Question about Xerox DocuMate 152 Pass-Through Scanner
Xerox Documate 152
My scanner will no longer turn on..I turned it off and now it will not come back to life. Any thoughts?
    Scholar:
    New Friend:
  • 34 Answers
Hello.
I am a Support Engineer with Xerox Scanners.
I am sorry to hear that you are having trouble with your scanner. The problem is either the scanner, power supply, or outlet. I know that probably sounds exceedingly obvious, but I would recommend checking each individually.
If the power brick has been plugged in for a while, see if it is warm. If the brick is cold to the touch, it may not be functioning or the outlet it is connected to may be no good. Try turning the scanner on using the power outlet in another room (on an outlet that you know works).
If it still won't turn on, then you have eliminated the outlet from being the problem, and you can focus on the hardware. That leaves us with the scanner or the power supply. If the power brick was cold, and you know that both outlets work, I would recommend getting a replacement power supply. If it was warm, the scanner is more likely at fault and should be replaced.
In either of the last 2 situations, if the scanner is in warranty, you can call us for a warranty replacement (of which ever part needs replacing). Otherwise, you can call us to discuss your replacement options.
Replacement power supplies can be ordered online here.
If you continue to experience trouble, please feel free to contact us by calling 800-648-0410.
Regards,
Xerox Scanners Support
Posted on Sep 28, 2012
    New Friend:
    Problem Solver:
  • 7 Answers
Hmm, well no, just the basics of checking all the wiring. Hope it was within warranty.
Posted on Jan 10, 2010
SOURCE:
How do I replace the white strip inside the documate 152 scanner?
warning
don`t try to replace it. If it make a problem try to treat it in it`s place
Jun 23, 2014 | Xerox DocuMate 152 Pass-Through Scanner
Stuck at 80%
try the new version of driver
Jun 26, 2013 | Xerox DocuMate 152 Pass-Through Scanner
Xerox documate 152 scanner - won't scan
Hello.
If scanner is stopping @ 98% is normally due t oa communication problem. Make sure USB cable is conencted to rear of PC ,and cable is no longer than 6ft..
We also have an extensive support site and knowlegebase at http://www.xeroxscanners.com/en/en/support/
If you continue to experience trouble, please feel free to contact us by calling 800-648-0410bsat4ube4gblqiaaaaasuvork5cyii=.
Regards,
Oct 30, 2012 | Xerox DocuMate 152 Pass-Through Scanner
Scans two pages and stops midway through the next page. This just started happening. I scan in bulk, archiving payables. I've tried restarting both my computer and the documate and problem still continues....
I've seen this issue happen when the wrong driver was being used. When you install the documate, it installs 2 drivers. The WIA driver (windows acquisition driver) and the TWAIN driver. Make sure that you are using the TWAIN driver.
Mar 04, 2011 | Xerox DocuMate 152 Pass-Through Scanner
I have been using my Xerox 152 scanner for a year
Okay, I brought on my feminine side and read the manual. I cleaned the rollers etc and located the extra 'pad assembly ' that came with the scanner. So I hope I am all set for awhile.
Jan 10, 2010 | Xerox DocuMate 152 Pass-Through Scanner
Xerox ducuMate 152, password recently does not work
You could reset the device, that usually resets everything - the downfall is that you will have to re-configure everything.
  1. Right-click on the One Touch icon and choose Show Hardware from the pop-up menu.
  2. The Hardware Properties dialog box opens and shows information about your Xerox DocuMate 152 scanner.
  3. Click the Properties button.
  4. To return the scanner to its factory settings, click Reset Device.
  5. Click OK to save the changes and close the dialog box.
If this doesn't fix the problem please post a comment, I will do some more research into it.
Mar 20, 2009 | Xerox DocuMate 152 Pass-Through Scanner
Documate 510 Roller Pad Assembly
Hi, I don't know if it's permissible to advertise but we currently sell the assembly for the Xerox Documate scanners. As far as I know the scanner's discontinued, and the pads are getting pricey so consider how much longer you want to wait before replacing the scanner.
sales at sprucecomputer dot co dot uk if anyone is desperate
Sep 21, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Xerox DocuMate 152 Pass-Through Scanner Logo
240 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
