Dog ear in the outfeed - Office Equipment & Supplies
  • 1,915 Answers
You do not state model so I will give you a general tip. Dog ear pages are mostly caused by something in the paper path dragging on the paper. This can be a piece of label stuck in printer, torn bit of paper or toner built up on the fuser. Check the area where the paper comes out of the paper tray closely because this is where problems often start.
Posted on Apr 05, 2011
Dog ate the ear cushion on my AblePlanet NC180BMM Black Noise Canceling Headphones. Can I replace?
what --the dog or the head phones
the ear cushions may be difficult to get and it may be best to get new head phones
dogs you can get from the pound
Dec 12, 2016 | Audio Players & Recorders
My dog has swollen ears like little cushions. The puppy has been biting them is the reason . What can I do.
Take it to the vet, and they'll fit it with a cone so the puppy can't bite the other dogs' ears. Train the puppy not to bite!
Oct 02, 2013 | Pets - Others
Can pig ears be dangerous for dogs?
Yes, they can. The problem with pig ears is that once the dog chews on them, they can break into small pieces, which then can be dangerous for the dog if it eats them.
Aug 23, 2012 | Baby Einstein Dogs
What can I do to help prevent my dog from getting an ear infection? I clean his ears regularly; however he still seems to be getting infections.
I found a great natural remedy that works in preventing ear infections in dogs. I use it for my dogs and they have been ok for almost a year now.
THE FOLLOWING ALL NATURAL REMEDY
PREVENTS EAR INFECTIONS! This recipe is not meant to be used with Zymox. This should only be used once the ears are completely healed.
Keep in mind that it "will not" cure an existing ear infection.
Once you get your dog's ears to a healthy state either by using Zymox like we recommended or with the help of an antibiotic from your veterinarian, start using the following remedy weekly to prevent future infections. This works by raising the Ph level in the dogs ears.
Purchase an eye dropper bottle and the following ingredients
from your local pharmacy.
2 Tablespoons of Boric Acid
4 ounces of Rubbing Alcohol
1 Tablespoon of Glycerine
Shake the bottle before each use to thoroughly mix. Place a small eyedropper full into each ear. Cup the dog's ear and massage gently. Allow the dog to shake his head and gently blot dry any excess on the outside of the ear.
Do this weekly.
If ANY IRRITATION occurs - STOP using the recipe immediately!
Aug 15, 2012 | Pets - Others
Are pig ears a healthy treat?
Although they are quite delicious for dogs, pig ears contain a lot of fat. So if your dog suffers from obesity, do not give it pig ears.
Aug 13, 2012 | Dogs
Should I give my dog pigs ears?
I have read a lot of forums about this and it seems as though they are not that popular among dog owners. A lot of them say that the pigs' ears make their dogs sick with loose stools and others say that their vets have told them that pigs' ears are crawling with bacteria. So I wouldn't advise you to give them. Check out this forum: http://www.dogforums.com/dog-food-forum/951-pigs-ears-bad.html
May 13, 2012 | Dogs
HOw do I adjust the tables so I do not get a snipe?
Adjusting a jointer to relieve snipe can be trickey but here are a few procedures that will help.
-The two tables on the jointer are adjustable, the front (infeed) is what you adjust for cut depth.
- The back (outfeed) needs to be the exact hieght as your knives
The outfeed needs to be adjusted first
-unplug jointer
-using a straight edge on the outfeed table adjust it so that when you turn the head (counter clockwise) the knives just touch the staight edge (NOTE** all the knives should touch the straight edge the same, if not your knives are not set correctly) This is your most important adjustment, if the outfeed is to high or to low it will cause inconsistant jointing.
-Now that the outfeed is trued up to the head you can adjust the infeed table, using the straight edge align it so that it is perfectly lined up with the outfeed table (not touching the kinives) Your jointer is now at ZERO
You can now adjust the infeed for depth of cut, Start by lowering the infeed a very small amount (1/16 of a inch to start)
The biggest problem I have seen is that people try to cut to much at one time, it will work alot better if you take several small cuts instead of one deep cut.
Also- getting the knives set perfectly in the head is a key to success, if this is not happening you WILL have jointing problems. ALSO if the knives are not sharp they will pull the material down causing snipe.
I really hope this helps and if you need a visual aid try looking it up on you tube.
I have used my jointer for numerous different projects, Here is a cool one for tapered table legs.
Take a piece of square stock (like 2x2 ) about 3 feet long, make a mark about 2 foot up and wrap a piece of tape around it at the mark.
now make a mark (we will call it a stop mark) on the fence of the jointer by the head.
with a pencil and number the edges on the 2x2 (above the tape so you dont joint them off)
turn on jointer and run side 1 until your tape is at the fence mark, carefully lift 2x2 and do the same to the 2 side.
only joint the #1 & #2 sides, run several more times and you will have a perfect tapered leg.
SHOP DOG
May 02, 2011 | Masonry Tools
Need to get the agitator off
that's funny [feed dogs]they are called, dog ears but you do now have to feed the dogs because their not working.lol.hey you will have to get those parts on-line or at an appliance store.lowes wont carry those that i know.anyway if you pop the cap of the agitator you will see a piece that has a small handle.pull up and remove that piece.then you will see the bolt to remove to pull the agaitator[its a 7/16]take a good look at how its together before you take apart.......ok now that the agitator is out place on floor,put feet on the bottom piece and pull up on the top piece til comes off.then dump out the piece in the top w/dog ears in it........install new ears in that piece and reinstall upside down,inthe top piece of the agitator.then apply pressure on the dog ear retainer and place over the bottom piece of the agitate aligning the two little tabs sticking up on the bottom piece of the agitator with the little cut outs in the dog ear retainer....now take your socket to place bolt back on,put some plastic wrapper or package from dogs in the socket and push the bolt into it.then place the bolt in the hole of the dog ear retainer .now lift agitator up and place onto transmission shaft and tighten bolt and place cover back on................boy that was a lot of words.that should do it for you God bless you Tiffany ,from tom
Jan 24, 2009 | GE WBSR3140DW Top Load Washer
100 people viewed this question
jasbo
jasbo
