Question about Pit Cycling
Hi my pitbike isnt running right when i put full revs on it just splutter i think it may have something to do with the carb but dont want to touch it incase i break it even more
Try a new spark plug first.if no different look at your carb dependining on what model you have you will see on the side ethier 1 or 2 screws usualy 1 as a spring the othe doesnt hold you throtal full on in neutral after warming it and with a screw diver turn the screw whithout the spring qaurter turns but count as you know ware it was first you will here the difference in the engine
Posted on Apr 04, 2011
Liffan lf50qt-2a starts but only runs properly when it's just about to run dry on fuel as when it's full just splutters on and cuts out or will high rev but not turn the wheel soon as it's about to run out...
When motors are just about to run out of fuel they actually go better because they suck more air and run lean try adjusting the mixture screw on the carb i think anti clockwise in most cases to put more air in it and do this while its running if you can so you can hear it if it doesn't change turn it the other way as soon as it starts running smooth you know you got it hope that helps
Aug 06, 2014 | Motorcycles
GPX750 Carb Problems
check the carb (throttle) cable lengths.If they are different the mixture and idle settings will be meaningless.
Jun 19, 2013 | Motorcycles
I have a yz450f 06 and its not running right its spluttering and poping on take off and cruizing at low throttle.
clean plugs, is the smaller jet blocked. is vacuum pipe to tank leaking anywhere.
Mar 11, 2013 | Motorcycles
My 98 kdx 200 misses when getting into high revs, so it doesnt get to high revs at all, just misses and splutters, even when you in neutral and hold the throttle open just doesnt get to that constant revs,...
Please do not run this bike again... take it to a QUALIFIED PROFESSIONAL and have him clean and set the carburetor!!. Change the transmission oil also. Make sure the exhaust is clean and dry.. UNBURNT fuel in the exhaust is inviting a fire/explosion!!
Sep 29, 2017 | 1998 kawasaki KDX 200
I need help !!!!!!
IF YOU CAN GET THE BIKE TO IDLE AT ALL, SPRAY SOME CARB CLEANER AROUND THE INTAKE BOOT AND SEE IF THE ENGINE REVS AT ALL. IF IT DOES, ITS A LEAKING SEAL AT THE BOOT. IF NOT IT IS PROBABLY STILL SOMETHING IN THE CARB.
Oct 21, 2009 | 2005 Aprilia MX 125
I just got a 110 ssr pit bike. is the back brake
It should be below. Not to sound rude, but I think you could have figured this one out yourself. You sound like a smart guy.
Thanks for using FixYa.
Aug 12, 2009 | Pit SSR 110CC Pro Beginner Bike
My quad starts fine then cuts out on low revs, it runs perfect with open throttle and also splutters whilst going slow and ides? thanks
mate adjust the mixture screw on the carb to its correct setting in the manual and put the idle screw in a bit so the revs rise a tad good luck
Jul 07, 2009 | 1976 Honda CB 100
Hi i have a cr125 on a 96 it starts with a bump and when warm kicks up quite nice but now it wont start at all i have tried a new plug got a spark ,compression is fine, plenty of fuel ,drained the carb...
You may need a carb kit. Sputtering is usually one of two things. 1) bad seals in the carb, install a kit.
2) water in the fuel.
Clean the pitcock water trap, check the air cleaner, drain the carb
The generator stuff sounds pretty weird and off the wall.
Mar 14, 2009 | Honda CR 125 R Motorcycles
I have a pit bike and it splutters alot when i ride it
my pit bike will not keep it revs for a long time so can some one help me it is my first pit bike
Jan 09, 2009 | Pit SSR 110CC Pro Beginner Bike
Cycling Logo
114 people viewed this question
Top Pit Cycling Experts
john h
Mack Baxter
Are you a Pit Cycling Expert? Answer questions, earn points and help others
