Question about Traxxas Rc Revo Nitro Monster Truck
How do you adjust the reverse feature and can you get that info online
    Problem Solver:
  • 12 Answers
Traxxas manuals are available on their website.
Posted on Apr 05, 2011
Troy bilt mower pony
are your blades engaged when you try to do this??
if so it is a back up safety feature from factory,turn blades off and try?
Or put the ignition switch in the position that will keep the mower running when you go in reverse with the blades on or push a button on dash when you go in reverse,probably not on yours just some of the features on some models and just something to look for on yours
Aug 02, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
The electric massage chair I am looking to buy online says that it comes with computer assisted adjustability. What does this mean?
The chair has a feature that will automatically adjust for the specific weight, height and width of the user. The massage chair will mechanically make the necessary adjustments so that the nodes and rollers can properly adjust as well.
Aug 06, 2012 | Furniture
03 Toyota Matrix will not start. Will start if roll off. Appears to be starter but in common factors are back up lights do not come on and when in reverse the beeping sound does alert (6-speed). Have not...
With the extra info, we can tell the problem is with the park/neutral switch. The same switch that prevents you from starting in gear also turns on the backup lights. The switch is bolted to the transmission and looks like the picture below. The switch is adjustable and may just need adjusting, but unless your car beeps in a different gear, the switch may need to be replaced. When adjusting a new switch, I put the car in reverse with the key on and the brake set (engine off) and I turn the switch until the reverse lights come on. Unfortunately this switch is expensive, so I do suggest you try adjusting it before buying a new one. The price at Autozone is over $200, but you may find one cheaper online. Please let me know if you have more questions, and thanks for using FixYa.
May 08, 2011 | 2003 Toyota Matrix
How to adjust the focus of Olympus lenses?The E-30 has a Focus Adjust feature but how do you determine if a lens back or front focuses? Then how do you properly use the Focus adjust feature?
Kept searching online and found this site :http://www.olympus.co.jp/en/support/imsg/digicamera/qa/products/e30/di102468e.cfm .
Sorry, I won't have to pay for your site but thanks anyway. The Internet; it's a wonderful thing!
conleyr
Jan 17, 2010 | Olympus Cameras
Reverse gear spits out
is it manual or automatic. Spits out. Being an 85 golf, There are parts on vehicles that need adjusting over time. There are parts on these adjustable parts that need maintenance and after say 24 years lol, replacing. Shift linkage adjustment and shift bushings are the most common cause of reverse (spitting out). Purchased online for 8.00 U.S. or get the nice neoprene if you plan on keeping the golf. Shift linkage adjustment is easy if you are a professional. If your not, plan to be on your back and making alot of trips back and forth if you don't know what your doing. Don't let some crook talk you into serious money. Adjust your linkage , but first replace the shift bushings. The little things are what tell the big things what to do.
Jun 28, 2009 | 1996 Volkswagen Jetta
Where can I get copy of instructons - Air SBEGO Mini IR Helicoper
have you made sure that the helicopter is charged completely?
if so when you try to take off if it spins to the left then hit the r trim on the remote and if it spins to the right then hit the l trim on the controller.
honestly all the instructions do is tell you how to put batteries in the controller.
Dec 30, 2008 | Sky I Blade Mini IR Helicopter W/ Remote...
Remote LOST - need info on what button to press...JVC AV-48WP30
There might be some features that the universal remotes aren't able to do. To perform the convergence alignment you should have the original remote.
Do you have the user manual or service manual?
The service manual will explain this process better.
Apr 10, 2008 | JVC AV-48WP30 48" Rear Projection...
Need help
This is some basic info I could find on your dryer. I will need you Serial Number in order to determine the year it was produced. Please post back with comments and let me know.
Whirlpool Duet GEW9250P 7.0 Cu. Ft. Super Capacity 8 Cycle Front Load Electric Dryer With AccuDry Sensing System. Dry clothes in the time it takes to wash them. The dryers uses AccelerCare™ technology to work just as fast as the washer (Up to a 9 lb. load), giving you more time to enjoy all the good things you've worked hard to achieve.
AccuDry™ Sensing System - Monitor remaining moisture and automatically stop the cycle when the load is dry, with the AccuDry™ sensor. Reduce overdrying and save time and effort, by not having to return to the dryer to re-check progress.
Senseon™ Drying System - Moisture-sensing strips and temperature sensors inside the dryer drum monitor how fast the load is drying, how hot the air should be and when clothes are dry. The system automatically stops the cycle to help save time and prevent overdrying. Senseon™ technology safely dries clothes faster than it takes to wash them.
Wrinkle Shield™ Plus Feature (120 Minutes) - The Wrinkle Shield™ Plus option automatically tumbles the load without heat to help prevent wrinkles from forming.
Whirlpool brand offers an ergonomic solution for its front-load washers and dryers to help reduce bending, stooping, or arching. Based on your height and laundry room needs, optional 10 in. and 15.5 in. pedestals make loading, unloading, and filling the dispensers easier. The 15.5 in. pedestal doubles as a storage drawer with a convenient sliding shelf to support your laundry basket.
Item Features:
  • Super Capacity Plus - 7.0 Cu. Ft.
  • AccuDry™ Sensor
  • Senseon™ Drying System
  • 8 Automatic Cycles
  • Bulky Items Cycle
  • Adjustable End-of-Cycle Signal
  • Wrinkle Shield™ Plus Feature (120 Min.)
  • 5 Temperature Selections
  • Quiet Dry Plus Noise Reduction
  • Dry Rack
  • Reversible Side-Swing Door
  • Dryer Door Window
  • Reversible Side Swing Door
  • Electronic Controls
  • Front-Mounted Lint Screen
  • Interior Drum Light
  • 4-Way Venting
  • Porcelain SpillGuard™ Top
  • Optional Storage Pedestals Available
  • Stackable Installation with Matching Washer
  • Matches Duet® Washer
Specs:
  • Warranty: 1 Year Parts & Labor
  • Capacity: 7.0 Cu. Ft.
  • Dimensions (HxWxD): 38 in. x 27 in. x 31 1/2 in; Depth with Door Open - 51.5"
  • Construction: Front Access, Reversible Side-Swing Door Style, Powder Coat Drum Material, Dry Rack, Extra Large Front Mount Lint Screen, Power Cord & Venting Accessories, Stackable
  • Controls: Electronic Controls
  • Electrical Requirements: 30 Ampere, 120/240 Volts, 60 Hertz (1/second). AC-ONLY. USE COPPER WIRE ONLY. A FOUR-WIRE OR THREE-WIRE, SINGLE PHASE ELECTRICAL SUPPLY REQUIRED. A TIME-DELAY FUSE OR CIRCUIT BREAKER AND SEPARATE CIRCUIT IS RECOMMENDED.
You can get an owner's manual replacement for your dryer at laundrymanuals.com. I believe there is a membership fee for the website, however. I hope this info helps you.
Nov 23, 2007 | Whirlpool GEW9250 Electric Dryer
Traxxas Rc Revo Nitro Monster Truck Logo
114 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
John mullen
gbob59
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
