Question about Ryobi Gas Hedge Trimmer
Hi, I have Ryobi weed trimmer model RY30550, (carb=C1U 195 H). It starts ok but will only run at full thottle. At intermeadiate thottle positions it rums rough, and at idle it want to stall.
    President:
  • Ryobi Master
  • 1,545 Answers
Try adjusting the L and H screws on the carburetor.
http://www.zamacarb.com/tipspage.html
Posted on Apr 04, 2011
Ryobi 410r cultivator starts and runs, for lack of a better term, at full throttle continuously, no matter the position of the throttle, needle screw settings or idle screw position. The carb has been...
Hi Dennis
Check to make sure the governor spring has not fallen off, broken, etc. from the frame of the engine.
Also make sure that the governor blade is not jammed with leaves, weeds, sticks, etc.
Bud
Oct 17, 2013 | Garden
Diagrams of zama carb c1u
http://www.zamacarb.com/pdfs/TechGuide_2007.pdf
click the link anf find the user guide and instructions
Jan 19, 2012 | Ryobi Garden
Petrol weed eater will not start. Alomost starts
Hi Mark, I own a shop, we will not work on ryobi, have you gotten 2 seasons out of it? If so thats probably as good as it gets. But you can check carb settings. In the USA they come with limiters on the adjustment screws, not too much you can do(break them off) back your adjustments counter clockwise 1half turn.
Dec 20, 2010 | Ryobi Three Trimmer Combo
What is the oil/gas ratio for a Ryobi RY30550 weedeater? 50:1? Thanks
50:1 is too high. That is normally for a chainsaw which is much more severe duty. Normally for a weed whip its 25:1. They usually say on the gas cap but if not 25:1 is a good ratio that never fails (have done commercial landscaping for years) I use this ratio if I don't have a guide from the manufactor of the weed whip..
Aug 30, 2009 | Garden
I have a Ryobi 725R weed trimmer. It starts and will run on 1/2 choke only. After about 5 minutes it shuts down, like it's out of gas but all fuel lines are full. Help??
Your carburetor is dirty. Disassemble and spray with carb. cleaner. Make sure the small screen is free of debris as well. Use a Den tek Brush, (http://www.dentek.com/shop.php?target=products&product_id=7), to clean the small portals in carb.
If you need further assistance, just let me know.
Jim
Jun 07, 2009 | Ryobi Garden
Ryobi SS30 trimmer starts fine and runs at when in full choke position to about half choke position. But when I put the choke lever to the full run position, it stalls out. Ryobi ss30 same problem of...
You need to rebuild the carburetor. You will need to go to an outdoor power & equipment store of some kind to get a carburetor kit for your specific trimmer. It will come with various gaskets, (some of which you won't use), a needle valve, and a small screen that goes in the carb. Replace all old parts with new. New primer bulb is sold seperately. When you have the carb. apart, you will also need to clean the small ports with a Den Tek Brush (used for cleaning teeth). Use carb. cleaner when cleaning.
Jim
May 29, 2009 | Ryobi Garden
Ryobi weed trimmer
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. also check the primer bulb for pin holes and proper seating/seal. i
Jul 06, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi Gas Hedge Trimmer Logo
821 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
