Question about Samsung WF337AA Front Load Washer
My washer will not spin out the clothes. They are sopping wet even after I try to spin themagain. I am so frustrated !!!!! Service man replaced the motherboard. When called to let him know that the washer is stilldoing the samething, he willnot return my call. What to do with this washer?
  • drickman72 Apr 04, 2011
    Yes, I can hear it, but where is the pump?
  • 822 Answers
On spin.......can you hear pump pumping,..if so...pump is blocked.............
unblock it and job done........
cheers
Posted on Apr 04, 2011
  • paul
    paul Apr 05, 2011
    look at the back of the machine....you have a waste pipe.going into the machine..that connects onto the pump...
    zanusis have the pump at the front of the machine with a flap that opens then thje pump has an opener under the flap to aid eadt cleaning..........but most other machines have the pump around the back..
    if you get stuck..........just shout...........
    cheers
I have a neptune top loading washer. Call PSEG service man out (had contract on washing machine). will not repair cost too much. Problem. end cycle spin -water will not come completly out of cloths....
Yes Elizabeth if you don't DIY the fix it's no worth having a repair service touch the machine.
I'm an knowledgeable owner and have helped many owners across 4 different forums save their $1K machine at reasonable cost. If you want to DIY I will help at this forum........ Google this ""FAV6800A/FAV9800A Outer Tub bearing replacement"" read thru the post and see if this is for you or someone that can help you DIY the work..............Good Luck dh1200s
Aug 01, 2011 | Maytag Neptune FAV6800AW Top Load Washer
When the wash is done the clothes are sopping wet. I tried putting fewer clothes in and they are still very wet. Checked the drain hose for a kink and it seems to be fine.
motor coupler-to test restart the washer in it's spin cycle, let the washing machine run for one minute, then open the lid and check to see if the tub is spinning. if it's spinning the coupler is fine. if it is not then the coupler needs to be replaced, can be purchased at any appliance parts store. good luck!
Jan 04, 2011 | Kenmore Energy Star 44092 Front Load...
Hi, my neptune washer will not spin clothes dry they come out sopping wet. can you help? thanks
if there is water standing in your washer your pump is clogged clear it out and will correct the problem ; if there is no water in the machine when you complete the cycle but the clothes are wet it did not spin more than likely your door switch is probably bad replace it
Aug 19, 2010 | Maytag Neptune MAH5500B Front Load Washer
Clothes sopping wet at end of all cycles
Here is a tip that I wrote a bout front load washer spinning and draining problems...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 16, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer sometimes leaves clothes sopping wet - then the next day O
you can remove the bottom access panel to get to the drain pump. there might be something in the coin trap.
Jun 24, 2009 | Kenmore 44072 Front Load Washer
Spin cycle not completely spinning out
Could be something stuck in the pump. Could be a bad belt.
This brand eats belts if the tub is overloaded even occasionally.
Remove the front panel and inspect the belt. Any glazing on the belt it should be replaced.
Remove and check the pump while you are there.
May 19, 2009 | Westinghouse Washing Machines
Clothes coming out of washer still soaking wet
is it a kenmore top load?if so the motor is not kicking in to 2nd gear for high fast spin,does it have a speed control on the head?are you using it on the reg. wash cycle?-mike
Apr 18, 2009 | Washing Machines
How can i fix my washer myself?
The washer will not ever completely drain according to Maytag. A certain amount of water stays in the outter tub for balancing the machine for final hyper-spin. However if the machine is not spinning all of the water out and your clothes come out sopping wet....read the long thread I typed out to another person earlier.....it's about 2-3 questions up on the same topic
Dec 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
Samsung WF337AA Front Load Washer Logo
168 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
