Question about SanDisk Sansa Clip MP3 Player
It is frozen i have the 1g sansa clip mp3 player how do i unfreeze it
  • SanDisk Master
  • 32,281 Answers
You MP3 player may have a pin hole RESET button on the back of the player, use a pin or straighten paper clip and insert it into this pin hole. This button may be able to unfreeze your player.
Posted on Apr 04, 2011
It got hanged..it can be turned and the buttons are not functioning
How to Reset a Sansa Clip
The Sansa Clip is a high-quality MP3 player. It holds hundreds of songs and is built for portability. The "clip" allows you to attach it to your clothing or belt while you are working out or on the go. Even the best MP3 players can encounter some problems, and the Sansa Clip is no exception. If your Sansa Clip freezes up and does not respond, you may have to try resetting or reformatting it.
Turn Sansa Clip on. Press the "Menu" (home) button.
Press the bottom of the scroll wheel until you reach the "Settings" screen. Push the center button to choose "Settings."
Scroll down to "Reset All" and select. You'll be asked to confirm the reset. Select "Yes." This option will simply allow you to reset the language and location settings on your Sansa Clip. It will not erase data from the clip. To do a complete factory restore, follow Steps 4 and 5.
In the "Settings" menu, scroll down until you reach "Format" and then select. You will be asked to confirm that you wish to format. Select "Yes."
Wait for the screen to say "Formatting Complete." You have now cleared all the files from your Sansa Clip and reset it to factory settings.
Resetting a Frozen Sansa Clip
Push the power button up and hold it for 20 seconds. Release it, then turn it on again.
Go to the Sansa website and download the "Sansa Firmware Updater."
Select "Run" when the updater installs. (Installation will take less than two minutes.)
Wait for the Sansa Firmware Updater to run through its system test. It will ask you to connect the Sansa Clip to the computer to update your Sansa's software.
Connect the Sansa Clip. Remove it from the computer when instructed. If this process does not unfreeze your Sansa Clip, contact Sansa support at the Sansa Firmware Updater website.
Tips & Warnings
You should download the Sansa Firmware Updater to your computer even if you aren't having a problem with your Sansa. This will ensure that your device software remains up-to-date and free of technical glitches.
Reformatting the Sansa Clip will erase all songs and data on the device. Resetting will simply change your player's settings.
Feb 19, 2011 | SanDisk Sansa Clip MP3 Player
My sansa mp3 has frozen nothing moves,it is on , how can i dislock it
Hi,the Sansa is a portable media player made by SanDisk. As with all portable media players, there may come a time when your Sansa freezes up for one reason or another. This can be incredibly frustrating. Fortunately, there are a handful of different methods you can use to unfreeze the player.
Instructions
Wait for the battery in the Sansa to die completely. Once the battery is dead, you can plug the Sansa into your computer and download a firmware update for your particular model (see Resources below). You can also remove the battery from the Sansa if you want to speed up the process.
Plug the Sansa back into your computer. If the computer recognizes the device, the player should begin charging right away. This will unfreeze your Sansa.
Hold the power button down for roughly 10-20 seconds. The Sansa should turn off. Wait a few seconds and then turn the player back on.
Hold down the center button and the menu button at the same time. Do this for up to 30 seconds while watching the display screen.
Hope it helped.
Thanks for using fixya.
Jan 12, 2011 | SanDisk Sansa Clip MP3 Player
Its just frozen
Well first of all you can try the following steps -
1. Unfreeze a frozen Sansa Clip by pushing the power button up and holding it for 20 seconds. Release it, and then turn it on again.
2. Go to the Sansa website and download the "Sansa Firmware Updater."
3. Select "Run" when the updater installs. (Installation will take less than two minutes.)
4. Wait for the Sansa Firmware Updater to run through its system test. It will ask you to connect the Sansa Clip to the computer to update your Sansa's software.
5. Connect the Sansa Clip and then remove it from the computer when instructed. If this process does not unfreeze your Sansa Clip, contact Sansa support at the Sansa Firmware Updater website.
Good Luck!!
Thanks
Apr 15, 2010 | SanDisk Sansa Clip MP3 Player
The screen is frozen with the Disconnected symbol. I cannot shut it off. what should I do ?
Locate the reset button the unit. It should be very small, and you'll most likely need a pen or something to press it. But if you press it, it should unfreeze your mp3 player and reboot it.
I hope this helps.
Oct 14, 2009 | SanDisk Sansa Clip MP3 Player
I left my Sansa Clip MP3 Player plugged in while putting my laptop into hibernation. Now player does not response, I can't turn it on, and laptop doesn't recognize it at all.
    Complete Reset of Sansa Clip
  1. Step 1 Turn Sansa Clip on. Press the "Menu" (Home) button on the Sansa Clip.
  2. Step 2 Press the bottom of the scroll wheel until you reach the "Settings" screen. Push the center button to choose "Settings."
  3. Step 3 Scroll down to "Reset All," and select. You will be asked to confirm the reset. Select "Yes." This option will simply allow you to reset the language and location settings on your Sansa Clip. It will not erase data from the clip. To do a complete factory restore, follow steps 4 and 5.
  4. Step 4 In the "Settings" menu, scroll down until you reach "Format" and then select. You will be asked to confirm if you wish to format. Select "Yes."
  5. Step 5 Wait for the screen to say "Formatting Complete." You have now cleared all the files from your Sansa Clip and reset it to factory settings.
  6. Resetting a Frozen Sansa Clip
  7. Step 1 Unfreeze a frozen Sansa Clip by pushing the power button up and holding it for 20 seconds. Release it, and then turn it on again.
  8. Step 2 Go to the Sansa website and download the "Sansa Firmware Updater."
  9. Step 3 Select "Run" when the updater installs. (Installation will take less than two minutes.)
  10. Step 4 Wait for the Sansa Firmware Updater to run through its system test. It will ask you to connect the Sansa Clip to the computer to update your Sansa's software.
  11. Step 5 Connect the Sansa Clip and then remove it from the computer when instructed. If this process does not unfreeze your Sansa Clip, contact Sansa support at the Sansa Firmware Updater website.
Aug 22, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip 1g frozen wont reset do i need update, thats what caused this mess
did you try pushing the power button up and holding it there for about 10 seconds?
Oct 25, 2008 | SanDisk Sansa Clip MP3 Player
How to unfreeze a sansa clip mp3 that won't turn off
plug it into the computer and shut down then take it out
Sep 07, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
197 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
