Question about Echo Shoulder Strap Harness Backpack Blower C061000111
Harness has fell apart do you buy 2 harness or one
    President:
  • Echo Master
  • 1,545 Answers
It appears that the one worn across your back is sufficient. Here is yours:
http://www.ereplacementparts.com/harness-assembly-p-519878.html
Posted on Apr 04, 2011
  • Roy Cagle
    Roy Cagle Apr 04, 2011
    I think I am mistaken. I have used these blowers. The backpack pad and engine are on your back and your harness holds it on from the front. The part number you gave was correct and only one is needed.
Where is the knock sensor bank 2 wiring harness located
Hi John, The knock sensors on both banks are fitted as closely to the cylinder head as possible. The knock sensors 'listen' to the ignition and adjust spark timing accordingly. They are fitted onto the hottest place on the engine and consequently the cables often get heated and hardened and easily break. The sensor is usually under the intake manifld (making it fairly hard to find, but it will be there. Regards John
Aug 19, 2014 | 2006 Buick LaCrosse
Got 92 camry knock sensors wiring harness fell apart from heat can i repair
I would leave trying to repair it as a last resort as there will be plenty from the wreckers that you can just place in where the other one was.
Sep 29, 2013 | 1993 Toyota Camry V6
Bicycle seat fell apart
If you don't have a local bike shop to reassemble your seat or sell you a new one, you can probably find one to fit at Walmart or Target. A good bike shop will often give you one of better quality than you can buy at a department store, because many cyclists replace the seat with one that fits their bottom when they buy a new bike.
Sep 15, 2012 | Raleigh Cycling
Can some tell me if they have a picture of the inside on the switch my fell apart need put back together?
If you click HERE you will be taken to a web page of part numbers and the exploded view diagram's of the area of the washer the parts is located in.
Dec 15, 2011 | Roper RAS8445KQ Top Load Washer
My 20mm sight fell apart, how do i fix it
Sight??? If the small finderscope feel apart you can buy another one of better quality here:
http://www.telescope.com/Accessories/Telescope-Finder-Scopes/pc/3/49.uts
If you mean the eyepiece fell apart then the same Company shown above (Orion) also sells eyepieces.
www.telescopeman.org
www.telescopeman.info
www.telescopeman.us
Aug 09, 2011 | Celestron AstroMaster 114EQ (100 x 114mm)...
Pump fell apart - inner piece fell out
On these newer pumps, the plastic piston comes apart, and to fix it a new part is in order. Without looking at it, I think that is what might have happened. Bicycle pumps are almost throw-away items these days. In the old days you could buy all sorts of pump parts, but not anymore. Good luck
Jan 05, 2010 | Cycling
Garmin Charger fell apart
Yes. Call Garmin up and tell them the pieces came off they will send you free pieces (covered under warranty) just tell them that you know how to put it back together and you can see images online of how it should loo kafter it's put back
Jul 14, 2009 | Garmin nuvi 205 GPS Receiver
Fuel tank wire harness
My schematic lies to me a lot but here it is: dark blue:goes to gauge, dark green with red stripe is pump power and black is ground.
Hot wire should have 12v, dark blue should have pulsing voltage and black should be absolute ground.
May 04, 2009 | 1993 Jeep Cherokee Country
My filter queen fell apart!!
http://geeksquad.fixya.com/ThreadView.aspx?prdid=20821&thid=780805
Posted by julieartlit on Jul 14, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Not knowing what actually fell apart is to contact your local vacuum cleaner dealer in your area or to call the Filter Queen factory cust serv or tech serv @ the phone # listed below, you can also request a new owner’s manual so that you might see what actual fell apart and you might be able to fix it yourself. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.filterqueen.com/
Customer Service 1-800-344-1840
custserv@filterqueen.com
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 14, 2008 | Filter Queen Majestic Canister Vacuum
Echo Shoulder Strap Harness  Backpack Blower C061000111 Logo
88 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
