Question about Air Tools & Compressors
I have replaced all of the components for my 2000 VW Beetle AC control system including the: compressor, the expansion valve, the fuses, and the control module; however, it still refuses to work the fan blows hot air and the compressor motor doesn't kick on what going on?
    Problem Solver:
  • 5 Answers
Is the cooling liquid inside the right one,with the correct pressure?
Posted on Apr 04, 2011
The AC in my 2003 VW Convertible is not chilling enough. What can I do about it?
Your system may just be low on freon. Most auto parts stores sell 134a freon for about $10 a can. If you visit an Autozone store the parts counter personnel might also show you how to add freon to the VW Beetle, it's not hard once you know where the correct port is located. You simply start your car, connect the freon dispensing hose to the AC port (there are two (2) ports, but the hose connection will only fit onto the smaller of the two (2) ports - the low pressure side). Allow the car to run while the can is discharged into the AC system, generally takes 10-15 minutes. Most dispeners have a freon pressure gauge on the hose portion that attaches to the can. Never disconnect a partially empty can unless there is a shutoff valve, and the valve is closed all the way. Better to add the entire can to the AC system.
If you have never added freon to your 2003 VW Beetle, that's the most likely problem. You could also have developed a slow leak in the compressor or AC lines, so I recommend adding freon WITH a sealant in the same can just in case.
The job would cost between $45 and $65 if you take it to a reputible mechanic to perform. That usually includes a full blown pressure test of the AC system. and a whole list of costly recommendations.
May 01, 2014 | 2003 Volkswagen New Beetle Convertible
Clogged AC for BMW 118i
You have to remember, your A/C system is a sealed system. If there are contaminates in the system, where did they come from? The only moving part is the Compressor. You might be able to get by for a little while with just changing the orifice tube, or expansion valve and recharging the system. But inevitably you will need to change the compressor. Anytime you install a new compressor you will need to change the orifice tube or expansion valve and the accumulator. Dryer. You will also need to have the evaporator core and condenser flushed out. While I have a system open I also change the o-rings at all fittings. This will ensure many years of trouble free operation.
Aug 16, 2017 | Cars & Trucks
2000 vw beetle a/c isnt cooling with compressor running
make sure low side pressure drops other wise the valves in the compressor are shot, meaning a new compressor is in your future.....
Mar 30, 2012 | 2000 Volkswagen Beetle
DO you know where the fuse that controls the a/c is located in a 2001 vw beetle 2.0 my a/c is blowing cold air and there is no voltage going to the compressor please help thank you :D
WELL AC COMPRESSOR HAS TO BE WORKING IF YOU GETTING COLD AIR.YOU HAVE FUSE/RELAY BOX AT THE LEFT END OF THE INSTRUMENT PANEL ALSO YOU HAVE FUSE PANEL UNDER HOOD IN ENGINE COMPARTMENT ON TOP OF BATTERY.CHECK THE 30 AMP FUSES ONE CONTROL THE COOLANT FAN CONTROL MODULE IN WHICH OPERATES THE AC COMPRESSOR CLUTCH CIRCUIT AND AC PRESSURE SWITCH.
Jul 11, 2010 | 2001 Volkswagen Beetle
2000 AC CIRCUIT FOR NEW VW BEETLE
Check fuse on top of battery.
Mar 27, 2010 | 2000 Volkswagen Beetle
1998 VW Beetle AC cycling on and off
**** in the venturi valve ,remove the ac interior unit and clean it all out ,broken bits of the old compressor blocking the restrictor (venturi )
Oct 23, 2009 | 1998 Volkswagen Beetle
Need fuse descriptions for the fuse box. some of the symbols on the card I do not understand.
Send me an email address and I will forward alond an image for the fuse block descriptions in a 1998 VW Beetle. Likely identical to the 2000 VW Beetle. Section 3.2 of your Owner's Manual also contains a pictoral representation of the fuse block, including descriptions for each fuse.
Jul 14, 2009 | 2000 Volkswagen Beetle
Please help me have AC
Just call me 925-459-0571
Jul 28, 2008 | 1996 Volkswagen Jetta
Electrical problems with trunk gas door and ac
the first problem with you fuel door is most likely the rear actuating motor or cable. remove the right rear trunk lining, and loosen the 2 silver phillips head screws, and remove the actuating motor. i would suggest replacing both the motor and the cable, as both of these parts have superceeded to a new improved part. the AC problem is caused by a faulty fan control unit. this part not only receives the switch signal and processes the information to control the compressor, but also controls the fans, their speed, the compressor,and the hi/lo pressure switch. both of these parts a a common problem for the beetle.
Jul 04, 2008 | 2000 Volkswagen Jetta TDI
Air Tools & Compressors Logo
170 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
