Question about Kenmore Dryers
Dryer was running and quit during cycle. What could be the problem?
  • Kenmore Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Apr 05, 2011
Whirlpool dryer runs, hums, then quits
Sounds like the motor is on it's last legs. Replace it. But, before paying huge money for a motor and the labor to install it, I suggest that you price a new dryer and compare it to the repair costs. It may still be a little more for a new dryer, but....IT'S NEW!
Mar 20, 2017 | Whirlpool Dryers
The signal dings at end of drying cycle but dryer keeps on running without heat
The drier works fine and heats during the cycle and then when the cycle is over the heat quits but the drier keeps running? Does it shut off when you open the door?
Aug 08, 2011 | Samsung DV330AE Dryer
Kenmore 700 series dryer; quit operating during cycle; will not restart; has power to terminal block; any suggestions?
the belt may have broken:
http://www.ehow.com/how_4814455_change-kenmore-dryer-belt.html
here is another website, Hope this helps Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
May 23, 2011 | Kenmore Dryers
Dryer quit running during cycle. Clothes were hot. Dryer will not start. Light works when door open & buzzer works when pushed.
Limit switch opening - most likely due to an airflow problem. Lint buildup may not be visible to you without some disassembly of the dryer. The top should fold back by removing two screws that hold the front down. The front panel should come off by removing two screws inside and possibly a few pressure clips. Check for lint buildup on the blower intake and beneath the lint filter.
Oct 28, 2010 | Kenmore Dryers
Buzzing noise
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 02, 2010 | Samsung DV419AGW Dryer
Dryer just stopped running during cycle and
your heat sensors or your duct is clogged unplug, cutoff gas if you have it. disconnect the hose clamp remove rear panel remove lint by picking light brushing vac.remove screws in duct reconnectwith foil tape hoseclamp, remove all kinks slopes,and crushes. karl
Oct 28, 2009 | Kenmore Dryers
GE Harmony Dryer dries fine one time won't quit sensing the next
The thermostatic fuse is getting hot during the run cycle and then staying open until the dryer cools down completely.
You may fix just by cleaning out the entire dryer. Remove the top cover and vacuum out thoroughly. Replace a torn lint screen and make sure your exhaust conduit is not leaking lint everywhere.
If you can't fix by cleaning, you will have to replace the thermostat which is a $5 part byt a $100 repair.
Jun 19, 2009 | GE Profile Harmony DPGT750EC Electric...
My gas dryer stopped turning.
There are two options on why your dryer would stop turning.
1. Your dryer motor quite
2. the dryer belt either came off or broke.
you will need to take the dryer apart to see if the belt is broken. if not than it is your motor.
Please let me know if you need further assistance in this matter.
Thank you for choosing fixya. please do not forget to rate and comment about your experiance.
Jan 06, 2009 | Dryers
Whirlpool dryer
If your dryer stops during its cycle, wait ten minutes and start dryer again. If dryer starts, then the motor was overheating.
Solution, Check for lint blockage around the motor and for possible overloading. If dryer repeatedly stops during its cycle, especially during consecutive loads, replace motor.
Good luck
Aug 10, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
35 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
