Question about Whirlpool Accubake RF362LXTT Electric Kitchen Range
My oven stays on even when it is in the off position
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that I wrote about why an electric oven will not shut off.
Electric Oven Problem Oven will not shut off
heatman101
Posted on Apr 05, 2011
2 Suggested Answers
SOURCE: Oven Stays On When knob is in off position
My electric oven stays on and gets hotter and hotter even when knob is in Off position.
Posted on Nov 11, 2009
Ge oven will not turn off after replacing element
If the element stays on even when the control is shut off it is most likely that the contacts are welded together in the control. This usually happens when the element blows out with a big bang. If this is the case the control will need replacing.
Feb 16, 2014 | Ovens
Bottom oven element stays hot will not cut off
In order for the element to stay on, the oven switch must be broken. No details are provided, but if your oven is like most, you have an Oven Selector knob for ~bake, broil, clean and another knob for Temperature selection.
Look at your Oven Selector knob closely to make sure it is not slipping on the shaft. It may be as simple as the knob being broken, and even though you are turning it to the Off position, the switch may still be on. If the knob is indeed turning the switch shaft, then it is most likely the switch stuck in the own position. Thanks for using FixYa.
Mar 03, 2011 | Ovens
Why does the light stay on even though the switch is in the off position on my cooker isolation box?
It sounds like the isolation switch is faulty, which can happen, or it it could be connected incorrectly.
I would advise having the switch checked.
Jan 31, 2010 | Zanussi ZBF360X Electric Single Oven
Ge tru temp range, oven will not shut off
You have a malfunctioning oven switch,get it replced or simply remove the fuse for your oven there maybe 2 fuses.
Jan 30, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
My oven stays on, only way to shut off it to shut breaker
Do you mean it continues to heat, or the indicator "says" it's on ? These wall ovens have notorious problems with the erc (clock/timer) could be a relay stuck in the closed position. trip the breaker, pull out the erc and visually inspect it, or if you're really inclined check to see if the relay "cycles" (clicking on & off/open & closed) through out operating.
Sep 26, 2009 | GE Profile JTP18 Electric Single Oven
The oven light stays on constantly, even when it's switched to the off position, when you turn the main power off it goes off, but back on when power switched back on.
It is most likely the switch will have to be replaced due to a short. Second possibility but more unlikely is a relay that is stuck open.
Jun 30, 2009 | Ovens
Electric Oven stays on when even though turned off! Oven is already warm in the morning even though the knob is in off position. Could it be the switch?
HI, this will require the skilled hands of a qualified GE tech. the damaged part here is the Magnetron assembly. this is a very sensitive part that creates radiation and the heating process as well. you will need to replace this device asap if possible.
Jun 11, 2009 | Jenn-Air JED8230 Electric Cooktop
Mar 28, 2009 | Kenmore Kitchen Ranges
Burner light stays on but burner does not work
Replace the burner switch, and you should be back in business. Hope this helps!
Feb 05, 2009 | GE JBP69 Electric Kitchen Range
How to find discontinued Dacor oven part?
Here's a link with a pdf file that lists your part #82810 for $202.31. http://ww1.dacorservice.com/PartsCatalog/docs/Links/2.pdf. The date on the pdf is 6/12/08. You can also locate a dealer or authorized service providor for Dacor applicances at: http://www.dacor.com/Customer-Care/Locate-A-Servicer.aspx. Good luck!
Jul 20, 2008 | Ovens
Whirlpool Accubake RF362LXTT Electric Kitchen Range Logo
280 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
