Question about Kenmore 9781 Electric Laundry Center with Dryer
Won't stay on when button is pushed, HOLD button down it will run but not heat !!!! PLEASE HELP !!!
  • Kenmore Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Apr 05, 2011
Kenmore Elite 11072972101 gas dryer will not stay on after I push the start button. What is wrong and how do I fix it.
If you HOLD the start button down and the drier heats and runs, then your problem is most likely a relay which is supposed to energize (close contacts), which "latches" the condition when you push the start button. The most likely cause of such a failure, is a fuse or a thermal cut out, which has prevented normal operation. For safety reasons, being a gas appliance, I would NOT ATTEMPT to fix this problem yourself, unless you have licenses to service such equipment!
Apr 17, 2017 | Kenmore Dryers
I Belive the control have a timer heat comes on at certain time. How do i sit this for autmatic
with a programable thermostat push the "hold" button.display should now say "hold" run the temp up or down it will stay at that temp till you push "run program" again
Feb 02, 2011 | Goodman Heating & Cooling
My kenmore elite dryer wont stay running after you push the push to start button. it starts runs only if you hold the button down. which i did for a shot period of time and also notice no heat starting...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Jan 16, 2011 | Kenmore 63942 Dryer
Dryer won't stay running after pushing the button.
that isn't the model number,it will start with 110. or 417.send the full model number and i can look up your dryer,most likely it's the even heat board or the motor relay but without the model number i can't look it up for you,these parts are in the top console,call the parts store give them the model number and they'll give you the right part or send it to me,let me know what you find
Jul 20, 2010 | Kenmore 63942 Dryer
Start button and no heat
Those two problems are usually unrelated and I believe you just have a coincidence that they both happened at the same time. You should replace the start button since it is faulty. The heating problem could merely be that the machine does not have enough time running to heat up since you have to hold the button to keep it running, however if that is not the case then you should replace the heating element and the thermostat. Possibly the thermal fuse as well just in case.
Dec 24, 2009 | Dryers
I hooked up a Jacuzzi bathtub and pump won't stay on
I bought a new house and I have a jacuzzi bathtube . and all the sudden stopped working .. where or how I can locate the pumpe ? the only thing I see is the button to turn it on or off and now it does'nt go on ?!! I checked the circute praker and everything seems okay to me.... help please.
Mar 08, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Dec 30, 2008 | Kenmore Dryers
Kenmore 9781 Electric Laundry Center with Dryer Logo
66 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
