Question about Roper Dryers
MOTOR HUMS BUT WONT TURN ON - Roper Dryers
  • 417 Answers
sounds like a sock got sucked into the fan. its going to have to come apart. study the chassis of the dryer. usually you start at the back of the control panel and work your way to the top undo the belt at the access cover st the back. get the front of the machine off. check the back middle of the drum for screws then lift out the drum. clean all lint while its apart. have the vac handy.. unplug it first!
jm
Posted on Apr 04, 2011
    Top Expert:
  • Roper Master
  • 76,649 Answers
This almost always caused by a burnt out dryer motor, the winding's in the motor are shorted or an open circuit. I advise you to replace the motor. While you are in there clean all the duck and debris out of the dryer cabinet, the duct contributes to early motor failure..
  • yadayada
    yadayada Apr 04, 2011
    The last few words say duct, it should read dust. and yes check for anything that is keeping the motor from turning but have never seen a sock in one. Clean it all up and see if the motor starts working again. If the motor still is humming, replace it.
Dryer motor hums but doesn't spin
Sounds like the motor has gone bad.
May 10, 2015 | Amana Dryers
Motor is running but won't agitate and belt is on ? I can hear the motor humming and it will fill up but it wont agitate.
Check drum turning by hand ok not sticky sounds like could be motor if it hums and no turn..
Oct 18, 2014 | Hotpoint Washing Machines
Fills with water and then stops makes a humming sound ,then stops all togther wont do aything spin or drain
sounds like an induction motor. start winding or start capacitor not starting to turn motor, This will make motor hum. Do not know m/c in qestion. Switch on and as soon as pos try to turn motor careful not to use hands or anything that can injure yourself with if it starts to spin.
Oct 29, 2012 | Whirlpool WTW5521S Top Load Washer
When you turn on the dryer you can hear the motor hum but the drum wont turn ...i checked the belt and it is not broken
When you checked the belt, did you check to see if the motor would turn by hand, if not the motor is locked down and that's why you hear the hum noise, it still has power and still trying to rotate, but from being locked down it has no option but to strain and hum. If that's not it, check around the drum for a sock or small piece of clothing, it can wedge between drum and dryer frame and cause the tub not to rotate just like if the motor were locked down.
Jan 06, 2010 | Washing Machines
Press the start button on dryer, it hums but wont turn. With 2 people pressed the start button again, held the door switch, reached in turned the drum, it hummed stopped humming then no more nothing....
Sounds like a weak motor. You'll have to get a new motor installed. They are fairly inexpensive and easy to install yourself on that type of machine if you are handy. Motor is located in the bottom right of the machine, attached to the drum belt through a small pulley underneath the drum next to the motor.
Dec 27, 2009 | Dryers
Dryer wont tumble
i think the belt is slipping bad on your dryer,,
what puzzels me is you say you can here the motor hum? is it a hum? or a buzz?? if its a buzz then its more likley to be the motor as its past its best and it needs if it needs a new motor as well, it would work out cheeper to buy a new tumble dryer
Nov 16, 2009 | Dryers
Craftsman radial saw runs (hums) but wont turn over
The motor capacitor is dead. Replace it and it'll be right as rain!
Regards, --W/D--
Aug 05, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
Washer wont agitate or spin motor hums i canturn
if the moter hums when working but does not move time for a new moter the torque side of the moter has gone look on ebay or espares
Jul 29, 2009 | Washing Machines
Pump just hums but wont start
Sounds like its frozen and causing a very heavy load on your circuit. If the motor gets hot within seconds, its shot and needs replacing. Have you attempted to turn the motor over by hand ?
Jun 22, 2009 | AO Smith SQ1202 Pool Pump Motor
Dryers Logo
59 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
