Question about Hoover F5835900 Upright Steam Vacuum
My Hoover F5835900 will not **** up water out of my carpet! No problem putting the water down....just will not **** it back up. I bought the darn thing a month ago and have used it once.
    President:
  • 1,654 Answers
Make sure the canister is inserted correctly and that the float that shuts it off when full is not stuck in the up position.
Posted on Apr 04, 2011
Won't pick up brown water
Hello! Follow these quick trouble-shooting steps to restore suction to your Hoover F5835900.
1. Remove the clean water tank.
2. Recline the handle and let the cleaner lay flat.
3. Remove the dirty water tank lid.
4. Reposition the front panel located on the outside of the tank in the center. It should be flush to the tank, even straight across and pushed down as far as it will go.
5. Assemble the dirty water tank lid back on from the front to the back. The lid should not lift up from the front.
Try it out. The cleaner should now have suction. Good luck!
May 31, 2014 | Hoover F5835900 Upright Steam Vacuum
Instruction Manual is lost
ok, you will need to go to hoover.com and at the bottom of the page you will see download manuels. click on this and it will bring you to another page asking for the model #. in the space put your model # in F5835900 (no dashes) then push enter. it will bring you to yet another page were you can print the manuel
Jul 29, 2009 | Hoover F5835900 Upright Steam Vacuum
Hoover f5835-900 will not pick up water. seems to be blowing air
Hello
Click HERE toget the manual. Go to figure 3.1 and clean the filter if necessary. Goto figure 3.8 and make sure pate E is clear. Make sure the part isslides up against when inserted downward is clear. Go to figure 3.11.The slotted holes in the recovery tank lid must be clear. Finally therecovery tank lid must fit snugly and air tight. I hope this works
Jun 28, 2009 | Hoover F5835900 Upright Steam Vacuum
Instructions or manuel was not included.
i downloaded the manual for your machine, but not sure how to access it for you,but i do know about the problem, the tank that sits down on the front of the steamer and it has 2 clips that you push in to lock the tank is where your dirty water is put in when you are cleaning your carpets. the tank above ,the one where you put your solution and water in is what is used to shampoo your carpet. on the handle is a trigger (black) button ,this is the button you push in to release your solution onto your carpet. release the button to extract the water from your carpet,moving your steamer in a back and forth motion. the trigger button is the only button on the machine and is only used to put the water /cleaner located in the upper tank on your carpet, releasing this button and moving your steamer back and forth over the shampooed part with extract your dirty water into the tank that sits below the solution tank. go on www.hoover.com and click on carpet cleaners ,scroll down to find yours and click on manual. and the owner manual will download and you can print it out for future reference, i hope this will solve your problem, sandy
Nov 29, 2008 | Hoover F5810 SteamVac Upright Vacuum
I need a manual
You can view your manual by going to the following site:
www.hoover.com/pdfs/manuals/F5835900.pdf . Using the Adobe 6.0 format you can save a copy directly to your computer.
Sep 02, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Dispenses Water Only
try replacing the air filter and the water heater.
Jul 28, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac does not spary soution out well on carpet, carpet not getting wet
With the tank off, check to see if the rod in the handle is hitting the reservior asm,(this what the tank sits on). If it is, then the reservior asm. could be bad. If it isn't, then there is a problem inside the handle. Also make sure the filter at the bottom, has a red frame is clean. There also if there is a foam filter on the inside of the recovery tank lid, make sure it has a 1/4 in or so gap from the top.
Jun 21, 2008 | Hoover F5835900 Upright Steam Vacuum
Manual for F5835900
Check the filter inside the dirty water tank. Make sure it has a 1/4 in. gap from the top to the top of the filter.
Nov 14, 2007 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover F5835900 Upright Steam Vacuum Logo
173 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
