Question about One For All URC6131n Remote Control
How to set it to my dvd and my tv - One For All URC6131n Remote Control
    Problem Solver:
  • 14 Answers
Look in the manual. Oh, you don't have one? Try google.com
Posted on Sep 14, 2011
Error: incompatible TV settings
You need to pull out the manual. The settings are related to the INPUT to the TV. You must select the DVD-CD settings from the Menu and switch from the TV setting to DVD.
Feb 26, 2014 | Sharp Televison & Video
When I play a DVD, it is in black and White. When I play the tv it is in colour. Can't get the DVD to play in colour!
You have one of several possible problems, ranging from best case scenario to worst case scenario:
A DVD video that is supposed to be black and white - try a different disc.
Some setting on the DVD player is set to monotone - check manufacturer's instructions
A bad set of cables connecting the dvd player to the tv - test a known good set of cables
A bad output on the DVD player - test DVD player with a different TV.
A bad input on the TV - try another input if possible, test TV with a known working video input.
Sep 17, 2011 | Computers & Internet
Hitachi DV-PF 2U dvd player works fine when hooked directy to TV (channel 3) but won't work when connected through the new COX digital cable box. TV is set to channel 4, dvd player turned on, disc...
If the cable box needs to be set to 4, the TV will need to be set to 4 as well as the dvd player. The hookup should be cable box to dvd player to the TV for your system to work. Let me know if you have any other questions. Thanks.
Dec 30, 2010 | Hitachi DVD / VCR Combo
TRYING TO INSTALL DIGITAL SET-TOP BOX WITH DVD AND TV
Hi ccraigo
To answer your question;
Your motorola will connect directly(not through the dvd) to the tv set into one of the input ,(preferably using hdmi or component cables for hd) and the dvd will use a different input,
All you have to do then is switch between which one you want to watch.
Hope this help Cheers
Apr 20, 2010 | Pioneer Televison & Video
I played a dvd and now can't get the tv to come on. How do you switch between dvd and television? This is a Westinghouse DVD LCD combo television.
on the remote there are various button at the top to control the functions. these include tv dvd cable etc.
When the remote is set on tv all the functions on the tv work together with the functions of dvd such as play stop etc.all except power channel up channel down etc.
THE REMOTE MAY JUST BE SET TO DVD JUST PRESS TV AT THE TOP OF THE REMOTE OR YOU MAY NEED TO SET IT BACK AND THE PROBLEM IS FIXED!!! THE USER MANUAL SHOWS YOU HOW TO SET IT.
Feb 27, 2010 | Televison & Video
Sony rdr vx410 dvd player playing some dvds in black and white
  • DVD's are standard definition video sources. Number of lines output is 576 lines, whereas your HD TV set has 720 or 1080 lines. This difference may result in a poorer image. However some DVD players are able to “upscale” picture to obtain a very good picture. Check if your DVD player has the following connectors: YUV, DVI or HDMI. For more information, refer to the instruction manual of your DVD player.
  • Some HDMI or DVI featured DVD players also have an internal processor that can upscale pictures from a DVD to 720 or 1080 lines to provide an excellent picture from a standard definition disc to your HD TV set. Those settings are available from the setup menu of your DVD player. Please refer to the instruction manual of your DVD player.
  • If your DVD player does not have those connectors and only has a SCART connector, or S-VIDEO, or composite, there is not much to do to improve the picture quality. Just make sure that you are not using the cheapest cables and that the picture settings of your TV set are correctly adjusted.
  • Some high end TV sets have a picture improvement engine that can soften a noisy image. Make sure that it is activated from the setup menu of your TV set. Please refer to the instruction manual of your TV set.
  • If people and objects have weird white outlines around them. This may suggest that your TV sharpness is set too high. Make the correct sharpness adjustments from the setup menu of your TV set.
  • Make sure you use good quality cables and that your cables are not too long (less than 5 meters long).
Jun 15, 2009 | Sony RDR-VX420 DVD Recorder/VCR
Recording TV programs on DVD Recorder
if you are using a cable box / converter dvd-r and tv must be on ch 3.............
okay you dont have a cable box the tv is set to ch 3....the dvd-r, set up, initial settings and change cable to air...........then channel setting auto (scans all channels except HBO)...now you able to look at a dvd, record your show (s)
feel free to rate if helpful
Mar 02, 2009 | Toshiba DR410 DVD Recorder
Setting up DVD/VCR
Depends how you have connected to the TV.
You will need to set your TV to the relevant socket you have connected the DVD/VCR into.
S-Video, Component , composite etc
These will be EXT 1 , EXT 2 or AV 1, AV 2 etc.
Feb 18, 2008 | Philips Magnavox DVD/VCR Dual Player
DVD/TV Problem with TX-LR552
Did you change your TV input to DVD as well?
Jul 26, 2017 | Onkyo TX-LR552 6.1 Channels Receiver
One For All URC6131n Remote Control Logo
13 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
