Question about Marantz CD-4000 CD Player
Hi, my Marantz CDP4000 (12 years old) for few days a go working first 3-4 minutes and then i have jitter and problem with reproduction. When i left player in stand by mode for a 5 minutes, player again working properly in first 3-5 minutes. Does it problem with power supply (old capacitors) or something else?
3 Suggested Answers
  • 3422 Answers
SOURCE: Marantz CD-5000 CD player
see if the player tries to read the disc. Load a disc and listen.
Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
If still ur problem is not solved then i am sad to say you have to get it repaired and thats the only solution..
Good luck..
Posted on Feb 22, 2008
  • 99 Answers
SOURCE: My one-year old Marantz CD5001 CD player
these models use the 12.1 philips laser mechanism and it is a very common problem for failing to read discs.
various technics / marantz / philips / cyrus cd players etc also use it and are plagued with the same fault.
it's a 90% chance the laser is dead!
philips realised the unreliability of this laser and uprated it to the identical looking VAM-12.
do not dismiss the spindle motor as these also fail quite alot on this mechanism.
hope this helps.
Posted on Sep 12, 2010
I have marantz 7'300 an the standby light is on but wont power on no screen no sound idk help please
Unplug it from ac for 10 minutes and then try it. If that does nothing you need to get it to warranty service. It has a 3 year warranty so should still be covered. No Video or audio output on MARANTZ nr1602
Jun 14, 2016 | Marantz Audio Players & Recorders
Marantz bd8002
Hi
Some machines have a mind of their own. Take a look there.
Free User Manuals and Owners Guides ManualsOnline com
One thing though from my experience is that when I have pushed too many buttons some things may not work properly, then I disconnect and wait. Sometimes it helps,
kolbrun
May 24, 2014 | Saeco Odea Giro Plus Coffee Maker
Can anyone tell me if the Adcom 5503 three channel amp is common ground? I want to use it to power some old school polk SDA 1C as my mains and a CSi5 polk center. Thanks
no reason why not, 3 channel amps used to be the "state of the art" back in the early stereo days. the third channel was produced from the sum of the right and left channels, (the plus side of the right and the plus side of the left were sent to the center channel. produced what was considered at the time a true reproduction of the sound as it was intended to be. your lucky to have this old amp.
Mar 12, 2011 | Adcom GFA-5503 3-Channel Amplifier
Hi. my fossil automatic watch stopped working. any advice?
Have you left it off for a few days? If an automatic watch is not worn, it will stop after 2-3 days.
You can get it started again by gently swinging it from side to side for a few minutes. For continuous working it needs continuous wearing.
Oct 22, 2010 | Fossil Watches
A cdr630 twelve years old will not record on any blank discs optical fail on maxell tdk and all brands.do you know what discs i can buy for this machine.marantz state discs with a green dye but i cannot...
The manual states that 74 minute 650MB 1-4X disks run best; my machine would not burn anything I had, eventually I found 650MB crrw's on ebay for as cheap as 2 cents a piece, I have a fair number of them and so far every single one has worked. Imation 800Mb cd's seem to work 80% for me.
May 20, 2010 | Marantz CDR631 CD Recorder
Need to give a FULL RESET in a MARANTZ SR5004 RECEIVER
Switch off the unit. Then hold down Sorround, Exit, Memory & Clear buttons all together and then switch on the power. This should work.
Jan 26, 2010 | Marantz Audio Players & Recorders
Battery needs jump start if car is not driven for 3 days.
u either have a shorted cell in the battery or the system has a current draw like a glove box light being left on, try disconnecting the battery the next time you leave it, if it starts ok then u have a current draw and need to find the source of that draw.
Mar 16, 2009 | 1994 Jaguar XJ6
Suddenly has the jitters. No change to nearby magnetic fields.
Is this monitor on its way to never-never-land? Believe it.
Jun 18, 2017 | Dell P991 19" CRT Monitor
Door locked, start pause light flashing
I also have the same problem. I have got it to work by unplugging for a day and night. When I plug it in the next day it works like new for a couple days and then back to the same old "door locked" problem when the door isn't locked........BIG HEADACHE!!!!
Jun 11, 2008 | GE WSXH208A Front Load Washer
Marantz CD-4000 CD Player Logo
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
