Question about SanDisk Sansa e260 MP3 Player
Downloading to player (please i need help)
My sansa won't download new music anymore. I plug it it and do everything like normal and it either sits there for a while saying writing or says it is already on the device when its not. then when i un plug is it says system restart, goes to the refreshing database screen then goes on working like normal but without the new songs. Please help!
  • jimmy8228 Aug 08, 2008
    Same problem. Tried MTP mode as well but indicates "new device". clicking on the popup closes it mometarily only to return the popup over and over. MSC mode also doesn't work and does what onlyjr88's does. Both Real one and musicmatch indicate music downloaded but in fact music is not downloaded.
I just posted the same problem and began pecking around for solution. Bear in mind, my knowledge of computer systems is weak. Now, one suggestion I found was (if using windows media player to load music to your player) revert back to version 10. I tried that but resulted in......"not supported by my system"..I guess windows XP?. HOWEVER I did notice a critical update to windows media player which I completed. Then, using version 11 in MTP mode, my son WAS able to put songs on his player. Could this be the holy grail? Worth a try anyway. Good luck!
Posted on Aug 08, 2008
Hi. I have a Samsung Sansa MP3 clip-on player. I listen to audio books all the time. I order an audio book online. It comes to me in either a regular CD or an MP3 version (however they manufacture it)....
Normally MP3 players can only play music/audio files in mp3 file format. You need to convert your CDs to mp3 music files onto yourcomputer or download them from the Internet and then copy them to your MP3player.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.
Click on this link for instruction on converting music files to mp3 file format:- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Apr 18, 2011 | Samsung Computers & Internet
Sansa rhapsody mp3 player
Your Windows Media Player may need to be updated and the player may need to be formatted. Please try these steps: 1) If you do not have it installed yet, please install the latest version of WMP10. 2) Download and install the quick fix from: http://download.microsoft.com/download/7/e/0/7e055e3f-6014-43bc-b6ff-6a90ced1d032/WindowsMedia10-KB902344-x86-INTL.exe 3) Format m250 device using the Sync mode in WMP. 4) To test, transfer songs to the player using the software for your subscription music service.
Aug 04, 2007 | SanDisk Sansa e250 MP3 Player
I do not have any software on my computer anymore for my sandisk mp3 player. how can i redownload the necessary program (s) to be able to remove and download music to my device?
You do not need software to use the Sansa e250. You can simply plug it into your computer, and use it as a portable drive. You can drag your music files directly onto the player from your computers file explorer.
Hope this helps!
Mar 18, 2011 | SanDisk Sansa e250 MP3 Player
Downloaded music and when i disconnect from computer it's not on the Sansa
you need to get the full-blown subscription to get those songs to play
Jul 31, 2008 | SanDisk Sansa Clip MP3 Player
Sansa e 260 will not work
Sounds like you need to reset your sansa, should be in the settings under factory reset, and/or format. THis will delete everything.
Mar 14, 2008 | SanDisk Sansa e250 MP3 Player
Music not showing up even when downloaded
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Dec 25, 2007 | SanDisk Sansa e260 MP3 Player
Sandisk sansa e260 reset?
Plug it into the usb port. The Sansa 260 will show up as the next drive letter. Using the right mouse button click on the drive latter and select format. This will will format your Sansa 260. The operating system files will still be there but all of your music, movies, voice recordings, etc... will be deleted.
Nov 11, 2007 | SanDisk Sansa e260 MP3 Player
"BAD TRACK"
You have a corrupt file - bad file...
Corrupt files for sansa -
Plug your player in, in MSC mode.
Right-click on it.
Click "properties"
Click "tools"
Click "Error Checking"
Check both the boxes on the error checking window that pops up, and click start.
After it finishes, check your player to make sure your player is normal.
If that don't work then format = http://www.sandisk.com/Retail/Default.as...
Sep 26, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
