turned should retract the deadbolt (safety feature). If yours does not currently switch around.
Feb 02, 2009 | Hardware & Accessories
Garden Logo
220 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
