Question about Sylvania G-Netbook
My computer will not come on, the green lights are on except the one under the battery.
    Genius:
  • 1,267 Answers
Try taking the battery out and leave the machine hooked up to the AC power and try it again. Li-ion batteries have a built in safety feature to prevent fires if the voltage is too low to safely recharge. If this works then you will have to get a new battery to make the machine portable again.
Posted on Apr 06, 2011
Es lexus 300 p 1705...What is this?
DTC P1705 - NC2 (Direct Clutch Speed Sensor) Revolution Sensor Circuit malfunction or Direct Clutch Speed Sensor Output is 300 RPM or less with Vehicle at 20 MPH or more & with Park/Neutral Position Switch Off
Most probably you have an electrical fault causing the problem and attached is a diagnostic procedure. It could be 2 separate problems and after rectifying the P1705 only would you know it is single or 2. Repair manual shows right on top of transmission, black sensor with single bolt, 2 wire plug. P/N 89413-08020 list price $113.80
NOTE: DTC P1705 is set when PCM receives 2 gear position signals at the same time.
1. Turn ignition on. If any A/T gear position indicator lights remain illuminated when gear selector is moved from that gear, go to next step. If all A/T gear position indicator lights turn off when gear selector is moved from that gear, system is okay at this time.
2. Disconnect A/T gear position switch connector. If all A/T gear position switch indicators go out, replace A/T gear position switch. If all A/T gear position switch indicators do not go out, go to next step.
3. Reconnect A/T gear position switch connector. Shift through all gear positions except Reverse. Using a DVOM, measure voltage between 16-pin PCM harness connector "D", terminal No. 6 (Green/Red wire on 2.3CL or White wire on Accord and Odyssey) and 25-pin PCM harness connector "B" terminals No. 20 or 22 (Brown/Black wires).
If battery voltage is present, go to next step. If battery voltage is not present, check for a short in Green/Red or White wire between 16-pin PCM harness connector "D" and A/T gear position indicator, or A/T gear position switch. Repair as necessary. If Green/Red or White wire is okay, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary.
4. Shift through all gear positions except Neutral and Park. Measure voltage between 16-pin PCM harness connector "D", terminal No. 13 (Blue/White wire on Accord or Light Green wire on 2.3CL and Odyssey) and 25-pin PCM harness connector "B" terminals No. 20 or 22 (Brown/Black wires). If battery voltage is present, go to next step. If battery voltage is not present, check for a short in Blue/White or Light Green wire between 16-pin PCM harness connector "D" and A/T gear position indicator, or A/T gear position switch. Repair as necessary. If Blue/White or Light Green wire is okay, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary.
5. Shift through all gear positions except "D4". Measure voltage between 16-pin PCM harness connector "D", terminal No. 9 (Light Green/Black wire on 2.3CL or Yellow wire on Accord and Odyssey) and 25-pin PCM harness connector "B" terminals No. 20 or 22 (Brown/Black wires). If battery voltage is present, go to next step. If battery voltage is not present, check for a short in Light Green/Black or Yellow wire between 16-pin PCM harness connector "D" and A/T gear position switch. Repair as necessary. If Light Green/Black or Yellow wire is okay, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary.
6. Shift through all gear positions except "D3". Measure voltage between 16-pin PCM harness connector "D", terminal No. 8 (Green/Blue wire on 2.3CL or Pink wire on Accord and Odyssey) and 25-pin PCM harness connector "B" terminals No. 20 or 22 (Brown/Black wires). If battery voltage is present, go to next step. If battery voltage is not present, check for a short in Green/Blue or Pink wire between 16-pin PCM harness connector "D" and A/T gear position indicator, or A/T gear position switch. Repair as necessary. If Green/Blue or Pink wire is okay, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary.
7. Shift through all gear positions except "2". Measure voltage between 16-pin PCM harness connector "D", terminal No. 14 (Green/Yellow wire on 2.3CL or Blue wire on Accord and Odyssey) and 25-pin PCM harness connector "B" terminals No. 20 or 22 (Brown/Black wires). If battery voltage is present, go to next step. If battery voltage is not present, check for a short in Green/Yellow or Blue wire between 16-pin PCM harness connector "D" and A/T gear position indicator, or A/T gear position switch. Repair as necessary. If Green/Yellow or Blue wire is okay, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary.
8. Shift through all gear positions except "1". Measure voltage between 16-pin PCM harness connector "D", terminal No. 15 (Light Green/White wire on 2.3CL or Brown wire on Accord and Odyssey) and 25-pin PCM harness connector "B" terminals No. 20 or 22 (Brown/Black wires). If battery voltage is present, check for loose PCM harness connectors. Replace PCM with a known- good unit if necessary. If battery voltage is not present, check for a short in Light Green/White or Brown wire between 16-pin PCM harness connector "D" and A/T gear position indicator, or A/T gear position switch. Repair as necessary. If Light Green/White or Brown wire is okay, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary.
Hope helps.
May 24, 2011 | Lexus ES 300 Cars & Trucks
Dell latitude cpx. Charging Light flashes yellow then green when plugged in. When I push the power button that light and the one next to it turn green and the 2nd & 3rd light under thoseturn green...
From what you have said it sounds like your battery might be the problem. Have you connected the computer to the wall and tried to turn it on. Is the same happening then?
Mar 28, 2011 | Dell Computers & Internet
On the wireless mouse that came with my computer(without ant info, thank u Dell)I have three lights on on the top of the receiver going on right now, two green and one red and I have no idea what there for...
their are numerous complaints about the batteries going so fast, on average were talking 2 days of complete use that's 24 hours of straight movements with the mouse before a dead battery not very impressive if this is true. test this way put fresh batteries in their. good quality batteries will work best due to their ability to release the charge under longer periods of time at the same voltage and amperage. press the button on the underside of the mouse that says connect, and press the top button the the receiver that's plugged into the computer tower. they will pair up and you will be able to use it as normal. the keyboard got a great rating. (side note: would love to know how long the batteries lasted you.)
Dec 13, 2009 | Dell Wireless Keyboard Optical Mouse w0147
D600 laptop boot problem
The D600 is plagued with power up problems for 2 reasons. First the connector on the motherboard to the power button is very sloppy and after awile it breaks contact. If you put pressure under the docking port area and press the power button it may start. The second is the memory slots. I know you said you replaced the memory, but it is the slot that is a problem. Remove the memory and put 1 chip in "A", then press down on the chip while trying to boot the laptop. If this works then get a peice of foam or pad and place it on the chip. When you put the cover back on it will push down on the chip and should boot. Repeat this process for "B".
The green light does signify a charged battery! This is also a possible reason for not booting. Remove the battery and try to boot with only the power supply. A shorted battery will stop the laptop from starting up.
If all of this does not help then remove the battery and the CD Rom, then try to boot. Finaly if nothing helps you should buy a new Laptop or a used one on E Bay. You could get a used D600 on E Bay that has a good motherboard for cheap money and use your drives and LCD. I work on D600 and D800 all the time. Let me know how you make out!
Dec 09, 2009 | Dell Computers & Internet
Continuous alternating one green and three flashing red battery
note.gif NOTE: Battery operating time (the time the battery can hold a charge) decreases over time. Depending on how often the battery is used and the conditions under which it is used, you may need to purchase a new battery during the life of your computer. Check the battery status light — If the battery status light flashes orange or is a steady orange the battery charge is low or depleted. Connect the computer to an electrical outlet.
If the battery status light flashes green and orange, the battery is too hot to charge. Shut down the computer, disconnect the computer from the electrical outlet, and then let the battery and computer cool to room temperature.
If the battery status light rapidly flashes orange, the battery may be defective. Contact Dell _I found this on : http://support.dell.com/support/edocs/systems/latd820/en/ug/index.htm Hope this helps and good luck. if i "fixed ya" please rate me. thanks-jmattes
Oct 22, 2009 | Dell Latitude D820 Notebook
I have a light flashing from green to orange on my laptop
no worries its just reading.. datas..
hot is just normal..
Sep 25, 2009 | Dell Latitude D610 Laptop Computer -...
Hi, The battery light on my Inspiron 6000 flashes 3 times red and then green repeatedly. What does this mean? Also, after the computer is plugged into an outlet for an extended period of time the power...
the battery has reached its expected life, you need to replace it. If it is under warranty, you can call dell and have them replace it. You can still use you laptop with the wall power/charger plugged in, remove the battery to get rid of the flashing red/green light.
Jul 10, 2009 | Dell Inspiron 6000 Notebook
Washing machine wil not fill - tries several times then stops and all lights except 4 go out
That would be the balance switch, should be located rear right under the main board. over time the switch becomes jamed in the on position and the machine always thinks its off balance. $4 to $10 for a new one.
Apr 14, 2009 | Washing Machines
Microsoft wireless notebook optical mouse 1023 - not working!
If you know that the battery is good then try this next. There is a VERY tiny shark-fin shaped spring-loaded button on the bottom of the mouse that is pressed in, when you insert the receiver, while the mouse is not in use, that turns off the mouse to save the batteries. If you haven't used the mouse in a while, it can get stuck in the in position, so that when you pull out the receiver, it doesn't spring out and turn the mouse on (indicated by the red light on the bottom). If you notice that the light isn't coming on. Just try manually pushing in the little shark-fin thing a couple times to make it spring back out. After a couple times, you should be able to get it unstuck and the red light should come on.
Feb 24, 2009 | Microsoft Wireless Notebook Optical Mouse...
Sylvania G-Netbook Logo
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
