Question about Maytag 24 in. MDB9150A Built-in Dishwasher
Maytag mdb9150 dishwasher stopped at some point last night--found it this morning with flashing lights--I think "clean" and "heated dry", not sure.  I used "drain/off" to make sure there was mechanical noise--there was, so I don't think the machine is dead.  Purchased on 2001 with 5 year warranty, so out of luck there.  I tried turning off the electricity to the unit for a few hours; nothing improved.  When you start it (or think you have!) it makes noises for about a minute that sound promising, then nothing, then a sort of low buzzing "I think I can" sound plays intermittently. Please help!!  Thanks. Marsha Landau, Evanston, IL
  • 142 Answers
Check pump and solonoids click/work, if no mechanical noise, could be the circuit board, but they can be expensive. :(
if the solenoids click, and allows water in, then the pump might be jammed, with grit, clean and reinstall... good luck !
Posted on Jan 27, 2009
Why is heated dry blinking?
FIXED Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry ...
www.applianceblog.com/.../40588-Kenmore-dishwasher-lights-flashing-...
Aug 26, 2013 - 10 posts - ‎3 authors
Thread: Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry" ... A few months ago, we had a brief power outage and the next morning, noticed the "Hi Temp" and "Heat Dry" lights were flashing. ... Well since then, the dishwasher intermittently stops mid-cycle and these same lights ... Thread: GE Eterna QuietPower 2 Normal and Heated Dry ...
Feb 24, 2012
Kenmore Elist 665 dishwasher Smart Wash red light ...
Dec 23, 2011
Heated dry blinking +17 times - ApplianceBlog
Nov 14, 2010
Heated Dry light blinking
Nov 7, 2010
More results from www.applianceblog.com
Why won't my dishwasher start and why does the "Heated Dry"
www.shopyourway.com > Manage My Life > Questions
Nov 16, 2009 - When I hold down the Heated Dry button to turn the control lock on it ...my dishwasher start and why does the "Heated Dry" light keep blinking ...
Dec 01, 2015 | Dishwashers
"Clean" & "Heated Dry" Lights Flashing
Trcontrol panal sorryy turning off the breaker for thirty seconds if not it could be a stuck
Apr 13, 2014 | Maytag MDB7100AWB Dishwasher
Maytag dishwasher mdb7100aws is flashing clean-lightwash-heated dry
I have a Maytag MDB7100AWS which suddenly started blinking the following LEDs: Clean, Rinse Only, Regular Wash, Tough Scrub and Heated dry. Tried cycling the breaker, no help. Tried the key sequences in the troubleshooting sheet behind the kick panel, no help. Then happened to press the Drain/Off button twice. All LEDs went out and am now on my second successful load, fingers crossed. Suspect the control board got latched up somehow.
Jan 25, 2012 | Maytag Dishwashers
'clean' light flashes
Press the normal wash then heated dry buttons in the same sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the cancel button.It will clear any existing faults and makes the dishwasher to operate normally.
To prevent the issue from recurring, run your hot water faucet first to ensure that hot water is present in the entire supply line before starting the filling.
Oct 18, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
MDB9150 The Clean light is on
Bad computer board. You will need to replace it. You can go to repairclinic.com they will have the part you need and the intstructions on how to replace it will be with your order
May 18, 2009 | Dishwashers
The heated dry and clean lights flash together
I had this same problem. I read on another blog that the manual recommends that you turn the power off to dishwasher. When you turn the washer back on, the lights still flash but then push the off button. The lights stopped flashing.
Jan 15, 2009 | Maytag 24 in. DWD1500A Built-in Dishwasher
Clean light flashes constanly. Won't clear out to start new cycle
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Jan 03, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
CLEAN and LIGHT WASH lights blink
peace,
Cut the power from the breaker source for 5 minutes. And it should reset the system!
Other wise you need hands on service
Aug 31, 2008 | Maytag 24 in. MDB9150A Built-in Dishwasher
Electronics problem with Maytag Dishwasher
the outlet pump may have become clogged, try removing and cleaning it.
Mar 26, 2008 | Maytag 24 in. MDB9150A Built-in Dishwasher
I can't get my dishwasher to start
try pressing normal wash, then heat dry normal wash then heat dry normal wash then heat dry. do it 3 times
Jan 27, 2007 | Maytag MDB9600A Jetclean II Built-in...
Maytag 24 in. MDB9150A Built-in Dishwasher Logo
415 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
