Question about OKI C9300 Led Printer
I tried to print a PDF file and received this error message: ERROR: invalidfont OFFENDING COMMAND: definefont STACK: /Font -dictionary- /PBAAAA+GaramndPremrPro-MedItCapt false I can't find information on this type of error anywhere. Please help with instructions on how to fix? Thank you!
5 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: False empty toner reading
You may need to do a full reset.
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
The above is of course assuming no hardware/firmware fault on the printer.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 12, 2008
  • 24 Answers
SOURCE: When printing .pdf's to HP 8500N ..I get a stackdump sse more inf
I find most PDF printing issues are due to the print Driver. Your print driver should be a Post Script driver they offer the best support for PDF files.
The issue your having is most likely due to the print driver. First step would be to replace your driver.
Print the document again.
If it does the same thing, then it could be caused by the actual PDF file your printing.
Print other PDF documents does it do this with all PDF's?
If so your Acrobat Software has an issue. Reinstall Acrobat.
Print PDF's again.
If the problem remains then it becomes a issue most likely caused by your Operating Sys of your computer.
Posted on Jul 27, 2009
  • 57 Answers
SOURCE: have a Xerox Phaser 8560
Sounds like a Postscript error. Try resetting the NVRAM. 'Troubleshooting', Service Tools', 'Reset NVRAM'. If that doesn't work, go into diagnostics and clear the PS NVRAM. 'Troubleshooting', 'Service Tools', press and hold 'Up Button' then press 'Down Button'. This takes you into a hidden service menu. From there scroll down to 'Enter Service Diagnostics' and press OK. Printer will turn off and reboot into diagnostics. Scroll down to 'Function' menu and press OK. Now scroll down to 'Clear PS NVRAM' and press OK. Press 'Back' button to return to first menu, scroll up to select 'Return To Customer Mode' and press OK. Don't forget you will lose all printer settings including your IP address. As you cannot print out a configuration page, this will be like setting the printer up from new as you will have no reference to your earlier settings.
Hope this helps.
Posted on Jan 22, 2011
  • 50 Answers
SOURCE: Hi - I can direct
I do not believe any font declaration in the pdf file is interpreted by the printer. PDF files are really nothing more than graphic files and are therefore printed in graphics mode not character mode.
Posted on Jul 18, 2011
Why is it I receive an error message "undefined" Offending Command: Operand Stack? What do I need to fix this?
This is an issue between the file you're trying to print and the printer not being able to read it correctly.
Try copying it and pasting it in a new document (preferrably different program) If that doesn't work, try to install and use another driver
Jan 20, 2015 | Xerox Phaser 6200N Laser Printer
Offending command F0S53
Not all printers can handle a ps2 file. Check back with Kyocera at
http://www.kyocera.co.uk/ and select the Support button.
Feb 25, 2014 | Kyocera Office Equipment & Supplies
When I try to print something from my Mac running OS 10.6.7 i get the message that a pipe is broken, and all that prints out is a Error: Syntaxerror OFFENDING COMMAND: true cvt 0fpgm glyf ...
Hi, From what I can make out, you have a corrupted font. The 'true cvt 0fpgm glyf' part refers to a true type thingie The /sfnts is a Mac-speak for system font.
Try the Mac forums for the font issues. Good luck.
Sep 12, 2011 | Xerox Phaser 6180N Laser Printer
Please help. The device prints once and then stops printing until restarted. This process continues between every print job. The message printed out from the printer is as follows: ERROR:...
This is a corrupted Postscript error.
Possible solutions are, reload up to date driver and/or firmware. Go to Xerox website address below for drivers and firmware.
http://www.support.xerox.com/support/phaser-4500/downloads/engb.html?operatingSystem=winxp&fileLanguage=en_GB
This could also be a program specific problem, try printing from another software package.
Finally, you could try an NVRAM reset. Go to 'Troubleshooting', 'Service Tools', 'Reset NVRAM'. WARNING, before performing an NVRAM reset, print out a configuration page. 'Information', 'Information Pages', 'Configuration Page'. This print out will give you all the printers settings, including your network settings, which will be lost through the reset. You will need to re input them through 'Printer Setup', 'Connection Setup', 'TCPIP'.
Hope this helps.
Jan 21, 2011 | Xerox Phaser 4500 Printer
I have an HP laserjet 1320; all of a sudden I cannot duplex print...it will print one side only and on the reverse side of the page I get a message: Guest: ERROR: MemoryFull Guest: OFFENDING COMMAND:...
Welcome to Fixya
Try to restore the printer to factory state and make sure you record your printer's settings before performing this procedure. Holding down the printer's Green print button briefly will print any configuration information.
a. Turn the printer power off
b. Press and "hold" the green "go" button whilst turning the printer on.
c. Continue to hold the go button for at least 5 seconds and until the amber
attention light turns on (triangle with ! in the middle), this should occur
before 15 seconds elapses.
d. Release the go button.
Your response will be highly appreciated.
Thank you for using Fixya!
Jan 04, 2011 | Computers & Internet
Whenever i try to print a pdf file longer than one page from adobe reader, my e-studio4511 will only print the first page, followed by a second blank page, and then a final page with the following error...
Send the font information for each page in the PDF file when you print.
For Adobe Acrobat Professional 9:
1. Choose File > Print.
2. Click on Advanced.
3. Choose Postcript Options.
4. Under Font and Resource Policy, select Send for Each Page.
In Adobe Reader 9: try this 1
3. Under Font and Resource Policy, select Send for Each Page.
may or may not work try it
Hopefully this will be helpful to you all
Nov 20, 2010 | Toshiba e-STUDIO 4511 Printer
When I print an 8 1/2 x 11 paper with certain fonts, colors, etc. I get an error code: ioerror Offending Command: status Stack: (BFUTCI+Univers-Condensed*1 Now if I print the same font, colors, etc. on an...
Try reducing the image on the 8.5 x 11.
The larger sheets are most likely allowing more information instead of "clipping it".
to resolve the issue repair or remove the font in question.
Jan 06, 2010 | Konica Minolta bizhub C450P Laser Printer
Print error page Bizhub C351
Google the full error.
this sounds like a font realted postscript error.
Jan 05, 2010 | Konica Minolta bizhub C351 All-In-One...
I am trying to print to adobe to convert to a pdf file. I am receiving an error stating Prodcut name: distiller Warning: Script-cannot be embedded beacuse of font file error. Error: undefined; offending...
You probably have Adobe reader which will allow you to read an Adobe document but not write a pdf file. For that you have to buy Adobe Acrobat. There are, however, free packages that will convert a file into pdf format. Try googling for "convert a file into pdf" or something similar.
Nov 24, 2008 | Computers & Internet
OKI C9300 Led Printer Logo
513 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
