Question about Dell Inspiron 560S Desktop Computer (Intel Celeron 450 640GB4GB) (DDPHBA51)
How to install cd burner in tower dell 560 - Dell Inspiron 560S Desktop Computer (Intel Celeron 450 640GB4GB) (DDPHBA51)
  • Dell Master
  • 32,281 Answers
For instruction on installing a CD or DVD burner in your desktop computer go to this WEB site.
http://www.helpwithpcs.com/upgrading/installing_cd_recorder.htm
Posted on Apr 04, 2011
Dell OptiPlex 780 with Windows 7 does not play my cd's or dvd's and is missing from device manager
Sounds like a problem of non-detection by the system. If the drive is missing from My Computer then it definitely is a non-detection issue. Try using this file (it's an exe when unzipped) and only required double-clicking.
http://www.geekstogo.com/forum/files/file/8-cdgone/
Mar 26, 2014 | Dell OptiPlex 780/ 780 Mini-Tower Desktops...
Dell inspiron 560 cd burner not working
Occasionally I find a cd (or DVD) reader that acts up. Maybe it will read some cds and not others. They are pretty cheap, I suggest getting a new one. If you are not comfortable opening up your machine and making changes, buy an external drive. If you do want to open it up: not only unplug, but remove cord from power supply. Open the door by removing the screws (sometimes thumbscrews) on the back that hold the side on. Take the side door off. The cd unit will be held in by 2 screws. Remove them, they will require a small Phillips screwdriver. Try to slide the unit out the front. If it will not move with moderate force, then you will have to remove the other side and remove 2 more screws, but this is infrequent. There will be 2 cables attached to the unit, remove them and the cd unit should slide out the front. Once you have it out, you can go to your favorite computer store and get a new one like it - but I suggest getting a DVD to replace it, as most software nowadays comes on DVD and a cd reader will not read a DVD. Do the reverse to install - but be sure first to set it to "master" or "slave" (to match the old one) if it is an IDE type.
Oct 03, 2017 | Dell Computers & Internet
How to burn a CD using the desktop DELL xps 8300
If you have a CD-ROM burner installed into the tower (The hardware and drivers in place) You can usually burn an audio or video CD using iTunes, or download and try out Nero in order to burn data CD's
Aug 15, 2011 | Dell Dimension 8300 PC Desktop
I would like to have/purchase a step by step instruction manual for the operation of my Dell Inspiron 560 Slim Tower computer. A manual that explains "To do (this) click on (whatever) tab on the...
This sounds more like you're looking for a general "How to Use Windows" guide, rather than something specific to the Dell 560. If you recently purchased this computer, it should have come with Windows 7 pre-installed on it. In this case, I would recommend the "Windows 7 For Dummies" guidebook, which can be purchased either at a local bookstore of your choice (ISBN #0470497432), or through an online retailer like Amazon:
Amazon.com: Windows 7 For Dummies
Good luck, and enjoy your computer; learning the ins-and-outs of a home PC can be a fun and educational experience.
Mar 08, 2011 | Dell Computers & Internet
Hi, The following is the spec. What is the best graphics card upgrade options without upgrading PSU? Thanks. 1 03FCY Base,Mini Tower,Configure To Order,INSP 560 $358.67 1 07GHK...
HERE is the direct link from Dell that will tell you what graphic card will go into your system. Since there are many factors involving graphics card updates this is the best place to start.
Jan 06, 2011 | Dell Inspiron 560 PC Desktop
Pls help me... my dvd rom have coins inside.i didnt know.i put cd and then it cant open and i cant take out the cd aswell. my laptop is dell studio 1435... pls help me...
Look at the cover near the cd slot - it should still have the hole. You mention coins inside - kids? It seems probable that the cd was installed with power on, but you will still have the hole - it's small so that a paper clip will just fit into it. Since you have the coins probably still in there, I would disconnect power, remove the cover and pull the cd driver from the tower case. More than likely the cd and cdrom drive will be damaged beyond repair, but if you remove the drive from the computer you'd be able to shake the coins out of it and also to be sure the coins aren't going to short out *********** board. If you can do that then you might as well reinstall everything and put it back together, then power it up to check it. Who knows you might get lucky...
Sep 23, 2010 | Dell (JP-03G005-26401-16R-H324)...
Hi, Can I replace my CD writer in Dell GX270 with
Directly no, since all BR units use a SATA connection that your pc lacks. But you can buy a cheap PCI SATA card and plug th BR into it.
May 29, 2010 | Computers & Internet
I am having trouble adding a memorex external hard drive/ cd burner unit to my studio slim tower. i plugged it into the front connection. it doesn't registar. what am i doing wrong?
1st make sure the USB port works (try plugging it into a differant USB port, if that still gets no results try installing the driver again that may make all the difference in the world atleast it won't hurt to try
Mar 30, 2010 | Dell Studio Slim-Tower Desktop Computer
Lg tower pc
you need to go into bios at startup, press F2 Or Delete Or Esc on bootup. When you get into the System Bios. Change the boot device priority from HDD To CD/DVD To boot first.
Save/exit And when you reboot ( with windows XP in the Drive ) you,ll get options to format or re-install.
Mike @ Compurepair.
Mar 29, 2008 | LG GMA-4082N DVD±RW Burner
Dell Inspiron 560S Desktop Computer (Intel Celeron 450 640GB4GB) (DDPHBA51) Logo
mukhtar21 shaikh
mukhtar21 shaikh
