I have a pioneer htp-200 which i just brought ive connected it directly to my panasonic tv using hdmi and optil but i dont get any sound out of it i triple checked everything but i must be missing something somewhere can you help?
  • 961 Answers
Don't know how many componenets you are trying yo run but, anything requiring video, Satellite receiver, dvd player, etc., should be hooked directly to tv using HDMI, component. or composite cables. HDMI garries audio and sound but your reciever doesn't care about the video and may not transfer it very well. Unless you are trying to jump HDMI jacks because you only have one HDMI in on your set. YOU shouldn't need any HDMI cables runnng to your receiver. All you should need is a digital optical cable from TV ouyput to receiver input.
Posted on Apr 04, 2011
How to connect a panasonic tcp50gt25 tv audio out (opictal) to a pioneer amp.with opitcal. i connect the cable but no sound,any idea for setting,i did the setting for optical on the amp but still no sound
What is the source? if you are using an HDMI connection from an HD source you should have digital audio. also, if you are connecting digital cable directly to the TV it will send digital audio out as well. check the optical cable at the amp end to see if it is working. it should glow red at the tip if it is.
there are digital input mode settings as well on some receivers. if it is set to DTS it won't work on PCM audio. if it is set to auto Digital it should work on any standard. check the PCM or DTS options in both the TV, and receiver if those settings are there.
Mar 12, 2011 | Panasonic VIERA TC-P54Z1 54 in. Plasma TV
Pioneer works with cable box but not with new blue
HDMI version is 1.3 in your receiver.The current version is 1.3b. I would suggest calling Pioneer cust assistance and see if there is a firmware update. Your unit has a 2 year parts & labor warranty. Their # is 1-800-421-1404 It sounds like a CODEC issue. Hope this helps
Dec 25, 2009 | Pioneer VSX-92TXH Receiver
Sound no picture, picture;no sound
a panasonic tv will shut down after a short time with no video input. it sounds like the setup menu in the receiver has defaulted and needs to be setup again to coordinate the audio and video signals. ive seen many yamaha menus default. dont let geeks in your house.
Nov 03, 2009 | Yamaha RX-V663 Receiver
Cant get my viera linked panasonic to play through surround sound
I had the same problem, so i contacted panasonic, I am including the email they sent me.
For connections of audio, so that you can hear all tv audio through the
surround system, connect either an optical audio cable or red & white
analog audio cables from the tv to the home theater. If you are using
optical audio, there is a plug on back of tv labeled for digital audio
output and an input on the surround sound system. If you plan on using
analog red and white, use the PROG OUT red and white output jacks on the
back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or
Component cables. HDMI is the cable that will provided 1080p signal (the
best HD signal), but if the source does not output 1080p, then your tv
will not display 1080p. Most cable boxes output at 1080i or 720p when on
HD stations. This signal still provides great picture quality, but HDMI is
not needed to get these HD signals. You can use component cables for your
cable box and the DVD player output to the tv for video. HDMI might give
you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the
tv (component or hdmi). Also from the home theater system to the tv using
hdmi or the video cables from component (red, blue, & green cables).
We hope this information is helpful to you.
Thank You,
Panasonic Consumer
Dec 16, 2008 | Panasonic Home Theater System System
How to connect BLU-RAY DVD player to Pioneer Plasma TV via HDMI
The best possible solution to your problem is :
Connect your blu ray player directly to the HDMI input of you Plasma and watch HD video....
and connect the 5.1/7.1 sound thru the optical or the coaxial link directly to your AVR 3805.
You will not loose anything on the Blu-Ray.
The sound is best processsed by the AVR3805, while the video, which is the real upgrade (BluRay) in terms of resolution of picture would be processed by your plasma.
Connect and Enjoy
Dec 16, 2008 | Denon AVR-3805 Receiver
Component to HDMI
why dont u connect the xbox directly to the tv via HDMI cable? the output will be fantastic.The component cables just cannot give a better resolution than HDMI.
As for connections,i am not in favour of component and HDMI together.
May 18, 2008 | Pioneer VSX-92TXH Receiver
42" pansonic plasma hdmi problem
if I understand your question properly.. its because your direct tv output doesnt broadcast in high def so its giving you the standard tv definition inputs which are RGB or Component.so you will lose picture quality cos its running at fewer lines or pixels. hope this helps
Mar 12, 2008 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
Set up help!!
Firstly connect your home theatre outpu HDMI to HDMI input1 on the TV. Then connect the PS£ HDMI to the other HDMI input on the TV. Now connected the optical cable from the PS3 to the optical input of the home cinema system. Your should now have surround sound from the PS3 and DVD.
Sep 11, 2007 | Samsung HTP-1200 System
212 people viewed this question
 Grubhead
Grubhead
