Question about Goodman CPLE24-1 Air Conditioner
What kind of freon does my unit take? Model number CPLE24-1
    Scholar:
  • 133 Answers
Refrigerant 22. Here is the site for the units specifications on the CPLE24-1. http://www.alpinehomeair.com/viewproduct.cfm?productID=453054740 Please grade the help I have given. Good or bad, it all helps. Thank you. Roger
Posted on Apr 05, 2011
What kind of freon was used in this unit when made
You didn't give a model or brand so here is what to check. Find the model--serial tag on the air conditioner and it should tell you type of freon and usually the amount. Most older air conditioners were freon R22.
May 20, 2015 | Heating & Cooling
Trying to find my model number on my coleman q.e.d II emerson model
try cleaning inside coil. alot of things can make it seem your low on freon. dirty filter, dirty coil, slow fan speed.
Apr 08, 2014 | Coleman Heating & Cooling
Your unit can be low on freezon and can have stop up inside coils if air cant move across coils it will ice up on inside clean coils and check if unit still ice up it low in freezon.
Can i add coolant to my home unit
If you mean freon, probably not.
It depends on what kind of freon is used. It takes a license to buy most types of freon for household use.
Aug 08, 2012 | Cars & Trucks
I have a model # 9530A601 and the frieon seems to be empty, what kind and how do I recharge it? my name is Toby
unless you are HVAC certified you will not be able to purchase freon. The type of freon and tonage are printed on the side panel of your outdoor unit. Charging an a/c system is not simple task you will need to call a technician unless you know someone in the field. Overcharging or Undercharging can do damage to your compressor rendering your unit worthless.
Jul 25, 2012 | Coleman Heating & Cooling
What kind of freon does this model refrigerator need
Most all Domestic refrigerators these days use R134 refrigerant such as yours most likely uses. The easiest way to assure what type of refrigerant would be to access the compressor area and look on the side of the compressor. All compressors have a tag showing what type of refrigerant is used in the unit. If you have any further questions or if you need a detailed schematic showing how to access the compressor area message me back your complete model number and I will provide one for you.
Thank you,
Rick
P.s. Never assume a unit uses one type or another types such as R11,R12, and R22 are being phased out due to government regulations on the hazzardous chemicals found in refrigerants such as these. It is always best to check the compressor for the labeling tag.
Jul 01, 2012 | Sub-Zero 561 / F
Will the a\c compresser work if no freon
The answer is no. The unit is protected by a switch to prevent it from not starting with no or low Freon. Freon contains lubricating oil. So --- No freon , no lubrication, compressor will seize up.
Kind of a good thing. Saves the compressor if the unit runs out of Freon.
Wayne
Jun 08, 2011 | 1993 Buick Regal
Suncutter A/C needs freon. I have added freon to my vehicle system myself. Are home units set up the same way as automobile systems?
To a point yes they are. But home units require a different type of freon, the oils are different and you can cause major damage using the wrong freon or using the same gauges that where used to fill a car, also the residential or commercial units use a very specific amount of freon and if you are to high or to low you can cause damage. You should not be low on freon and it is recommended that you get a qualified service technician out to look at your unit and run dye through it to find the leak. If this is a newer system you are running very high PSI throughout your system and without the proper equipment you can cause damage to yourself or the unit. I hope that this kind of answers your question
May 29, 2011 | Heating & Cooling
What type of freon does the walk in refer take
How about a compressor model number. This will identify the Refrigerant used.
Dec 07, 2010 | Nor-Lake Norlake Refrigeration 4' x 6'...
How much freon do i put in my ge refrigerator
You have to check the tag where is the model number and all the info of the fridge , it should says how many oz. and what kind of freon it needs.
Aug 05, 2009 | GE Refrigerators
Heating & Cooling Logo
274 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
