Question about Craftsman Garden
I have a Craftsman 16hp Lawn Tractor. Problem, battery will not stay charged up when the mower is being used, even with a new battery. If you shut the mower off, and then try to re-start it, you are in trouble
  • 2,841 Answers
Your mower is not charging the battery. Something is wrong with the charging system. It more than likely uses a magneto type charging system. It is mounted under the flywheel. Unless you are adept at repairing these take it to a pro.
Posted on Apr 04, 2011
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 11 Answers
Response to the above answer> magneto charging system? really dude? magneto is the armature for the timing.. get it right or dont post here.. stator \ alternator is the right answer and yes it is located underneath the flywheel. most higher HP Briggs are what they call direct circuit charging systems and no regulators.
if you replace the Battery and it does not charge you need to test the stator or as I call it the alternator with a multi tester.the stator is located underneath the fan\flywheel and requires a fly wheel puller to pull off fly wheel and to bolt new stator underneath.but i would test it with a multi meter first.stators are about 50 new.you will see the red wire for stator coming out of engine about midway down unplug it and test it. note there is a diaode in the one lead that could be the issue but most times its copper wire broke on stator its self.
Set the multi-tester dial to AC VOLTS or DC AMPS.
Insert the black multi-tester lead into the tester's COM receptacle.
  • For AC VOLTS, connect the other end to ground, such as an engine bolt or cylinder fin.
  • For DC AMPS, connect the other end to the battery's positive terminal. (NOTE: The battery must be grounded to the equipment frame of the engine block to create a complete circuit.)
  • Insert the red lead on the multi-tester into the tester's receptacle (labeled AC VOLTS or AMPS).
  • Connect the red lead to the appropriate stator output wire.
  • go to this link on the briggs site for youre engine so you know what volts or amps are good. also note that some lower HP briggs engines have a regulator that they threw in the mix and I believe any engine below 16hp does have a regulator so it would be need to be tested as well.any engine over 16hp has a battery and stator and no regulator.
  • http://www.briggsandstratton.com/us/en/support/faqs/charging-system-alternator-test
    Posted on Jun 29, 2015
    How do I put drive belt back on craftsman 16hp lawn tractor?
    Remove battery and battery box. Unhook idler spring, the end is in the frame right front corner of engine comp. Replace belt like page 24 in your owner's manual.
    Jul 08, 2012 | Garden
    My garden tractor is not holding it's battery charge. I replaced the battery, but still doesn't hold a charge after I use it.
    If you replaced the battery with a new one and it is not holding a charge, then your charging system is not putting out enough power to run the mower AND recharge the battery. So you need to figure what is wrong in the charging system.
    Mar 26, 2011 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
    My Craftsman 4000 dyt lawn tractor's electric clutch went out and when it locked up it choked the motor down....now everything is dead, there is not and "juice" going to the starter, the headlights will...
    Sounds like the machine stopped charging,usually caused by a faulty rectifier/regulator or a bad connection to it.Try either charging the battery for an hour or so or you can put booster cables from your car to it and then if everything is ok you need to fix the charging system,or replace the battery[once they are sulphated they will not take a charge even if the charge system works].Check the connections to the battery as well and if you can test the tractor when it is running and see if the voltage stays between 14 and 15 volts.Let me know how you make out.
    Jun 12, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
    Stalling Craftsman LT 1000 Lawn Tractor
    I have a Craftsman 21 HP Twin riding lawn mower and have replaced both spark plugs, filter and battery. New gas. New Oil....still will not start?? HELP!!!
    Oct 11, 2009 | Craftsman Garden
    I have a craftsman electric key start lawn mower. I used the key start twice and have charged it after each mowing, but now the key start won't turn it over.
    the battery probably got over charge & shorted the cells the tractor should charge the battery as it runs if it was equiped with electric start the battery charger more than likely over charged it killing the battery
    Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
    Craftsmans31c707 16hp riding lawn hard to turn over wont start
    i had the same problem ,replaced the battery,and starter
    turned out the muffler was plugged with a wasp nest,also ended up re-adj the valves later on!!!
    Mar 17, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
    Garden Logo
    362 people viewed this question
    Top Craftsman Garden Experts
    Wade Mobley
    Wade Mobley
    Dean Gruber
    Roland W VanLue
    Roland W VanLue
    Are you a Craftsman Garden Expert? Answer questions, earn points and help others
