Question about Digital Lifestyle FA1B32Z 32 in. LCD Television
CHERYL42 inch digital lifestyles tv " FA2B-42570. THE TV WILL NOT TURN ON., what do i do?
    President:
  • Digital Life... Master
  • 775 Answers
If your FA2B-42570 does not power on that could be because of one out of two reasons: bad power board or bad main board.
Here is a link which will help you isolate the first case by basically telling you how to command the power board manually and checking if it produces what it needs to produce:
http://blog.coppelltvrepair.com/2012/10/testing-tom277cabb-for-digital.html
if it does, then the only other possibility left is the main board.
Also note that this TV is known to have inverters that fail over time, i.e. the TV actually works, but you can't see image on the screen because the light source behind the color filters that the LCD is made of is simply missing.
Posted on Oct 24, 2012
    Scholar:
  • 67 Answers
Is there a power light indicator button lit when you plug it in? If there is then you have standby voltage. The next thing to do is check the capacitors on the power suppl pcb to see if the are bulging at the top. To do this follow these steps:
1. Place the tv face down on a cushioned table large enough to support the entire tv. You don't want to damage the panel.
2. Remove the screws securing the back of the tv to the front.
3.Remove the back and set it aside
4. Visually look at the capacitors on the power supply pcb. This is the board where the power cord attaches. Capacitors are cylinder looking components on the board. They are usually located near the heatsinks of the board.
5. If the are bulging, remove the connectors and screws from the pcb.
6. Replace the defective capacitors with capacitors equal to or slightly higher values. The values are printed on the capacitors usually 1000mfd or 2200mfd. Make sure the voltage is the same or slightly higher. You will need a soldering iron and solder to replace them
7.Place the pcb back into the tv and reconnect the connectors and screws.
8. Plug ac cord into tv and turn on. If backlights come on hit the menu button and lift tv and see if there is an onscreen display. If there is the repair is complete.
If it still doesn't power up you probably need to replace the power supply pcb. Good luck and let me know how it goes
Posted on Apr 04, 2011
Digital Lifestyles FA2B-32072
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 16, 2014 | Digital Lifestyle s LT32323 LCD TV
Digital lifestyles model fa2b 32570 is the tv that i have and i have a universal remote RCA RCR4358R but i cannot seem to get my input button nor my menu button to work on the tv i do have the channel,...
All universal remote controls do not contain all possible codes. It is likely you will have to try a different universal remote control. Even at that, you may not be able to find one that handles all functions of your Digital Lifestyles TV.
Jan 03, 2018 | Televison & Video
42' fa2b-42406-mdlt42322, no sound or picture, tv is only 2 years old bought 3.2008 from HSC, paid 1,200.00
THIS IS NOT A BIG ISSUE. THE PROBLEM WITH THESE IS CHEAP CAPACITORS GOING BAD. THE ONLY PROBLEM IS THE POWER IS ONLY GETTING TO THE POWER SUPPLY AND NOT FURTHER DOWN TO YOUR MAIN BOARD TO START YOUR TV. YOU CAN EITHER REPLACE THE POWER SUPPLY OR THE DAMAGED CAPACITORS. IN SOME CASES THE CAPACITORS BURN MORE PARTS SO IT IS ALWAYS BETTER TO GET ANOTHER POWER SUPPLY. THE BEST PLACE TO GET ONE IS WWW.TVPARTSANDMANUALS.COM PARTS WITH INSTALLATION INSTRUCTIONS AND CAPACITORS HAVE A HIGHER VOLTAGE RESISTANCE.
Jan 12, 2011 | Digital Lifestyle FA1B32Z 32 in. LCD...
I have a Digital Lifstyles 42
If everything else works - there is sound and high voltage (static on the screen) - but there is no picture (including no on-screen menus), this limits the likely area of problems is the video output circuitry or CRT filament connections. Check to see if the CRT filaments are glowing. If they are not glowing, check for bad soldering on the CRT neck board and around the flyback transformer.
Where the picture is erratic - coming and going entirely or changing brightness suddenly, with power off, remove the picture tube socket (carefully!) and clean the pins with fine sandpaper and use contact cleaner on the socket. This source of bad connections can result in a variety of erratic symptoms. Check for bad solder connections on the CRT neck board.
GOOD LUCK....
May 21, 2010 | Digital Lifestyle FA1B32Z 32 in. LCD...
Digital Lifestyle FA2B42570, Remote MS119... where can I find a replacement remote? Mine was dropped and fell apart. No longer works.
Hello I have a Digital tv Lifestyles FA2B-42570 the section of the source(fountain) a few components were burned and there does not look the number of component or integrated circuit. If you can help your me or some person to look at this note covers very agradesido to saying the numbers to me on behalf of the integrated circuits. You agradesco in advance his(her,your) time and his(her,your) help with me.
The numbers in the board are: IC1, IC3, IC9, Q4 my email is gru.castro@gmail.com
Nov 28, 2009 | Digital Lifestyle FA1B32Z 32 in. LCD...
I need a main power supply PCB for my WT323 LCD TV.
There is no such manufacturer for that make. You must give all numbers off the board itself and hope its available. If not, it must be repaired to component level.
Nov 27, 2009 | Digital Lifestyle FA1B32Z 32 in. LCD...
PROGRAM COMCAST DVR REMOTE TO WORK WITH TV
Digital Lifestyles 42in 1080p FA2B-42570
For DISH Network users: I found that the Citizen brand remote code #523 worked for the sound, mute and power. This is for the remote that comes with the standard DVR, im not sure about any others.
** This was added to the 32in product page because there is no listing for the 42 inch yet.
Oct 09, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
Digital Lifestyle FA1B32Z 32 in. LCD Television Logo
427 people viewed this question
Top Digital Lifestyle Televison & Video Experts
CoppellTVRepair.com
paul
paul
Are you a Digital Lifestyle Televison and Video Expert? Answer questions, earn points and help others
