Question about Maytag LAT2300 Top Load Washer
Maytag performer LAT2300 ae leaking from bottom, how do you check underneath? does the top pop up?
2 Suggested Answers
smartr10U
  • 1305 Answers
SOURCE: maytag washer
Many of the maytag toploaders have a rubber fill hose at the top of the outer drum.
Sometimes if the machine is fully loaded (or overloaded), during the spin cycle if clothes are above the top of the drum they can actually knock the rubber flange of the hose out of the drum. Then when the machine fills with water, it will dump it down the outside of the tub and it will appear that the water is leaking from the top and side of the drum... Fix it by snapping the fill hose flange back into the hole in the top part of the drum... let me know how you do or need more help...
Posted on May 10, 2009
Maytag mav6057aww leaking underneath
What I would do is pop the top of the washer, do this by pressing the clips in between the top and front of the machine, and then remove the front by taking out the two screws, one on left and right inside on the upper corners. These are normally 5/16". Lower the top after you take the front off and turn the machine on. Now you'll be able to isolate your problem.
May 19, 2012 | Maytag Washing Machines
Trying to remove aggitator from maytag atlantis I removed fabric softener part need to get the shaft of aggitator off trying to clean my softener keeps leaking out after wash is done
i believe all you have to do is put your fingers underneath the bottom of the agitator and pull up and the whole agitator pops up to remove it out of the tub.
Apr 08, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis leaking water, not from hoses - solution?
Hi this could be coming from a number of places. First get putty knife or possible a butter knife and pop the top. There are 2 clips holding it on they are at the top front about 2" in from the corners... Push in knife and pull up on top at the same time...Fold the top back out of the way and observe inside to see where the water is leaking. If it is coming from underneath you may need to remove the front to screw top left and right then fold out and up to remove. Observe underneath to see where the leak is.
If I can help with anything else please let me know.
Apr 13, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Washer leaking from the bottom
It will be the normal trial and error. Remove the top lld and the back panel.statt the wash again and start looking for anything obvious. Start from the soap box, then carefully look down the sides and then if nothing seen, switch machine off and tilt machine untill you can see the underneath. Look for any areas where there is water .(when visible start looking a little higher untill you find the spot.) Most of the underneath areas are likely rust spots that have broken through.. On occation the pipes are perferrated and have a small leak. All observation.
Sep 23, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag top load washing machine leaking water from bottom
The machine is leaking water from the bottom, I think the leak is in the area near where the motor is mounted. Before we noticed the water comes from underneath the washer, we smelled like burning rubber.
Al Bana
Jun 26, 2009 | Maytag PAV2300 Top Load Washer
Leak underneath tub
check for a broken seal at center of tub , if so , write down the brand & model and go to an APPLIANCE PARTS SHOP, and get a new RUBBER SEAL KIT, hope this helps , AJ
May 20, 2009 | Washing Machines
Maytag top load will not agitate or spin after belt replacement
Off balance arm was stuck. Removed control panel, checked all connections and and lid closed switch and it worked.
Nov 05, 2008 | Maytag LAT2300 Top Load Washer
Maytag washing machine lat8616aae
My lat8616aae has just rusted on the drum so i need to replace, but i do not know the Cu. Ft of it anyone know??? thanks
Apr 04, 2008 | Maytag LAT2300 Top Load Washer
Maytag LAT9800ABW
Plug off the wall, etc. Remove the rear cover. There is a thin tube coming from the control panel area to the base where the water exits, this should not be blocked, remove from top and blow to check, refit. Next clean out your outlet filter, it could be clogged, refit. This tube controls the water level. Do not overload your machine, the manual will tell you the max load. Check to see if any hose has come loose from behind the machine; look inside from behind.
Sep 11, 2007 | Maytag LAT2300 Top Load Washer
Washing Machines Logo
35 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
