Question about Intel Computers & Internet
TRYED TO PUT IN NEW CASE BUT PUT BACK IN OLD ONE NOW IT WONT LOAD UP I JUST GET IT BLEEPING ALL THE TIME IT COMMING UP WITH NO SIGNAL ON THE SCREEN NOT SURE IF WIRING RIGHT ON USB HEADER CAN YOU TELL THE RIGHT ORDER THE WIRES GO ON THANKS
  • 1 more comment
  • Daniel Wakefield
    Daniel Wakefield Apr 04, 2011
    Wiring depends on the specific motherboard. There should be small white lettering on the motherboard which shows where the connections fit correctly. What kind ove motherboard is it? What types of cases are you using? Are you using different drives?
  • DAVID MOSS Apr 04, 2011
    MOTHER BOARD IS ASROCK P4VM800 IVE PUT IT BACK IN THE ORIGINAL CASE DO YOU KNOW WHAT THE BLEEPING MIGHT BE
  • DAVID MOSS Apr 05, 2011
    hi daniel i get 3 beeps pause then 3 beeps and so on mother board is a ASROCK P4VM800 all was fine until i tryed to put in a nother case still dont know if the wiring is right on the usb header;got 2 power 1-2 2d- 2d+ 2 grounds hope you can help i dont know much about computers thank for any help DAVE
    Scholar:
  • 142 Answers
It sounds like a possible memory error code. See my previous post about checking the memory. Remove all memory sticks turn on and see if it sounds the same. Make sure memory slots are clean by using a can of air. Put one stick in. If you still get error beeps, try a different slot. If you still get error beeps, Try another stick of memory.
Posted on Apr 05, 2011
  • Daniel Wakefield
    Daniel Wakefield Apr 05, 2011
    After seeing your last comment I would bet that the memory is bad. Very rarely do you get a motherboard with all the memory slots bad. Next step is to get new memory. Make sure if you do this yourself that you are touching the metal part of the case before you pick up the new memory. That way you do not shock the new memory and kill it.
  • Intel Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Apr 04, 2011
  • 2 more comments
  • Daniel Wakefield
    Also, the beeping is usually a code. (i.e. one beep, pause, one beep pause... or two beeps, pause, two beeps, pause... etc) The different codes mean different parts of the motherboard are either bad or not connected correctly. First remove the memory and put it back in one stick at a time, testing for power between each chip. Make sure the processor is connected correctly. Take out all extra cards. If you still get the beeping, disconnect the drives and try without the drives, then just the hard drive, etc.
    It is a process of elimination since I do not know what the actual beep code you are hearing.
    HI DANIEL RE BEEPING I GET 3 BEEP THEN PAUSE THEN 3 BEEPS AND SO ON IT WAS ALL FINE UNTIL I TRYED TO PUT IT IN ANOTHER CASE STILL NOT SURE IF IVE GOT THE WIRING RIGHT ON THE USB HEADER IVE GOT 2 POWER NUMBERED 1&2 2 GROUNDS 1&2 2D- 2D+ ALSO No 1&2 not sure which way they go on and in which order THANKS DANIEL ANY HELP WOULD BE VERY WELCOME AS I AM THICK WITH COMPTERS DAVE
    sorry daniel its me again tryed what you said still getting 3beeps pause then 3 beeps also tryed swopping ribbons to hard drives and dvd drive also floppy drive cant under stand it. it still comes up with no signel on the srceen wish i would have left it be now dave
  • Brian Sullivan
    Brian Sullivan Apr 05, 2011
    the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
    make sure that your RAM is securely seated
    test or replace all the leads that attach to your hard drive make sure the connections are secure including electrical extensions + IDE,SATA the ones that attach from your
    ((motherboard to hard drive))
    make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
    hope this helps
Less than a week old phone will not turn on.
have you bothered to recharge the battery as with a lot of use it will be flat within the week
Feb 09, 2016 | Microsoft Visual Stdio Fun Svr Sa Nl
Bush tdv6w
Mine was the same. Now the weather has warmed up not bleeping but now not getting hot, therefore not drying? Any ideas?
Nov 23, 2013 | Dryers
When i turn on my p.c my screen sais"no input signal"and my tower is making a bleeping noise please help
beeps and no signal are indicators of either a failed or unseated graphics card or memory you will need to remove case to check components fixtures.get rid of beeps and it should boot ok
Nov 13, 2009 | Computers & Internet
Vtech 8100 VOIP wont connect to DGL 4500 router
please call dlink tech support at 877-453-5465. just an advise on how to handle the call when you reach dlink tech support (agent); do not agree to call back after you troubleshoot with them (they'll be giving you a case id reference# and be advising you to check your pc or call "who" and call them back to continue the troubleshooting). insist to the agent that he need to resolve the problem asap (by the way, agents are not allowed to drop the call or they'll be dead-history!). and if the agent still insisted you to call back, ask for a "senior level technician" to finish the job (escalate the problem).
fyi: dlink tech support handling time to resolve a call is 15 to 18 minutes only. if you reach that 15-18 minutes (max) time the agent will think of a way for you to call back (advising you to check with your pc manufacturer, check with your ISP, call microsoft to update your software, etc... non-sense!) they need to do this in order to reach their handling time (agents need to reach 21 to 25 billable calls, and billable calls are "solution provided", "resolved", and "dropped call"). ---- believe me, i was one of them and repented.
Feb 17, 2009 | D-Link DGL-4500 Wireless Router
Turn signal on 1999 cherokee
The car needs a new TS flasher. About 6$ at the auto parts store. You find the old one by listening for where the click is comming from under the dash. These are typically very accessable.
good Lukas
Feb 07, 2009 | 1999 Jeep Cherokee
Samsung hlr4667 dlp \ no hdmi connectivity
No, when I bought my new plazma tv, and unhooked my old DVR box, I had to go to my cable provider and inform them. they sent a signal and WHAM I was back in Biz.
Nov 10, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Changing from old moniter to flat sceen. the new one will get to windows logo, load up, then says no signal. wats wrong please?
Your screen resolution might be the problem. Put the old monitor back on, change the resolution to 800x600 for example, and restart. Then plug in your new flat screen. You then should be able to increase the resolution via the Display control panel and see how far it will let you go.
Aug 05, 2008 | Computers & Internet
Ps3 wont start up
send it back under warranty,
The power supply may be faulty.
Feb 18, 2008 | Sony Playstation 3 (PS3) Console
How to remove and install CRT?
You got to remove the lower back panel and you'll find another 4 screws there and don't remove the front cabinet with the screen, remove the back one with the mirror. I sugest you to use the old deflection yoke, in case your new crt is comming with his yoke.
Dec 09, 2007 | Samsung HCM4215W 42" Rear Projection...
Computers & Internet Logo
167 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
