Question about LG 37LE5300 LED TV
37lg5300. No sound from the speakers. When I go to the audio menu, it says, "Audio menu cannot be set during wired headset mode". I don't have anything in the H/P jack. When I do put in the headphones, I can hear the TV.
SOURCE: CANT CONNECT MY BOSE COMPANION 3 SPEAKER TO MY 42LG50 LCD TV
I have just brought the bose companion 3 speakers and i connected it to the headphone socket in my tv and it worked.
Hope this helps
Posted on Apr 15, 2009
  • 7 Answers
SOURCE: LG 42PX4DV - HDMI Audio / PC Audio IN problem
one quick fix you can try. plug in the HDMI cable, slect a digital audio sound output from the sound settings on your machine, then leave it connected and restart it. It just might work.
Posted on Aug 05, 2009
  • 44 Answers
SOURCE: want a TV wireless headphone with no headphone jack or audio out
You may have to connect the headset through a VCR or DVD player that does have the output connections.
Posted on Sep 05, 2009
SOURCE: This TV is lacking in the audio department.
What you can do is to look at the back of the TV and search for an audio out. The presumption here is that this TV is a newer Flat Panel and has too many connections on the back of the screen. It will be confusing, but it may be by itself and it will say "Audio Out" or "Digital Out" (Digital Out is best). If this is not true you can connect the Headphone out to the Pre-Amp through a 1/8th to RCA cable connection from Radio Shack. When you find it you can connect this output to your Pre-amp or AV Receiver with standard RCA cables or "Optical Cables" (Optical Cables are best) and really enjoy the movies with as much Butter on your Popcorn as you can stand but watch out when it gets scary because the Popcorn will fly.
Posted on Sep 18, 2009
Testimonial: "Thanks for your quick reply. I checked for audio "outputs", nope. I'm gonna use the earphone output into a preamp. That'll turn off the TV speakers. "
Warf135
  • 137 Answers
SOURCE: When I use the headphone output jack (to drive a powered subwoofer), the default internal speaker audio output is disabled, leaving me with only the subwoofer output. How can I use both the internal
Your best option is to use a seperate amp with sub output from the audio outputs on the back of your TV. use this amp to power the sub and a good pair of speakers, and you'll have quality sound.
It is possible to prevent the TV's internal speakers from cutting when you use the headphone socket, but it means going inside your TV, and if your not skilled, you can easily blow your TV (and yourself) up. You just need to re-wire the headphone socket on the TV to stop it cutting the internal spaekers.
Posted on Oct 06, 2009
No sound from TV but if we connect headset sound comes from headset what is the solution
Check the settings in the "Audio" section on the menu on the TV. Check to make sure the TV speakers are in the "on" position in the menu and that the "Analog audio out" on the menu (if there is one in the menu), is set to "variable" if you are controlling the volume with the TV and not a sound bar.
Jan 23, 2016 | Televison & Video
Skype not working
Sir,
Click this link for more information........
http://support.skype.com/index.php?_a=knowledgebase&_j=questiondetails&_i=35
Also Check........
On a PC with external speakers and also a headset with microphone. Windows XP is configured so that standard audio are external speakers and standard microphone is the headset. Skype is configured to use the headset for audio in and out.
This way one can listen to sound from the PC and from MP3 players through external speakers and if there is a call to make or take, this is going through the headset.
But now there is the problem that the noise level for the headset is too low. Increasing volume has no effect on the headset, it only affects the external speaker's volume.
Now the solution: Going to the control panel and opening the sound setting, go to the audio tab. The external speakers are selected as default. Just temporarily select the headset and then click on volume just below. You can now set the volume for the headset, click OK and click cancel (!!!) on the sound control dialog box. This way the external speakers remain as default output.
Skype-->Tools -> Options -->Sound Devices-->audio device/USB/etc Audio Device (do NOT use windows default device)
You can also tick the ring pc speaker check box as this is a good backup to alert you even
if the main speakers are off or turned down.
Windows:
Start-->Control panel-->Sound and Audio devices
On the audio tab set the default playback device to your main soundcard(AC97/Audio-chip/add-on-adapter), etc.
Your installed audio device must be present there.
If not, reinstall audio device
thanks
good luck
Oct 29, 2008 | Altec Lansing Stereo Headset with...
Tip
How to Play With Bluetooth WMP files
<p>Bluetooth is very common in cell phone headsets and wireless keyboards and mice. It is a low power, moderate, high speed wireless communication protocol that is fast enough to transport high quality audio signal. If you have a computer with Bluetooth, you can order your audio to a Bluetooth headset or a set of speakers, allowing you to listen to music and movies played in Windows Media Player anywhere within 30 meters of the your computer. <br /> <p><br /> <p>1. Place the Bluetooth device in pairing mode. Speakers and Bluetooth headsets generally have a "Connect" button somewhere discreet; see the product manual for specific instructions on how to put it in the "discovery" mode. <br /> <p><br /> <p>2. Click on "Devices and Printers" computer "Start" menu and click the "Add Device" button in the window that opens. <br /> <p><br /> <p>3. Select the Bluetooth device in the list and enter your password security. Most devices use "0000" as a default password. <br /> <p><br /> <p>4. Right-click the volume control on the lower right corner of the Windows taskbar and select "Playback Devices". <br /> <p><br /> <p>5. Click on the Bluetooth device on the "View" tab and click on "Default". The Bluetooth device is now the primary playback device for computer audio. <br /> <p><br /> <p>6. Open WMP and play the file you want. The audio must be played through a Bluetooth device. <br />
on Jun 26, 2011 | Computers & Internet
Turn Sound ON, now it's "Q SOUND OFF""
follow this steps and fix it. God bless you
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
Jul 09, 2013 | Televison & Video
No sound
Did you check the main menu for sound settings to see it the speakers are turned off?
Feb 01, 2012 | Computers & Internet
My pantech reveal's speaker has suddenly stopped working. I cant hear anything when i receive or make calls. A headset icon popped up to the left of the battery icon during the same time the speaker...
it means you have the phone in headset mode so it is sending audio to headset not speaker ...should be able to turn it off in the phone settings
May 25, 2010 | Cell Phones
No stereo sound output from audio out jacks. Speaker sound is OK
Make sure that the set is not in mono mode. It should be in the audio menu or you may have an audio button on the remote control.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 23, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony KV-27FV16 no sound
Try going into the audio settings part in your menu and select reset audio settings.
May 16, 2008 | Sony KV-27FV16 TV
Using Motorola Blue Tooth with PS3
Yes you can. Just go to accessories or audio device settings. Have your headset on and hit connect bluetooth device. The key it asks for should be 0000. If that doesn't work do a quick search online and you should be able to find one that works.
Dec 07, 2007 | Sony Playstation 3 (PS3) Console
LG 37LE5300 LED TV Logo
274 people viewed this question
Computer Repairing
Computer Repairing
