Question about Dryers
I have a Halston II,52",
worldvet
  • 859 Answers
SOURCE: Trying to replace 3 speed ceiling fan switch
The black goes to the L connection the others are a guess. You can do this two ways. Connect the colored wires in any sequence and then see what switch sequence give you high and lowest, the other one will be medium. Once you determine that, mark the wires with a piece of masking tape as high, medium and low. Otherwise you connect them, turn power on and use a multimeter to see which color gives you the highest voltage and which gives you lowest. Since you aren't comfortable using live wires and a meter, go with the first option and use the process of elimination to find the wires giving you the speeds you need to find the highest and lowest. Next, you need to determine how your switch sequence works. First pull has to give you highest speed. so you may end up wiring them in reverse if your first attempt is backwards. There is a reason the first pull needs to be highest, it powers up the motor so you can then chose a lower setting. A low setting first will over tax your motor and wear it out eventually as it has to work harder at first.
Let me know if you need further clarification and perhaps this is all you need to get fixed.
Regards,
Worldvet
ps I checked on the Internet of a wiring diagram and I bet you did tok all to no avail.
Posted on May 27, 2008
  • 79 Answers
SOURCE: Fan switch broken, wires out when opened
I googled Hampton Bay Manufacturing and this is what I found:
Hampton Bay fans are manufactured by "King of Fans Manufacturing, FL". The contact number for them is 800-330-3267. ...
Maybe they can supply you with a wiring diagram.
Posted on Jun 11, 2008
  • 3 Answers
SOURCE: need wiring instructions
The wiring is pretty self explainitory with the wireless receiver. As for installing the receiver; get the wiring done and then zipstrip the receiver to the side of the motor mount bracket. Just make sure that you put it where it clears the canopy (motor cover).
Posted on May 24, 2009
  • 235 Answers
SOURCE: Need a wiring diagram for a HamptonBay ceiling fan pull switch
Black is hot-white is neutral-blue is your light kit and goes with the black- yellow? should be a green for ground.
Posted on Jun 30, 2009
  • 377 Answers
SOURCE: I need a replacement fan blade for the hampton bay
If you go to this URL:
http://www.ceiling-fans-n-more.com/hampton-bay-ceiling-fans.php
you will be able to find what you need.
Posted on Oct 06, 2010
Need to know where to connect the red wire coming from the house to the fan motor
Red supposed to be the line (hot Wire) if you have a voltmeter try to verify this if not the other color has to be White that's the neutral and the green is the ground, now, on your fan you have the Light-wire, the Fan-wire usually they are black and red the neutral is white and the ground is no color (cooper), if you want to turn on the light and the fan separately you need to run another hot-wire and another switch if not
Red wire from the house to Light and Fan Wires
White wire from the house to white wire from the fan
And ground to ground
The only thing is that when you turn the wall switch on you have the light and the fan on you will have to turn either one off manually
Apr 30, 2016 | Hampton Bay Outdoor Ceiling Fans: Ceiling...
How to replace fan 3 speed switch in hampton bay ceiling light
Remove the switch housing from the fan with a Phillips screwdriver. Depending on the model, there are either two attaching screws on the base of the switch housing, or three screws around the upper rim of the housing. Once the screws have been removed, unscrew the brass finial surrounding the chain on the outside of the switch housing and pull the chain through to detach the housing from the fan.
Insert a thin flat headed screwdriver into the slot next to each wire; twist the screwdriver and pull the soldered ends of the wires out. If the wires are connected to the terminals with screws, undo the screw a few turns and pull the terminals out from under the screw heads. Undo the two screws holding the switch to the fan and remove it.
  • Take the old switch to the nearest electrical or home improvement outlet and buy an identical replacement part. If there are two similar switches and you're not sure which is the right one, describe the fan to a sales assistant and tell him how many operating speeds it's equipped with.
  • ceiling light
  • May 27, 2012 | Hampton Bay 52 In.Carriage House II in...
    I need a replacement fan blade for the hampton bay 52 in. carriage house II.
    Sep 19, 2010 | Hampton Bay 52 In.Carriage House II in...
    What do I do with the red wire coming down from the ceiling
    Usually the red wire is for a separate light switch... so you can switch the fan with one wall switch and the light with the other...
    so... if that is what you have hook it to the lighting wire of the fan and if not then just wire nut it off and forget about it...
    heatman101
    Aug 29, 2010 | Hampton Bay 52 In.Carriage House II in...
    I need a diagram for the wiring that goes from the fan to remote speed settings and then to electrical wires in ceiling
    all of the white wires connect together and to the white house wiring (neutral from ceiling) ..also the neutral or return wire for the controller (may also be white) .. then the black house wiring(or red if you have an external wall switch) is connected to the controller wire marked AC or AC input .. the output marked "lamp" on the controller connects to the blue wire that goes to the light bulb (or bulbs) ... the output called fan goes to the black wire of the fan motor .. the green house wire goes to either a bare wire, green wire or a green bolt that is screwed to the metal of the fan.. thats the safety ground ...
    Jun 05, 2010 | Hunter 52" Ceiling Fan With Light And...
    Replaced a light switch for a ceiling fan. Switch
    On the switch ... one wire goes to thefan or the light and the other wire goes to the power.
    All white wires normally go together.
    Jun 05, 2010 | Hampton Bay 52 In.Carriage House II in...
    Fan is working but no light. Why?
    They are on two different switches most likely. Check the fan light switch. Check the bulb... those are about the only things really
    Dec 09, 2009 | Hampton Bay 52 In.Carriage House II in...
    Need wiring instructions
    Mar 24, 2009 | Hampton Bay 52 In.Carriage House II in...
    Dryers Logo
    27 people viewed this question
    Top Dryers Experts
