Question about GE Ovens
I have a GE oven (JKP20B0F6BB) it beeps on and off. I just replaced the main control board but it still does it
4 Suggested Answers
textonor
  • 130 Answers
SOURCE: Oven mystery....need the best GURU or Wiz....CHALLENGE! Please help!!!
Monogramman you have described where your issue is. When you dismount the front panel you are moving the wires. If I was looking at your unit and you told me that it worked with the panel removed, I would look at the wiring between the front panel and the relay board for a loose connection. You should be able to pull the connectors ( remember to shut off the power for safety) and put a flash light on the backside of the connector. Look thru the front an you should see very little light. If you see a lot of light there is your loose connection. Or if you are careful, you can wiggle the connectors until you get to one that is causing the clicking. Hope this helps. I doubt if it is the oven thermistor as the oven heats while the front panel is dropped down.
Posted on Jan 06, 2008
localwonder
  • 6784 Answers
SOURCE: F7 error on GE eledtric oven JKP20
This is a shorted touch pad. replace the touch pad or, if the touch pad is incorporated within the control board, replace the entire oven control board.
Posted on Jun 25, 2009
  • 973 Answers
SOURCE: The LED display on my GE JTP56 electric wall oven
It sounds like a defective Control Board, return it or exchange it for another one.
Posted on Jun 13, 2010
When buttons are pushed, no beeping. even when timer is set to go off, no signal that the time has expired
If all other functions are working and you just lost the beep sound then you have to make this choice. The beeper is actually mounted on the main control board. If it has gone bad--the only way to fix it is to replace the complete main control board which is an expensive part. One thing to check in your owners manual is if your control has a way to change the sound level of the beeper. If yes--it may have accidentally got shut off if it has that type settings.
Jun 16, 2015 | GE JTP75 Electric Double Oven
F1 code GE profile convection self clean wall oven (95?) oven beeps F1 code oven works when it is on bake etc. when touch key are pressed it goes off but starts to beep again
Hi
F1 Error indicates a bad control board and the control board (electronic control) should be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
Sep 19, 2011 | Ovens
GE Oven Model # JRS04B0W3BB is showing an F7 code, how do I fix it? I can stop the beeping noise by pushing the stop button, but the beeping returns after about 30 minutes. I have pulled the breaker for...
Hi
Daniel
Aug 06, 2011 | GE 24" Built-In Single Electric Wall Oven
Model JRP15WOW1WW GE Oven beeping and showing code F-7. Help
Hi
F7 Error indicates a bad control board and the control board (electronic control) should be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
Aug 04, 2011 | GE JKP15 Electric Single Oven
Ge built in 1993 oven shows an F-1 sign and beeps
Hello there:
any time you recieve the f-1 and sometimes a f-o error with the beeping this is from the electronic range controle board or erc for short and this means that that part has fgailed and needs to be replaced if you go to repair clinic.com you can look up you oven model number and get parts from there or if you have a appliance repair center in your home town give them a call and tell them the ovens model number and tell them you need a erc or electronic range controle board ok?
Hope this helps
Best regards Michael
Aug 16, 2010 | GE Ovens
My double oven keeps beeping and F-2 keeps appearing on the display What does this mean
HI. This error code will occur when the control board senses an oven temperature above 915F-935F
Once this type of temperatures occur, this will generally weld the relay contacts on the main board. This will damage the board, and it will require you to have it replaced, asap. If these temperatures never reached the sated thresholds, i would advise to Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace the sensor if found to be defective. Check door lock switches for damage, as well.
In most cases, this will be a failed control board. To confirm, simply preform a resistance test on the sensor. The normal ohm readings should be 1100 ohms at room temperature.
Jan 02, 2010 | GE JKP28 Electric Double Oven
The read on display is f2 and beeping
In most cases, this will be a failed control board. To confirm, simply preform a resistance test on the sensor. The normal ohm readings should be 1100 ohms at room temperature..
Jan 02, 2010 | GE JKP27 Electric Double Oven
Beeping with f7 display
HI this is a touch pad or key pad issue. In most models, the touch or key pad are integrated. In this case, you will need to replace the entire control board or EOC(clock).
Now, if the touch or key pad is separate from the main control board, and linked, via linking ribbon, i would advise to use the procedure below to isolate the problem area.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Oct 03, 2009 | GE Ovens
Jun 25, 2009 | GE JTP20 Electric Single Oven
Ovens Logo
164 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
