Question about Pioneer Audio Players & Recorders
The cassette deck in my Pioneer SX-P720 system died, how can I disconnect it. When you unplug the ribbon cable, it kills power to the whole unit. Thanks !!!
  • danitas
    danitas Jul 26, 2012
    I am in the same situation - nobody can help us...
SOURCE: pioneer avh-p5700dvd... please help mee!!!
Try ebay
Posted on Feb 24, 2007
simplemitch
  • 752 Answers
SOURCE: PIONEER DC-Z92 CASSETTE DECK AMPLIFIER
Is this one of the units that has a ribbon cable ( looks alot like an IDE hard drive cable) that connects all the components together? It also has a squre plastic fan that protrudes slightly from the rear (by about a 16th of an inch)? If so, it's the power module which consists of 2 boards (along the fan housing). You can probably find replacements for about $70, but I wouldn't bother. They quit making new replacements several years ago and any board you get now is just a pull from old stck units.... and they fail about 2 minutes after you put them in. Pioneer knows this but still sells the defective parts.
Posted on Oct 13, 2007
SOURCE: Denon d-c30 cassette problems
Hi Craig,
I started my electronics "career" at the age of six. Will not bore you with details. Firtsly I would suggest that you check your power rails with a scope then follow the crackle in the usual way. Now what about dry joints or dry caps? If there is any semiconductors containing germanium, check them out. If aal else fail put the tape in the fridge for a couple of hours!!! Make use of a hairdrier to "prehaeat the unit. I used to do milspec and we worked at -40 to +55 centigrade. There might even be a noisy reistor in the psu.
King regards
Dries Hyman( South Africa)
Posted on Dec 29, 2007
hogan doan
  • 227 Answers
SOURCE: Does Pioneer still offer FREE replacement screen ribbon cables??
Yes they will replace the ribbon cable for free for only one time. but if you did the bypass mod they will unmod it and charge you $200 for doing it. In that case you better of send it to that guy Rich with Same Day Audio Service on Ebay, he will fix it with his company manufactured milspec ribbon cable for I think $85. His cables are much higher quality than Pioneer's and come with a free lifetime warrantee if you have it perform by him or you can purchase the cable from him and put it in by yourself but he won't guarantee it if you do. It not very hard to do if you are a little bit technical incline. I bought a few cables and replaced them myself with the Ribbon Cable Exhausted Tutor Guide on AVIC411.com, but I have figured out a much easier way to do it. Let me know if you need help. Goodluck to you.
Posted on Mar 04, 2008
  • 329 Answers
SOURCE: Brother SX-4000 Typewriter - problem w/ ribbon
Make sure ribbon you have if for the typewriter you have. take ribbon off machine and type characters, you should see the small ribbon (black) part that turns the ribbon move. If not you have a problem in the printer carrier itself...
Posted on Jun 12, 2008
I took my Pioneer SX-450 Receiver and Pioneer CT-1040W Tape Deck apart to move it. Put it back together. Now can't get a tape to play.
After putting a known good tape in the deck, push play, if the tape doesn't move, try rewind and FF. If nothing happens, the deck has a problem. I assume this is a cassette deck. If so, I always try the thrift stores for a new(used) one. There are good bargains there.
Dec 22, 2016 | Pioneer Audio Players & Recorders
Oct 12, 2007 | Audio Players & Recorders
Basically I have the same problem that has been displayed a lot on this site. My pioneer DEH-P7800MP display won't show when the face closes. When the face opens up all the buttons and lights and display...
The faceplate and head unit is is attached via a flat ribbon cable. (Caution only continue if you have some courage). If you open the faceplate you will see that the ribbon cable is seated in too a flat connector on the PCB (Printed Circuit Board). This connector has a locking mechanism on it that when locked presses the contacts of the cable to the connector. Ensure that the cable is seated properly and that the latch or the lock is in the locked position. Assuming that the tension lessons when the unit is closed so it draws away from the connector and when the unit is open it pulls tension creating a contact. If you see no signs of mishap on this end of the connector try the other end.
Hope this helps.
Nov 17, 2010 | Pioneer DEH-P7800MP
I have had my pioneer deck for about a year and a half now. It's the model DEH-P6850MP, because the interface slides up and down, the ribbon that transfers information from the deck to the unit has got a...
Yes it can be fixed, my shop charges about $90 for that repair. it includes parts and labor. Other shops may differ, but that is a pretty good estimate of what most shops would charge.
Here is the part number if you plan on doing it yourself.
XNP7026
You will need to remove the metal connector jack that is soldered on to the ribbon cable and put it on the new ribbon cable. If you are not good with a soldering iron, you should just take it in. It would be cheaper than buying a new one.
Dave
Jul 12, 2008 | Pioneer Car Audio & Video
CT-W602R Dual Cassette Deck- door won't open
Dear etu7diante,
The another way to release the cassette from the deck is by moving the flywheel manualy after opening the cover of the system. The system should be disconnected from the power supply. If you are able to to do this please let me know .later I can guide you to do the job.
ramesh22
Jun 09, 2008 | Audio Players & Recorders
I have a Pioneer SX 251R and a PD M501
How about a Pioneer CT-W302R stereo double cassette deck ?
I have a unit in very good condition for sale.
lftremblay@hotmail.com
Feb 16, 2008 | Pioneer SX-205 Receiver
Kenwood stereo B-B5 Power Amplifier/Graphic Equalizer
Replace capacitor 110 (47uf 25v), it fixed my problem, should cost about 25 cents and take about 1 hour of your time :-)
Jan 14, 2008 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Pioneer powers off when face plate opens.
My first guess would be that the ribbon cable between the flip face and the mother board has gone bad. This is a very, very common problem. I'd suspect that above everything else at this point.
Jan 03, 2008 | Car Audio & Video
229 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
