Question about Philips Magnavox 51MP392H Rear Projection Television
Red Picture on My Rear Projection TV Phillips
We recently moved and when we hooked our Philips Rear Projection television, we cant get the picture to come out right. It is all red. Even when we do the converge thing, it just looks really red with a bright white in the center. What to do?
  • jackiel351 Aug 12, 2008
    We just moved out 51" projector TV and it is very red, green and blue no other colors, and we can't find the remote to the tv can we get a replacement remote for this tv, it is older the model # is 6p5450 w102.
    Thanks, Jackie
    Genius:
  • 1,139 Answers
Hello traci061882,
This might be an indication of defective CRTs (Cathode Ray Tubes). I would first check to see if the Green and Blue CRTs were functioning or have other issues such as coolant leakage (do visual inspection). Anything other then this will require you to contact a qualified TV repair Technician to troubleshoot the problem. I would suggest for starters that the technician perform a test on the CRTs with a CRT tester, This is the best way to do this it will cut to the possible cause right away, if the CRTs can be rejuvenated, at least you will have about two to three more years of use out of the TV before the CRTs are completely gone. However if the tubes are not the problem then the technician will have to troubleshoot the circuitry the connects to the CRTs.
I hope this helps,
Thank you,
Shuttle83
Posted on Aug 10, 2008
SOURCE:
I cant line the red and green crosses up left and right but i can move them up and down. I have two pics in diferent colors
The tv have a convergence problems,it is dead.Tv have colors lines like R,G,B mis alignments,have colors pictures shadows or 3D pictures look alike?Yes,than the tv convergence board it is dead.The tv convergence board must require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
May 09, 2011 | Philips Magnavox 51MP392H Rear Projection...
Picture is too red
sounds like you may have a bulb out, you can pull the screen off to access it but you have to very careful with the screens or you will damage them, only clean with isopropyl alcohol and of good quality, there will be three bulbs in there, red blue green, their location and direction is very important, so dont move them, if they all work clean then put the screens back on, and see if you can adjust the direction from the menu
Jul 03, 2010 | Philips Magnavox 9P6034C 60" Rear...
My television is actually a magnavox 51mp6100d/37 51" rear projection and im having a problem with the picture! it is really bright in the middle and then going towards the outsides it gets darker and i...
YOU HAVE ALGAE IN THE BLUE AND GREEN TUBES IT DOES NOT GROW IN THE RED TUBE TAKE OFF THE FRONT COVER AND LOOK IN THE TUBES COMPAIRE IT WITH THE RED WHEN IT IS ON WITH A PICTURE WILL NOT HEART YOU TO LOOK IN THEM WITH IT ON DONT TRY TO FIX IT YOUR SELF
Feb 09, 2010 | Philips Magnavox 51MP392H Rear Projection...
No picture No sound, chirping from a board
Is the FBT,the high voltage transformer.The big black block of plastic with a red wire solder to a board.MIght even have to change transistors deflection board also.
Nov 21, 2009 | Philips 60PP9352 60" Rear Projection...
Cant get icns lined up can adjust side to side but
if this is a rear projection crt type set go into the customer menu and select CONVERGENCE--if either blue or red will not move up and down--you have a bad convergence IC---most sets use two of them.
Aug 07, 2009 | Philips Magnavox 51MP392H Rear Projection...
The colors on my tv have separated, red, blue and green.
This a convergence problem. You maybe able to correct "electronically" by using the remote control and menu setup options. If you cant get where you need to go via remote control. A profession tweak may be needed inside the tv to phyiscally align the colors. good luck
Jun 29, 2009 | Philips Magnavox 51MP392H Rear Projection...
Too much green in picture cant fix using tint
Check to see if you have the colored leads comming from the CATV box switched or not hooked up.
You may just have no red. you also may have switched the red video and red audio leads.
Mar 22, 2009 | Mitsubishi WD-52327 52" Rear Projection...
The color is bad
my rear projection Phillips TV Picture has a green tint.
Jan 02, 2009 | Philips Magnavox 9P6034C 60" Rear...
Red and green fuzzy waves across the screen
my screen just became distorted (red picturer to the upper right & green picture to the bottem left ? can you help me ? [email protected]
Sep 08, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 51MP392H Rear Projection Television Logo
60 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
