Question about Honeywell Heating & Cooling
My carrier programmablethermostat has no power
  • Robert Apr 04, 2011
    Can you check if you are getting 24 volts from the transformer?
  • 3,361 Answers
Check for power to the air handler.
If you have power there,check power on the low voltage side of the transformer in the air handler.
No low voltage out of the transformer is will need replacing.
There may also be a 3 to 5 amp fuse on the air handler control board that is blown.
Any auto motive fuse of the same size will replace it.
Posted on Apr 04, 2011
Do not know how to change ink cartridge x2650
Lift the scanner unit, and then press down on the cartridge carrier latch to raise the cartridge carrier lid. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
Remove the used print cartridge. Insert your new cartridges.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Apr 28, 2011 | Lexmark C533DN InkJet Printer
Lexmark X5495,Error 1203, Says Clear Carrier Jam
Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the test page prints, the error is resolved.
2 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. 3 Remove both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the All-In-One (AIO) on.
Yes: There is a hardware problem with the printer. Continue to Contacting Lexmark.
No: Continue to Step 4.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. 5 Insert the color cartridge. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 4 and 5. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
No: Continue to step 6.
6 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. 7 Insert the black cartridge. Close the top cover, reinsert the power supply and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 6 and 7. If you have already tried cleaning the contacts, skip to Defective Cartridge Test.
Apr 15, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Carrier Stall is the error
Please do the following..
To check the cartridge carrier:
  1. Unplug the printer.
  2. Move the cartridges to the left by hand and then take them out.
  3. Try to print without the cartridges in the carrier. Do you still receive a Carrier Stall error message?
  4. If not, put the cartridges back into the carrier and snap them in at the back. The message should no longer appear.
If the power light on the printer is not blinking, the error message may be caused by a communication error. Do the following:
  1. Remove any other devices attached to the USB/LPT port.
  2. Uninstall the Lexmark printer.
  3. Connect the printer directly to the PC and ensure that power is being supplied to the printer.
  4. Reinstall the printer.
Thank you....
Jan 26, 2009 | Lexmark X83 All-In-One InkJet Printer
THERE IS A MESSAGE THAT SAYS ERROR 0502 EVERYTIME I TRY TO PRINT
This is copied out of Lexmark's KnowledgeBase, just so you know I'm not coming up with this off of the top of my head. Go to www.lexmark.com and click Support > Technical Support, and then search for ID: ENUS22800 if you would like to see the original, complete with pictures. Or, here's a text version:
The 0502 error can have any of four possible causes:
- A faulty black/photo cartridge
- A faulty color photo cartridge
- A dirty encoder strip
- The encoder strip being out of position
The steps below will help you to identify and resolve each of these four issues.
1. Turn the printer off and disconnect the power cable from the back of the unit.
2. Open the printer's front cover.
Pinch the top of the carrier belt and gently move the cartridge carrier to the center of the printer.
3. Remove both of the cartridges.
4. Move the cartridge carrier over to the left-hand side of the printer using the carrier belt.
5. Gently clean the encoder strip with the cloth.
6. Move the cartridge carrier back to the right-hand side of the printer using the carrier belt.
7. Reconnect the power supply and turn the printer back on.
8. Perform the printer hardware test. Instructions on how to do this are here: http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:483:0:0&docid=ENUS3744
Did the printer pass the hardware test?
If yes, proceed to step 9.
If no, proceed to Reseating the encoder strip.
9. Power the printer back off and disconnect the power cable from the back of the unit.
10. Open the printer's front cover.
Move the cartridge carrier over to the middle of the printer using the carrier belt.
11. Reinstall the printer cartridges and move the cartridge carrier back to the right-hand side of the printer.
12. Reconnect the power supply and turn the printer back on.
13. Perform the printer hardware test.
Reseating the encoder strip:
1. Turn off the printer and disconnect the power cable from the back of the unit.
3. On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Gently pushthe encoder strip down and then back up to get it into the slot. Ifthe strip is completely out of the slot, it may be necessary to moveit first forwards and then back.
4. Move the cartridge carrier back to the left-hand side of the printer with the carrier belt.
5. Reconnect the power supply and turn the printer back on.
6. Perform the printer hardware test. Click here for instructions.
If yes, proceed to step 9 of Cleaning the encoder strip.
If no, proceed to the Black/Photo cartridge troubleshooting steps.
Black/Photo cartridge troubleshooting steps:
3. Remove the black/photo cartridge.
4. Move the cartridge carrier back to the left-hand side of the printer using the carrier belt.
6. Perform the printer test. Details on how to do this are here: http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:483:0:0&docid=ENUS3744
If yes, repeat steps 1-7 with a new black/photo cartridge.
If no, continue to Color cartridge troubleshooting steps.
Contact Lexmark if the problem persists with a new cartridge.
Color cartridge troubleshooting steps:
3. Remove the color cartridge.
6. Perform the printer hardware test. Instructions on how to do this are here:
If yes, repeat steps 1-7 with a new color cartridge.
If no, contact Lexmark.
Hope this helps!
Jan 21, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmark all in one x5100 series begins to print then stops with"hardware error message 0502
Hope this helps!
Jan 21, 2009 | Office Equipment & Supplies
Lexmark x83 carrier stall
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:95:0:0&framed=&docid=ENUS22722&relevance=0
Use the above link to trouble shoot the problem.
Error: "Carrier Stall" ID:470
Feb 24, 2008 | Lexmark X83 All-In-One InkJet Printer
Error #0502
pattlnk_4242006_196-lable.jpg Legend:A: Encoder Strip (semi-transparent grey strip)
B: Carrier Belt (black and brown toothed belt)
C: Cartridge Carrier
Troubleshooting Steps
WARNING! Be very careful when cleaning or adjusting the printer's encoder strip.
Required materials
You will need a dry, soft cloth
Embedded links in the table will take you to specific troubleshooting steps.
Step Action 1 Turn the printer off and disconnect the power cable from the back of the unit. 2 Open the printer's front cover.
pattlnk_4242006_1911-beltmove.jpg 3 Remove both of the cartridges. 4 Move the cartridge carrier over to the left-hand side of the printer using the carrier belt. 5 Gently clean the encoder strip with the cloth. 6 Move the cartridge carrier back to the right-hand side of the printer using the carrier belt. 7 Reconnect the power supply and turn the printer back on. 8 Perform the printer hardware test. Click here for instructions.
9 Power the printer back off and disconnect the power cable from the back of the unit. 10 Open the printer's front cover.
11 Reinstall the printer cartridges and move the cartridge carrier back to the right-hand side of the printer. 12 Reconnect the power supply and turn the printer back on. 13 Perform the printer hardware test.
Embedded links in the table lead to specific troubleshooting steps.
Step Action 1 Turn off the printer and disconnect the power cable from the back of the unit. 2 Open the printer's front cover.
pattlnk_4242006_1911-beltmove.jpg 3 On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Gently push the encoder strip down and then back up to get it into the slot. If the strip is completely out of the slot, it may be necessary to move it first forwards and then back.
pattlnk_4272006_149-reseatenc.gif 4 Move the cartridge carrier back to the left-hand side of the printer with the carrier belt. 5 Reconnect the power supply and turn the printer back on. 6 Perform the printer hardware test.
Black/Photo cartridge troubleshooting steps Embedded links in the table will take you to specific troubleshooting steps.
pattlnk_4242006_1911-beltmove.jpg 3 Remove the black/photo cartridge. 4 Move the cartridge carrier back to the left-hand side of the printer using the carrier belt. 5 Reconnect the power supply and turn the printer back on. 6 Perform the printer test.
If you attempt the steps with a new black/photo cartridge and the error persists, proceed to Contacting Lexmark.
Color cartridge troubleshooting steps Embedded links lead to specific troubleshooting steps
pattlnk_4242006_1911-beltmove.jpg 3 Remove the color cartridge. 4 Move the cartridge carrier back to the left-hand side of the printer using the carrier belt. 5 Reconnect the power supply and turn the printer back on. 6 Perform the printer hardware test. Click here for instructions.
If no, proceed to Contacting Lexmark.
If you have attempted the steps with a new color cartridge and the error persists, proceed to Contacting Lexmark.
Feb 21, 2008 | Office Equipment & Supplies
Lexmark does not work.
see if this helps you Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply and power the AIO on. Did the error message return? Yes: Continue to step 2. No: Print a test page. If the test page prints, the error is resolved. 2 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. 3 Remove both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the All-In-One (AIO) on. Did the error message return? Yes: There is a hardware problem with the printer. Continue to Contacting Lexmark. No: Continue to Step 4. 4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. 5 Insert the color cartridge. Close the top cover, reinsert the power supply, and power the AIO on. Did the error message return? Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 4 and 5. If you have already tried cleaning the contacts, continue to Defective Cartridge Test. No: Continue to step 6. 6 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. 7 Insert the black cartridge. Close the top cover, reinsert the power supply and power the AIO on. Did the error message return? Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 6 and 7. If you have already tried cleaning the contacts, skip to Defective Cartridge Test. No: Print a test page. If the test page prints, the error is resolved. Cleaning the Cartridge Contacts NOTE: The embedded links in the table lead to specific troubleshooting documents. Step Action 1 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. 2 Remove the cartridges. Clean the cartridge contacts (click here for instructions) and the AIO carrier contacts
Sep 30, 2007 | Lexmark X4270 All-In-One InkJet Printer
Carrier Jam
i have a problem with my printer it gives a message saying 'clear carrier jam' with a big noise.its not working it is going too fast
Sep 26, 2006 | Lexmark P6250 All-In-One InkJet Photo...
Heating & Cooling Logo
94 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
