Question about Brother IntelliFax-2820 Laser Fax
Hi,, We are using the fax everyday for business. today it keep sending blank pages. we restarted it,chage toner. still the same..
  • 4 Answers
Hi please check orientation of your document feeder, to see if you have loaded the original document into the document scanner up sided down. Thats the simplest solution.
Posted on Apr 05, 2011
The pages are not printed
sometimes in this case the dram needs to change (
Mar 01, 2015 | Samsung CLX 3185FW - multifunction fax /...
It has plenty of ink and the drum is good but it stopped printing
All blank pages could either mean: On the scanner side: * Mechanical error, you'll need to perform service on it to reanimate it again. * You can check if it is on the scanner side by printing a test page on the printer. If it prints fine, the problem is in the scanning process.
On the printer side: * Dirty connectors between toner/drum unit and machine. Remove the toner/drum package and clean the metallic cylinders on the left and right side of the toner/drum unit, then reinsert package into machine. * Bad toner and/or drum unit. Replace should solve it. * Mechanical error, you'll need to perform service on it to reanimate it again. * You can check if it is on the printer side by either scanning to a connected PC or sending a fax to someone. If the scanned/faxed page looks fine on the pc/fax that receives the fax, the problem is in the printing process.
Jun 02, 2009 | Brother MFC 9700 All-In-One Laser Printer
SENDING FAX COMING BACK BLANK PAGES .NOT PRINTING ATALL.
If you attempt to print any kind of report from your unit and the pages are still blank there are two posibilities.
#1 The toner cartridge tape was never pulled out correctly/ the toner cartridge might be defective.
#2 A more serious cause fo the same symtom might be a defective hi voltage section in the unit. On a newer product this is not very likely
May 13, 2009 | Canon FAX-L1000 Plain Paper Laser
Pages come out blank
seems your toner catridge is finished or the contacts on you toner cartridge are not making contact. check the contacts and clean the metal contacts on the side of the toner cartridge.hope this helps
Dec 22, 2008 | Samsung Office Equipment & Supplies
Fax 2820 will not print. pages are blank
what do you mean printing stage?for the blank pages,it may only require cleaning.check the toner save setting,make sure it is off.clean the scanner glass of the machine,or you may just need to replace the drum
Nov 15, 2008 | Brother IntelliFax-2820 Laser Fax
Blank pages
remove the cartridge and using a damp cloth wipe the ink openings...this might fix the issue.
Oct 01, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Blank Streaks
streaks are caused either by the toner, drum, lamp or fuser.
If you make a copy and it does not show a streak then it was done by the person sending the fax. BUT, check this,
open door and take out toner cartridge. look for a thin glass that is on the bottom of the machine and wipe it. Toner spills will cause a black streak.
Nov 15, 2007 | Brother IntelliFAX 2800 Laser Fax
Can not receive faxes or blank pages com thru!
Can you make a copy and get a good print? Does the blank pages come from different people? If you still get a blank from making a copy, then try a different toner and or drum unit. Hopefully it is still under warranty.
Aug 01, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
145 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
