Question about Uniden BC72XLT Handheld Scanner
My scanner wont pick up any frequencys. - Uniden BC72XLT Handheld Scanner
  • 44 Answers
Its because its not programmed...
Posted on Jul 16, 2011
Can a Uniden Hh979 Vhf Marine Handheld Radio pick up police frequency's
If you have the ability to input frequencies into your scanner then yes you can pick up any frequency that you can get your hands on they have books they used to sell at the bookstore with all the police frequencies in them for example the state of California however some departments have secondary Frequencies that they don't give out
Apr 17, 2016 | Uniden Radio Communications
Why wont my scanner model 60 channel pro-2029 scan
Hi Chad,
Do you have any frequencies programmed into your radio scanner?
If not, then that is why you're not receiving anything.
If on the other hand you do have frequencies programmed, are they the correct frequencies for your location?
Are the frequencies the Tx or Rx frequencies that you programmed, The Tx frequencies are the correct frequencies to program, as Rx is the mobile(usually) Tx frequencies, and unless you're within 5 miles of that mobile, you won't hear it, and you certainly won't hear the base transmissions, unless it's a high powered Simplex Frequency.
I hope this has been useful to you.
Cheers,
Peter
Mar 15, 2013 | Radio Communications
My pro 2018 scanner wont pick anything up where i live could there be something wrong with the scanner or do i need a better antenna i live in holmes county ohio
First try picking up the NOAA Weather broadcasts. They're transmitted on seven frequencies (162.400, 162.425, 162.450, 162.475, 162.500, 162.525, 162.550) and at least one should be active in your area. To check reception, just press the WX key on your scanner. If you can pick up one or more of the frequencies, you'll know that the scanner is functioning properly. If not, your scanner is likely in need of repairs - a questionable move due to its age.
If the scanner is functioning (receiving the weather band), try a quick RESET. use a paperclip or pen point to press the recessed RESET button on the back of the scanner.
Make sure that you have programmed local active frequencies into the scanner. For a comprehensive database, and a lot of other useful scanning information, visit:
www.RadioReference.com
After all of the above, if you are receiving weather but no local transmissions, I recommend that you try an external antenna.
If you need the manual for your scanner, you can download and print it, at no cost, here:
http://support.radioshack.com/support_electronics/doc69/69290.pdf
Bill B
Listening in since the 60's
Sep 28, 2010 | Radio Shack Pro-2018 Scanner
Wont pick up any frequencies
Hi, my name is John. Try to program some frequency,s in it. Get them here. <a href="http://www.RadioFreq.com">www.RadioFreq.com</a> or <a href="http://www.RadioReference.com">www.RadioReference.com</a> ...instructions are #1. Press the E/PGM button. #2. Enter the frequency you want. Press the E/PGM button. #3. To program frequency, press the up- down arrow. #4. To exit, press the HOLD or SCAN button...... hope this was helpful....
Aug 27, 2010 | Uniden BC340CRS Base Scanner
I have this scanner and it will scan but it wont pick nothin up
A couple of things could be involved in your problem. You need to be listening to the frequencies that are being used in your area, but most of them will not be transmitting all of the time. Something you can try is if you live maybe about 10-20 miles from an airport and your scanner picks up aircraft frequencies you can look up the airport and find the automated beacon frequency and tune that in. The automated beacon should be transmitting 24/7 the weather conditions of the airport.
Another thing to check is weather you have the correct antenna attached to your scanner and that it is connected properly, the circuits in your scanner may need that antenna to be connected for the circuit to function properly.
If you are using the scanner to listen to your local Fire Dispatch there can be days when there isn't anything happening.
Another problem could be that your local Dispatch has moved over to a new Digital System and your scanner isn't equipped to recieve that System.
Apr 16, 2010 | Uniden Hand Held Scanner - BC-246T 2-Way...
Cant seem to get it to pick up local frequencies
Can't really diagnose the problem without more information, but make sure that your antenna is connected properly and that you've programmed frequencies that are active in your area. For a quick function check, program the frequency 162.55, 162.4, 162.475, 162.425, 162.45, 162.5, 162.525, 161.65, 161.775, or 163.275 into your scanner. One of them, probably the first one, will be the primary weather frequency in your area. If the scanner picks up the weather broadcast you'll know that it's working.
Dec 28, 2009 | Uniden BCT8 Base Scanner
Police scanner that doesnt get police signal anymore
They may have switched over to the trunk system, so the regular freqs wont work anymore. All city police departments are switching over, fed requirement.
Sep 17, 2009 | Radio Shack Pro-95 Handheld Scanner
Not hearing certain frequincies
not all scanners will pick up the same, the hand held can't pick up frequency as far as the other one.
Mar 11, 2009 | Radio Shack Pro-97 Handheld Scanner
Police scanner wont pick up police frequencies
do you still have a warranty? because it is going to need repair
you can try to leave it unplugged for a while , but otherwise its going to need repair
Nov 29, 2008 | Uniden BC898T Base Scanner
Uniden hand held scanner
my channels wont scan
Sep 19, 2007 | GPS
Uniden BC72XLT Handheld Scanner Logo
69 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
