Question about Cell Phones
The phones are NOT charging correctly - they appear NOT to be holding the charge, Only a short time can be in use ????
  • pollyaub Apr 04, 2011
    Thank's for your help, you kinda confirmed, what I was already thinking !!!. Will get new batteries installed ASAP !!!!
    Thank's Again - Much Appreciated. Aub Shaw.
  • Cell Phones Master
  • 6,993 Answers
There are only two things that can cause this problem;
1. It's either the battery cell is weak such that is cannot hold charge anymore
or
2. The charge is defective is such a way that it is not giving the battery full charge.
How long have you been using this phone(s)?
From my own point of view, I think the battery is the cause of the problem. Once a battery cell is weak, no matter how long you charge it, the battery will drain in not distant time.
Replace the battery and hopefully, problem would be solved....
Good luck.
Posted on Apr 04, 2011
My old 611 dosent hold the battery charge for long even though I have put in a new battery
An in car charger will not charge as well as the mains, when charging for the first time you should use the mains, and charge for at least 8 hours. If it didn't charge correctly, it will be the same low charge all the time, as the battery has a memory that makes it charge the same each time. Try charging from the mains, you might be lucky.
May 22, 2012 | Cell Phones
My cell phone wont hold a charge
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 28, 2011 | Sprint LG Rumor Touch Phone cover by...
Battery lufe is rubbish
How old is the phone/battery?
Most cells use LiPo batteries, which can be very tempermental. If they are fully discharged (used until they will not power item any longer) more than a few times, they can lose the ability to hold a charge. Also, check the phone's users manual for correct battery charge times, as many Li/Po batteries will show a full charge before they are actually fully charged, particularly for the first few charges. If your battery isn't holding a charge, the easy fix is to replace it, but if the phone/battery is less than 6-12 months old, I'd ask my cell provider to replace it as defective.
Hope this helps,
r
Sep 12, 2011 | Cell Phones
Hand set wont hold charge,can only make a short phone call after being on charger all night. Hset 1 or 2 or time not showing on face
If you had your handset for a while, then try replacing the 'standard' AAA rechargeable Ni-Mh batteries (same or higher and better current 'mA' ratings) as they have a finite life span and will gradually loose the ability to retain charges over times (typical symptom is they appear full and after a few minutes use, they are completely depleted).
Hope it helps: let me know how you go.
Jan 08, 2010 | British Telecom BT Freestyle 7100 Cordless...
Both handsets of the new 2801 we bought will not maintain charge
This condition is usually caused by a battery that has been charged too much or incorrectly. It has developed a memory and now can only hold a very small charge. I believe it is time for new batteries!
Mar 04, 2009 | Xact Communication EXG2801 Cordless Phone
Battery holds a charge for a short time only
These phones are known for the contacts not transferring adequate voltage to fully charge the phone.
Oct 23, 2008 | GE 26928GE1 Cordless Phone
Rizr Z3 battery won't charge, no date and time, can't make a call
Terrie,
I am having the same problems and also bought my phone off ebay. Were you able to correct the problem? If so, please let me know. calspar@yahoo.com
Nov 01, 2007 | Nokia 1100
Correct procedure for charging battery
read da manual which cms wid da battery on hw lng 2 charge it wen newly purchased. charge wen battery is cmpltly drained.smtimz it may refuse 2 chrg so get a universal charger nd alwz use it 2 crg
Sep 06, 2007 | LG enV VX9900 Cellular Phone
Base phone handset #1 holding charge
The base unit should not need a charge. It should be powered by the plug in adapter. It may have a battery to keep operation for a short time in a power outage. The adapter may be loose, the adapter could be broken or the plug in the phone may be broken.
Jun 19, 2007 | Uniden TRU9480 Cordless Phone
Won't turn off completely, gets warm, won't charge correctly unless hooked to a computer.
Gerrypw - just get a new phon.
TIP DRILL - take the phone to a mobile service center and have them service or replace your charger port.
May 30, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
