Question about Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
Drier is stuck on manual quick dry, selection knob is on Normal(auto)dry.
    Problem Solver:
  • 18 Answers
Switch is stuck behind panel
Posted on Apr 05, 2011
Samsung dryer only dries on timed dry cycle. And where is the light bulb in the dryer??
sounds like the timer is sticking in some cycles and works only in timed dry? as the points in other cycles are seized and stuck close? as for the bulb should be along the back wall of tub or near door
Feb 13, 2015 | Samsung Dryers
Can't switch between different dryer selections
is the knob broken?pull off the knob and see if it's cracked.
Jan 13, 2014 | Dryers
Drier not hot enough when i set temperature to high position
Replace the high limit thermostat located on the top of the heating element housing. Here is the part to order.
Nov 18, 2012 | Frigidaire GLER104FSS Gallery Series 27...
My drier gets warm but not hot???whats wrong....I check exhaust system cleaned it and vent system too. power is normal I put it on express drying too and warm not hot?
Most electric driers have two heater coils, inside that provide heat to dry the cloths. Wires like in a light bulb only bigger. I suspect one of these coils is burnt out and thats why it is only getting warm not hot. Also be sure to remove the hose from the back of the drier and check for a restriction there.
Oct 08, 2010 | Kenmore 63942 Dryer
Automatic Dry Function Has Stopped Working
There is a humidity sensor which acts as an auto cutoff switch in most driers, as your load auto dries , it senses the change in humidty and kicks the power off. It is often shaped like a flying saucer with wire terminals on the wings. That is likely your culprit, generally located close to the element. Based on your description, I would start there. Also test a load on timed dry, but it sounds like that's your problem. Remember to unplug before looking under the hood. Post back if you need further info
Sep 20, 2009 | Dryers
Blinking AD
AD is auto dry you may need to clean the sensor or you may have a fauilty one ...Auto Dry Loads dried using the Towels, Heavy Duty, Normal, Perm Press, and Delicates cycles will dry automatically at the selected temperature to the desired dryness level. The dryer uses sensing bars to sense the moisture level of the load as it tumbles through heated air. Auto Dry cycles save time and energy and protect fabrics. The estimated drying time will be displayed for about 5 minutes, then the outside of the display will light up in a circular track to indicate the drying time is automatically being determined by the sensors. When the load has reached the selected dryness level, it will continue to tumble, unheated, during a Cool Down period. This helps reduce wrinkling and makes items easier to handle during unloading. The estimated Cool Down time will be displayed. Drying time varies depending on size and dampness of load and fabric type. If the load is too small or almost dry, the sensing bars may not detect enough moisture to continue the cycle and the cycle may end after a few minutes. Select a Timed Dry setting to dry such loads. Room temperature and humidity, type of installation and electrical voltage or gas pressure can also affect drying time. For cycle selection turn the knob on the front of the dryer control panel. The light will illuminate next to the cycle selected. The following is a brief description for what cycles should be chosen for certain items and materials to be dried.
Sep 18, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Electric drier takes 2 to 3 cycles to dry one normal size load
Have you tried cleaning the actual inside of the drier?
When you use drier sheets the wax on the sheets melts onto your clothes and makes them soft, but the wax often gets stuck in the holes of the drier making it incapable of drying the clothes in one load. Try scrubbing the inside of your drier with some hot water.
Apr 13, 2009 | Roper REX3614KW Electric Dryer
Diplomat washer drier
all you have to do is:
select half load
set drier timer to required time. set main timer to dry program
i suspect you are not pressing half load button - this is essential
Jul 20, 2008 | Washing Machines
Re washing and drying
Hours? It sounds like your machine has a problem.. Have you tried clearing the filter on the outlet after the drainage pump? The Indesit only has a 1200 spin speed so it's not the most efficient drier anyway (rated B for spin efficiency).
Personally I dislike Indesit as they release some models which do not permit replacement of the bearings because the innner and outer drum assembly are crimped/pressed together during manufacture. Instead of replacing bearings and seals (At most about £35.00) you would need top buy a complete drum assembly at about £125.00, and throw away a large lump f stainless steel. Presumably Indesit want you to throw the entire machine away, and to buy a new one. Not a brilliant idea in my opinion, as it is unlikely that a frustrated ex Indesit owner will but an Indesit as a replacement, and that sort of wastage (bearings last around three years in regular family use) makes a complete nonsense of energy efficiency ratings. The cost of manufacture and disposal over a three year usage period will have a massive carbon impact in comparison to the energy efficiency savings even of the most efficient of machines.
The planet can't afford to buy cheap machines and then thropw them away.
Apr 28, 2008 | Indesit W 123 Front Load Washer
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
74 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
