Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
The plastic piece or duct which is the size of sandwich of my Hoover SteamVac Spin Scrub F5914-900 is not getting seated properly how so much ever i try which thendoesnt allow the dirty water tank lid to close properly
reddevil6
  • 1673 Answers
SOURCE: Belt replacement Hoover carpet cleaner
Hoover steamvacs don't use belts. If the brushes are not turning, pull the brush block out, turn the machine on and see if the square hole where the brush block was, is turning. If not then the turbine is bad. Sometimes you can take the turbine apart and clean it out. most times I have found , replace it.
Posted on May 26, 2008
  • 107 Answers
SOURCE: NO DIRECTIONS FOR HOW TO ATTACH AND USE STAIR TOOL FOR MY HOOVER
Here is the link to Hoover's manuals. I could not locate a model F5900-900 But i believe it is F5914-900. Please verify before downloading manual by checking the serial number stick for a model. Its silver and should be on the back or bottom.
Posted on Dec 09, 2008
SOURCE: attach upholstery hose
Go to www.Hoover.com. Click on Carpet Cleaners. Click on Steam Vac All Terrain. Click on Learn more. Then click on Download the manual in pdf. The manual explains all.
Posted on Feb 07, 2009
SOURCE: recovery tank not working
recovery tank empty where do you look to see where the hair ball is so i can clean it
Posted on Apr 04, 2009
AV Nerd
  • 4 Answers
SOURCE: Hoover SteamVac Agility
Press the handle release kick-button with your foot, extend the handle all of the way back, and take a look at the gap between the base of the unit and the handle/reseviour assembly. You should see several black hoses attached to the base and running up into the handle assembly. One of them (the dirty water return hose) might be cracked. Turns out that might be a common problem with this model. We had the same problem.
Judging by the interference between the vacuum hose and the "dirty water return" hose, there is NO WAY those two hoses can exist together in that housing without causing the dirty water return hose can last for many full bends of the handle. We opted to not repair our unit, but you might be able to do it yourself for the cost of the part and several hours of your time. Otherwise, seek out your certified Hoover repair center for more info.
Posted on Jun 18, 2009
My Hoover steamvac is not sucking up water
The most common reason for lack of pick up on the F5800 or F5900 series is that the lid is not fully seated on the dirty water tank. Be sure to hook the two tabs on the front of the lid, and then snap the rear latch into place. Another reason is that the duct on the front of the dirty water tank is missing. The duct may have been removed to install the hose, and was not put back in place. It is a square plastic piece, about the size of a slice of sandwich bread, which slides into the front of the tank. A far less common reason for no pick-up is that the seal that the tank sits on has fallen off the motor cover suction tube. You will see a round tube on the bottom of the dirty water tank. This sits on top of a large rubber seal on the motor cover when the tank is in place. Be sure the seal has not fallen down into the hood.
Aug 09, 2011 | Hoover SteamVac Carpet/Upholstery Deep...
I have a hoover steam vac spin scrub that won't pick up the dirty water heeelllllllppppppppppppp please
The most common reason for lack of pick up is that the lid is not fully seated on the dirty water tank. Be sure to hook the two tabs on the front of the lid, and then snap the rear latch into place. Another reason is that the duct on the front of the dirty water tank is missing. The duct may have been removed to install the hose, and was not put back in place. It is a square plastic piece, about the size of a slice of sandwich bread, which slides into the front of the tank. A far less common reason for no pick-up is that the seal that the tank sits on has fallen off the motor cover suction tube. You will see a round tube on the bottom of the dirty water tank. This sits on top of a large rubber seal on the motor cover when the tank is in place. Be sure the seal has not fallen down into the hood.
Jun 15, 2011 | Hoover SteamVac F5914-900 SpinScrub...
I have a Hoover SteamVac Spin Scrub that won't pick up the water. Could you please give me some info on how I might fix it. Thanks!
I have a hoover stemvac that wont **** up any water/solution It has suction but it's not pulling up any liquid? Does anyone know how I can fix this?
The most common reason for this is that the lid is not fully seated on the dirty water tank. Be sure to hook the lid in front, and then snap it in place at the rear. Another problem could be that the duct is missing from the front of the tank. The duct is removed to install the hose assembly, and may not have been put back in place. It is a square plastic piece, about the size of a slice of sandwich bread, which slides into the front of the tank. A less common problem is that the round rubber seal that the tank sits on has fallen of the motor cover suction tube. Look beneath the tank for the missing seal.
Mar 31, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Steam vac doesn't **** water out of carpet
The most common reason for this is that the lid is not fully seated on the dirty water tank. Be sure to hook the lid in front, and then snap it in place at the rear. Another problem could be that the duct is missing from the front of the tank. The duct is removed to install the hose assembly, and may not have been put back in place. It is a square plastic piece, about the size of a slice of sandwich bread, which slides into the front of the tank. A far less common problem is that the round rubber seal that the tank sits on has fallen of the motor cover suction tube. Look beneath the tank for the missing seal.
Add a comment
Feb 22, 2011 | Hoover Steamvac F5860-900 Vacuum
IT WILL NOT PICK UP WATER
Add a comment
Feb 20, 2011 | Hoover SteamVac F5914-900 SpinScrub...
I have a hoover steam vac spin scrup with clearn surge that wont recover that water from the floor, everthing else seems to be working, we looked for a wet button but could not find one, any thoughts
Feb 19, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Changed hose on carpet cleaner and it wont pick up the water
If you are unable to pick up water from the carpet after using the hose attachment, is is usually due to one of two reasons.
1 - The duct on the front of the dirty water tank has not been put back in place after using the hose. It is a square plastic piece about the size of a slice of sandwich bread.
2 - The lid is not properly seated on the tank. Be sure to hook the two tabs on the front edge in place before hooking the latch at the rear. This also applies when using the hose.
Feb 19, 2011 | Hoover SteamVac Carpet/Upholstery Deep...
The solution is not vacumming up
Feb 14, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steamvac does not **** up the water
There are two common situations that can cause lack of pick-up. First is that the lid is not properly attached to the recovery tank. Make sure it is latched in back and snapped in place in front. The second common problem is that the duct on the front of the dirty water tank is missing. There is a plastic duct about the size of a slice of sandwich bread which slides into the front of the tank, and is removed when the hose is in use. A less common problem is that the large round rubber seal that the tank sits on has fallen off the suction tube on the motor cover.
Feb 04, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
67 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
