Question about Kenmore Dryers
Kenmore 90series dryer,what do l do to unpause my dryer
3 Suggested Answers
SOURCE: kenmore 90 series
i have no solution, my dryer won't start but the buttons light up and it makes all the sounds but won't start? It's gas by the way if you have a solution pleasee-mail me back, or if you know someone who can fix it. HELP!!!!!!!!!!!! sheri
Posted on Dec 01, 2008
hunter19_46m
  • 7482 Answers
SOURCE: kenmore 90series dryer,will tumble but
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Oct 14, 2010
I have a Kenmore 90series washing machine model 110.20902990. I removed the upper agitator as well as the bolts, on every video I've seen I should be able to lift the bottom agitator but I can not.
this most likely has a spline inside it , after years of washing id say rust is on shaft making for some tightness in side it , id try to use a heat (air) gun to soften up plastic to try and move it , don't forget to wear thick gloves as it will be hot on the hands
Sep 30, 2015 | Kenmore Washing Machines
I'll re-ask "pauls2" question... By
On that model the front panel is whats removed to access all internal parts,the rear panel does not come off. This vidoe will show ya how to remove the front panel
http://www.youtube.com/watch?v=2bVoelV7M7Y&feature=results_video&playnext=1&list=PL440E0E523449284C
GENE
Sep 23, 2011 | Kenmore 65924 Electric Dryer
I have a kenmore 90series dryer model # 110.60927990. Worked fine one day next day pushed start here it engage nothing happens. Tried it again same outcome like trying to start a car u hear the starter...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 15, 2011 | Kenmore Dryers
Dryer drum rotates with on heat produced maytag 90series electric
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 24, 2011 | Kenmore 63942 Dryer
I have a kenmore 90series the problem is that when it's done washing it want drain out all the water after two spin cycles
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Dec 27, 2010 | Washing Machines
Cant change the belt on my kenmore 90series washer
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Next, see the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=144&osCsid=c677615061d7ce3e6fa5ba64edbc663d
That description should help.
Mar 27, 2010 | Kenmore Washing Machines
I have a Kenmore automatic heay duty top load washer that when is in the wash cycle I believe what is the agitator only sort of jerks back and forth slowly instead of turning. It is a 90series and the...
see if you can lift agitator off and see if something is jammed under it ....like a sock or something..most unscrew at top and just lift off if this is not your problem it may be the transmission. how old is the washer if old probably cheaper to replace then to have transmission repaired(if it is transmission)
Jan 07, 2010 | Washing Machines
Will not switch from rinse to spin mode
Unplug the washer for 10 min to reboot the circiut board. Then select a single cycle. Selecting too many cycles in a short period of time can overwelm the little brain in the board.
Apr 30, 2009 | Washing Machines
Kenmore 90 series
Apr 09, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
48 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
