Question about Mitsubishi WD-52531 Television
My WD-52531 is darker in vertical bands on each side of the screen. The image is darker in those areas regardless of what input is selected. It looks like burn in from watching 4:3 ratio television. The darker areas are in the same location as the vertical letterboxes when watching 4:3 images. How is this corrected?
    President:
  • 1,961 Answers
Try first cleaning all the lenses from inside the TV'S projector DLP projection TV's are very prone to dust accumulation because of spinning mechanical and lenses..To do the cleaning you need to open the back cover of your TV use a soft cloth to wipe all the dirt and dust from the lenses be carefull not to apply a force you might break the lenses.clean also the projection lamp.you can also replace the lamp if the lamp is not bright or nearly to be busted.....do first the cleaning and lets see if this resolve the problem....good luck and please post back if you need further assistance...
Posted on Apr 04, 2011
Samsung lcd tv with double image on screen
T'Con board should be suspected. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1300 posts to different brand TVs now. Pull up older posts there.
Nov 26, 2012 | Samsung LN46B610 46 HDTVReady LCD TV
Umax powerlook - Scanned Image Light Bands
The scan optics are dirty or elements in the scan sensor have gone bad.
Jul 21, 2017 | Umax PowerLook 3000 Pro Flatbed Scanner
Display Issue, Hisense 42" LCD
Hello
Do a factory default reset to this set. You can get details about how to do this, from its user manual. If it does not help you, the t'Con bard [Timing Control Board] may need replacement.
The board sill look like this.
http://www.dataentryjobs.us/67948.html2_15_2012_7_21_33_am.jpg
Feb 14, 2012 | Televison & Video
Light vertical band about 3.5" on left side of screen
The cost to repair this "convergence" issue is about the same as a new TV. Stay away from Toshiba TV's they have allot of problems. I have found for the cost that Vizio (sold at Wally Mart, Costco, Sam's club and others) has excellent prices and few problems.
Jan 19, 2012 | Toshiba REGZA Televison & Video
Hi, I was recently given a Samsung Syncmasster 2333sw flat screen monitor that I hooked up to my old Dell Dimension 8200 desktop.The monitor says the optimum resolution is 1920x1080 pixels. The maximum the...
hi bob you should be able to adjust the screen size via the menu on the monitor itself, (Available in Analog mode only) Note When TV signal is input in AV mode ,select “Screen Fit “to adjust vertical position in 0-6 levels. Image Size Note Supplied for the wide models only such as 16:9 or 16:10. You can change the size of the screen displayed on your monitor. PC signals • Auto - The screen is displayed in accordance with the screen aspect ratio of the input signals.• Wide - A full screen is displayed regardless of the screen aspect ratio of the input signals. Note • Signals not available in the standard mode table are not supported.• If the wide screen which is the optimal resolution for the monitor is set on your PC, this function is not performed. AV signals • 4 : 3 - Sets the picture to 4:3 normal mode. • 16 : 9- Sets the picture to 16:9 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • 4 : 3 - Sets the picture to 4:3 normal mode. • Wide-Sets the picture to 16:10 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note • It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • When the panel is of 16:10,the screen size options include “4:3”,”wide “,”Screen fit“.hope this helps
Jun 22, 2010 | Dell Dimension 8200 PC Desktop
Grey vertical line appears on screen
I had the same problem with my Lnt4071f. I called tech support and they said it was a faulty panel and the entire set had to be replaced. If you have your warrantly still use it, if not you may just be able to replace the panel, but its expensive.
Dec 27, 2007 | Disteck P4204TWHD Television
Big vertical tinted stripe on screen
Need more information:
Can you isolate which color is causing the banding?
Is there something ON the lense itself?
Is the projection mirror broken or bent?
S
Dec 12, 2007 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Mitsubishi WD-52531 Television Logo
144 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
