Question about Trijicon Ta01 Acog 4x32 Rifle Scope Red Illum Reticle
I recently purchased aTrijicon ACOG model TAO1NSN-DOCW on Ebay (shame on me) . The reticle is noticibly tilted to the left.
  • 3,083 Answers
Not mentioned how long ago you purchased it, but you need to file a complaint with them, if you're within the time frame for filing. The item could have been shipped defective, or broken in shipping. Check the Ebay policies to see if you can still get your money back. If you're stuck with it, your best bet is to take it into a Gun shop and see what they say, and if it can be fixed without an enormous cost. If they can't help, contact Trijicon support to see if they can fix it, and how much, etc.:
http://www.trijicon.com/na_en/support/ask_trijicon.php
Good luck, and hope this helps.
Posted on Apr 05, 2011
How do i access my ebay purchases that i made today
Hi
Log in to eBay, and go to "MyEbay" (top left of page) This should display your landing page and a list of things on the left hand side should include a link to your "Purchase History". I f you click here it will show your recent and less recent purchases and you can select the tie range over which to view your purchases
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 16, 2014 | eBay Computers & Internet
Rattling in left earcup
Sounds like you have blown out the cone on the speaker. Have you removed the covering to see if the speaker in that earphone is intact?
Feb 10, 2014 | Bose QuietComfort 15 Headphones
My PT-44LCX65 has been showing numerous color spots recently. In August, I noticed a dark green spot in the top left corner, and also a less visible maroon spot near the center. Today (12/16/2010) I'm...
THAT IS GOING TO MOST LIKELY BE A PROBLEM WITH THE OPTICAL ENGINE AND PANASONIC HAD SEVERAL MODELS THAT HAD PROBLEMS WITH EEPROM CORRUPTION THERE WAS A RECALL TYPE OF EXTENDED WARRANTY I SUGGEST CALLING PANASONIC THEY WILL SEND SOMEONE OUT TO FIX IT MOST LIKELY FREE OF CHARGE :)
Dec 17, 2010 | Panasonic PT-52LCX65 44" HDTV
The reticle on my ACOG 3.5x scope won't go down far enough sight in @ 100yds. It is 12" high at 100yds and the reticle is maxed out. What should I do?
this is not uncomon jack up the frount of the scope with a fuw strips of 35mm film if you can this will lower the point of aim a lot at 100yds,,,you may need to let off the screws and fit a thin washer/s under the scope to lift the frount up
Nov 20, 2010 | Trijicon ACOG Rifle Scope 4X 32 Matte...
Ive got an 4x32 acog and the elevation is knob isnt changing the placement of the reticle, is there any way to fix without senging back to trijicon
Jonny,
If you've mounted the firearm in a shooting vise and can still verify it isn't moving there's not much to do but send it back to trijicon. If it's less than 30 days old you could take it back where you purchased it and they would most likely exchange it as defective.
hope this helps, Mark the Gunsmith
*Please give feedback on this answer*
Dec 28, 2009 | Trijicon Optics
My rifle scope is maxed to the left is there way to recenter adj screw
it sounds like your saying the turret is wound over fully to the left?
if so the scope mount is at fult...the only way to pull the cross over to the right is to pack out the scope mount with old film on the right side of the scope this will make the scope shoot futher to the right
Nov 11, 2009 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
Cross hairs canting to the left..how do i recenter the recticle?
From your short description, it sounds like the Horozontal (the ELEVATION) reticle is canted to the left. If that IS the case then do this;
Sand bag the rifle on what you know is a level and firm surface. The rifle MUST be level itself. You can use a small level to determine this.
Without moving the rifle, look through the scope and determine if indeed the horozontal or ELEVATION reticle is indeed canted. The reticle should be LEVEL in relation to the ground and the rifle itself.
If it still appears to be canted, loosen the set screws of the scope ring caps (Not the scope mounts) and while looking through the scope, gently rotate the barrel of the scope clock wise until the Horozontal reticle appears to be now level. Re-tighten the scope ring caps and look through the scope again to make sure the Reticle is still 'level'.
You must now make sure that your scope is still 'zero'd'.
IF the issue is something other than what I have assumed from your description, please send me a msg. with more detail and I will be able to resolve whatever issue you are having. Include the 'Brand and model', plus the power of it, and the brand/model/cal. of the rifle the scope is mounted on.
Good luck. :)
Apr 27, 2009 | Nikon Tactical Rifle Scope 4-16X 50...
Replacement part
did u call maverick direct for part
Jan 30, 2008 | Maverick MM6386 Deluxe Food Processor
HP 610 Color Copier
Can you copy from the glass top? The feeder asm should be easy to purchase from ebay or HP.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 08, 2007 | HP 610 Color Copier
Trijicon Ta01 Acog 4x32 Rifle Scope Red Illum Reticle Logo
233 people viewed this question
Top Trijicon Optics Experts
james laughton
james laughton
ray gallant
Are you a Trijicon Optic Expert? Answer questions, earn points and help others
