Question about Poulan Pro 25CC 2Cycle Gas Blower
25 cc poulan pro gas blower idle screw setting. What is the correct settin for this blower?
    President:
  • Poulan Master
  • 1,545 Answers
If the carburetor is a Zama (and it probably is), then the manufacturer of the carb states these settings:
http://www.zamacarb.com/tipspage.html
Posted on Apr 04, 2011
What are the initial settings for air/gas adjustment screws, 34cc Poulan Pro. (PP 3416)
Idle screw should be set/turned to where the chain doesn't move but the engine idles. Here is the manual: http://www.poulanpro.com/ddoc/ppoo/ppoo2010_usen/ppoo2010_usen__545186810.pdf
Nov 15, 2016 | Poulan Garden
What is fuel mixture on a 25cc craftsman weedwacker
I always mix it 40:1 so that the piston will always be lubricated and after I finish cutting I empty the gas tank and then restart machine so as to keep the fuel filter clean.
David
Sep 21, 2014 | Poulan Pro BVM200VS 25 cc Gas Powered...
Adjust idle up on poulan pro 42 cc chain saw
Adjust the low side out another quarter turn first before messing with the idle screw.
Sep 15, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Hello i'am working on a poulan pro weedeater pp330 i need the adjustment on the air and gas mixture screws
it would be only on the fuel side--adjust all closed then open half way--this should allow to start then adjust to best idle
Sep 05, 2014 | Poulan Pro Weedeater Leaf Blower/vac...
Poulan stalls out
on the side of the carb you should find two screws, one for the low speed jet nd one for he high speed jet. Turning the low speed jet only about a 1/4 turn at a time, adjust it in or out until it idles smoothly. Go to arboristsite.com, chainsaw and do a search on tuning for more complete info.
Jun 09, 2010 | Poulan Pro PP3816AV 38 Cc 16" Anti - Vib...
Poulan bvm pro 200 gas blower not getting gas
As a service center for Poulan products the usual problems for not starting I see is compression or the cylinder has come loose from the crankcase. Compression needs to be 115 psi minimum. If you remove the plastic muffler cover you can see the cylinder-crankcase joint. Wiggle the spark plug to look for any movement at that joint. If there is any movement the cylinder screws are loose.
Poulan has an excellent 2 year warranty and any service center should be happy to repair it under warranty for any problem.
Sep 22, 2008 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan Pro 25CC 2Cycle Gas Blower Logo
798 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
