Question about Toro Power Lawn Mower
I have a Toro Super Recycler Mdl 20033 ser 230000001 and up. Lawn mower will not start, there is no spark. New spark plug and fuel line. Change the magneto? Is this simple?
    President:
  • Toro Master
  • 1,545 Answers
You may not need to change the ignition module. The "air-gap" on it may just need to be adjusted. That is, the distance between the pickup legs of the ignition module and the magnets integrated into the flywheel. You would have to remove the exterior cover and any sheet metal cowling (directs air flow off the flywheel around the engines cylinder). Then, the coil and flywheel should be visible. I use a standard business card as a gauge. Slide it between the coil legs and the magnet area of the flywheel. You should feel just a slight little rub. If it won't slide or the gap is large, no spark will be produced. You will have to loosen the screws holding the coil in place, double up the card. let the magnets pull the legs in against the card with magnets behind and retighten. Then recheck for spark. Post back if needed.
Posted on Apr 04, 2011
    Problem Solver:
  • 13 Answers
How do you know it has know spark? this may not be the issue
Posted on May 20, 2011
1 yr old -won't start this year
probably need to clean out carby and fuel tank
Jun 11, 2013 | Toro Power Lawn Mower
Engines dies after 5 seconds
loosen the fuel cap and try running it the vent in the cap could be plugged up
Jun 11, 2012 | Toro Super Recycler Super Bagger Lawn...
Toro lawnmower Wiil not start
Remove carb float bowl. Clean bowl. Observe float bowl screw, look for hole thru bolt, if present use thin wire to clean out. Float should be hanging freely and gas should be flowing, raise float gas should stop. Pinch off gas line or use shut off valve. Remove pin from float, remove float and needle meter. Use thin wire to clean out passage were meter needle is inserted, wire should pass thru to behind choke. Replace float & meter needle. Replace float bowl. Pull rope half way several times. Inspect primer bulb for cracks or leak. Try to start, may take 5 or more pulls to prime.
Jun 04, 2012 | Toro Super Recycler Super Bagger Lawn...
Will not start toro model143.026706
if it stopped running after hitting something with the blade check the key on the flywheel where it meets the crank
Jun 04, 2012 | Toro Power Lawn Mower
Starts and runs great(when engine is cold).\r\nafter 15 mins the engine dies. will start up again, but will only run about 5 sec. and then dies. toro super recycler 5.5 hp GTS5
I would check the gas cap. If the gas cap is plugged or pieces missing from inside it will not allow air into the tank and the fuel will not flow properly to the carburetor. Just loosen the cap and try it, if it does not change check for dirt in the fuel line.
Jun 15, 2011 | Toro Garden
Toro recycler model number SR-21 S lawn mower wont start changed plug, filter, new gas. Mower ran for two lawn cuttings but seemed to overheat and choke out frequintly in high grass now it wont start at...
check your oil is it up to full, then I would check to see if you have compresson, pull your plug and roll over and feel with finger ,but don't touch spark plug wire or you will light up! next I would check for spark, then for fuel, make sure the carb is getting fuel,,,check your hoses and fuel cap and clean your carb and needle/seat and make sure gas will run through the fuel line. Also you could have sheared a flywheel key
the choke out you are talking about could of been a lean condition and smoked the eng rings
Good Luck compresson test should tell all 2StrokeJim
May 17, 2011 | Toro Lawn Mower With Toro Power Tools
I have a Toro super recycler model 20017 with a tecumseh motor, model LEV120, spec 361541B has spark and is getting fuel but will not start any suggestions? Have already replaced coil cause previously had...
Make sure that the doggone brass bolt that holds the carb bowl on was cleaned as well. It is the main jet and has tiny holes that get clogged from evaporated fuel/varnish and debris (if no inline fuel filter is used). It has holes on the bottom and the smooth part of the sides...it needs to be clean and shiny! If all is well and the motor is an OHV, then maybe the valves need adjusting.
Sep 14, 2010 | Toro Super Recycler Super Bagger Lawn...
Toro super recycler mower will not stay running, has fuel and oil and air filter was just replaced
Try replacing the fuel and spark plug. Gas may be bad. Get some fresh from the station not from the can sitting in the garage.
Drain the fuel system and put the fresh gas in.
HTH
Good Day.
Oct 30, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Power Lawn Mower Logo
643 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
