Question about Kenmore Elite HE4 Electric Dryer
HE4 dryer vibrates violently while drying loads but feels like it turns smoothly when turned by hand
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Apr 05, 2011
I have a Kenmore 70 series large capacity front load dryer. It will heat but the drum just stopped turning. I do not believe it is the belt. You can turn the drum with your hand very easily and...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 20, 2011 | Kenmore Elite HE4 Electric Dryer
Getting hot but not drying. AF is the code that shows up
AF means air flow. Pull the mach. out to access the rear and disconnect the hose, turn it on to dry and feel at the outlet for air flow, if you have good flow check the hose out to the vent for blockage. If you do not have good air flow, the fan is ban.
Nov 11, 2010 | Kenmore Elite HE4 Electric Dryer
Dry take hours to dry
need to check hi limit thermostat on element make sure it is not cycling to soon
Apr 13, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 electric dryer locked on express dry only......
Shut the breaker off for several hours. Turned it back on.
Nov 30, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer - heat but not drying
you have thermistor failure/ located inside machine reason for premature heat
Oct 07, 2008 | Kenmore Elite HE4 Electric Dryer
Dyer has power but doesn't start
dryer inside is very hot, 6 years long time, i have the feeling that wire was damaged and connected to each other cause this kind problem.
Jul 06, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore HE4 Dryer
rmcfarland I am going to make an assumption. You are using the Automatic cycle. If so then this is wet load detection. Open the dryer door and at the bottom on the front you will see 2 metal bars. This is you moisture sensor. Clean that sensor with a mult purpose cleaner. If detergent and fabric softner sheets build up a coating on this sensor, the control will think you put in a dry load and shut down the dryer. Hope this helps.
Jan 25, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer won't start
Manual might be available on line type in your make and full model. Could well be the bulb that blew. Sounds like the door switch thou i see by other postings some times the filters can cause a similer problem
GUEST. 1. start switch is faulty...oops is it eletronic?it so disregard that. 2 drum is to tight 3 motor or switch on motor faulty
smitty123. Will drum turn by hand??? Can you hear the motor hum when you close the door???
Oct 27, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
74 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
