Question about Samsung Televison & Video
I own (2) Samsung PN50A450P1D Plasma TV's. The sound, when using the QAM tuner on a HD station, is garbled. I called Samsung for Tech Support when these TV's were still under warranty. Samsung told le that the issue was Comcast's. Now the TV's are 2 yrs old, out of warranty, and I just bought another, different brand of TV and have NO sound issues.
4 Suggested Answers
  • 87 Answers
SOURCE: QAM Tuner difference between Toshiba & Samsung
software upgrade available from toshiba.
Posted on Apr 24, 2009
SOURCE: Can't view local HD with built-in QAM tuner on Sharp Aquos LED
I found this solution at ehow.com and it works: http://www.ehow.com/how_5417083_hd-channels-comcast.html. You'll just have to switch over to another input to view the HD channels.
Posted on Dec 07, 2009
ladywinn
  • 5138 Answers
SOURCE: I have an LG 32LC7D
Yes ,its the main board PN EBU40417101
Look on Ebay
Posted on Sep 12, 2010
I have a nspdp42 plasma and i cant affort cable and want free tv. is there a analog to digital converter in the unit already? the model # is 801rmd2237770 Thank you
The Insignia NS-PDP42 Plasma HDTV has a built in ATSC/NTSC/QAM tuner.
In short, yes, it does have a digital converter built in, but you will need a antenna capable of receiving digital broadcasts. You can find these at Walmart for $15 to $60.
Mar 05, 2011 | Insignia 42" Flat-Panel Plasma HDTV
My Brand New 40" westing
To get HD channel form your cable TV without using the cable provider HD tuner box but using your TV Clear QAM tuner (your TV has Clear QAM tuner, my TV also has QAM tuner so I do not have to use the cabel box, but my COMCAST does not provide may Clear QAM signals like they use to) to get the unscrambled HD, the cable provider must provide those unscrambled Clear QAMsignals for your TV to pick up the signalS.
Learn more about Clear QAM cable signals:
http://en.wikipedia.org/wiki/QAM_(television)
Did you use the correct setup during the tuner setup to scan the availabel cable channel per user manual?
Dec 30, 2010 | Westinghouse SK-40H520S 40 in. LCD TV
Trying to set up Digital Labs 19''LCD TV/DVD combo and only gets limited cable channels (old tv on same cable gets lot more). Have completed auto scan and pick cable as reciever however only gets limited...
The remote control that came with my Digital Labs tv/dvd combo worked for about 2 seconds and never really worked correctly. Now, I'm trying to find a universal remote that will be compatible. Please help.
Dec 26, 2009 | Televison & Video
Dec 03, 2009 | Sharp Televison & Video
Our 37" series 4 (450) LCD TV sound "garbles"
Hi my name is Roety,
I can help you with your issue ,
Make sure you have the latest firmware upgrade from Samsungs website!
Also weak signal can cause this if using air signal raise or connect a better antenna
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Nov 29, 2009 | Samsung LA37A450 37 in. HD-Ready LCD TV
We have a Toshiba HDTV model number 57H82. It is
Sounds like a bad tuner/decoder on the Qam analog side of things. You can bypass this with a Clear qam converter box or a analog to digital tuner box or simply having this repaired upwards of $200 bucks.
Thanks for using Fixya.com
You're Toshiba Tv Expert.
Aug 31, 2009 | Toshiba 57H82 57" Rear Projection...
How do i know if my tv has a quam tuner im not
First it is QAM (quadrature amplitude modulation) and is used only on cable systems. Know that you will only get clear-QAM, this is, those not encrypted. This means only the local channels, which they are not allowed to encrypt. It will switch automatically, so if you get any HD it will be QAM. They will have names like 85-1 for digital source, not necessarily HD. Not all set-top boxes can tune digital channels--check with your cable system. You have called them? Be sure to remind them on your STB make and model, they may need to replace it. -Ken
Jul 16, 2009 | Samsung Televison & Video
LOCAL HD CHANNELS WONT COME THROUGH
Only has an ATSC tuner. Will not do cable QAM.
Jun 19, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
Samsung Plasma Display HPN5039
Vladislav was able to fix his TV by replacing some defective capacitors in the power supply.
The locations of the defective capacitors are C523 and C524. The value is 0.22uF 400VDC or can use 600VDC as well.
You can also buy the entire power supply assembly by clicking here.
Good Luck.
May 07, 2008 | Samsung HPN5039 50 in. Plasma HDTV
Qam tuner
For most cable services, you need their decoder box to have the digital and HD services.
For the Sony HD TV, you will get best results with an HD cable box, and use the HDMI cable interconnect with it.
Call your cable company for details.
Jerry G.
Dec 18, 2007 | Sanyo DP42746 42 in. Plasma Television
Open Questions:
Televison & Video Logo
44 people viewed this question
Henry  Thomas
Henry Thomas
