Question about Apple iPod touch Second Gen (8 GB, MB528LL/A) Digital Media Player
Ok i have a ipod touch 2nd generation i have replaced the digitizer, and the lcd screen, and i am trying to replace the wi-fi flex cable that was connected to the mainboard but i don't know how to attach it to the main board. I thaught it was supose to connect with some double sided conductive tape and so i tried that and i still can not get the touch screen to respond and last time it was working the first time i lifted up on the digitizer to take it off the touch screen worked for a little bit so i thaight it just wasn't connected properly and so i just need to know how to actach the cable correctly. i think ?
  • jasongero173 Apr 05, 2011
    sorry if that doesn't sound right but i did say i am trying to replace the wi-fi flex cable not the digitizer cable need help with that please.
  • 536 Answers
The digitizer is connected by carefully pressing the end of the ribbon down onto the main board. You will feel a slight click as the connector engages.
You have to be sure to line-up the two halves of the connector just right before gently pressing down.
Hopefully you haven't damaged the ribbon cable.
I've replaced the digitizer 3 times on my 2nd generation iPod Touch and it's VERY easy to rip that ribbon.
Also, be sure to remove the protective, clear membrane from the inside and outside of the digitizer or your have to live with a blurry display until you replace it again.
Posted on Apr 04, 2011
  • Jeffrey Groves
    Jeffrey Groves Apr 05, 2011
    Sorry about missing that point about the flex cable. I've not messed with that before. Have you checked the tutorials for this repair on ifixit.com?
How to Replace screen and digitizer for iPod touch 4th gen.
iPod Touch 4th Generation:
iPod Touch 4th Generation: Heat the surrounding edges of the iPod for 30 seconds
Begin at the bottom corner...used a straight blade to pry the glass up slowly; the LCD will come with it since they are fused together.
When you get closer to the top be very careful since the wifi cable is normally sticking to the glass. If it is use a small screw driver to detach it from the glass. The wifi cable is on the opposite side of the power button.
There is one flex cable (LCD) that can be removed; just a slight twist and it should pop off easily.
The other flex cable (Digitizer) is under the logic board and since you'd be replacing it you can cut this flex cable to work with more ease.
Remove the eight screws on the metal plate.
Remove the metal cover over the camera...screw driver on the very edge and pop up...do not use much force or dig at it since it would be very easy to destroy the camera.
To remove the metal plate that covers the batter: bottom left corner... dig your screw driver in (shallow) then push through horizontally until you reach the edge and lift the end of the screw driver upwards...using this method will allow the speaker to stay in place and the metal plate to separate.
Remove the top three screws
Put a screw driver between the logic board and the power flex cable as you gently lift the logic board up on that side...this method will ensure you don't rip the POWER flex cable
Do not lift aggressively...both cameras must be lifted gently, the adhesive is not that strong but there are some there.
The power and volume flex cable connection to the logic board is near the volume buttons, be extremely careful not to damage the connection when lifting the logic board.
Remove the copper tape surrounding the connection for the digitizer and install new digitizer.
Follow steps in reverse.
Good Luck
Sep 23, 2013 | Apple Touch Screen Digitizer For Ipod...
Tip
How do I connect my iPod to My Network
<p>The iPod Touch is the only device in Apple's line of portable music devices with embedded networking capabilities. When you enable WiFi on your iPod Touch, the device scans the area for available networks and displays a list of results. From there you can connect your home network or Wi-Fi and use the Internet to email, instant messaging, Web browsing and other applications. <br /> <p> <br /> <p>1. Touch the "Settings" icon on the home screen of the iPod Touch. <br /> <p><br /> <p>2. Select "Wi-Fi" menu item. <br /> <p><br /> <p>3. Move the slider at the top of the window of the "Off" to "On" position. The phone will scan for nearby Wi-Fi networks.<br /> <p> <br /> <p>4. Tap the name of the network you connect to your iPod Touch. <br /> <p><br /> <p>5. Enter the password for the Wi-Fi network you selected with the keyboard on the screen. <br /> <p><br /> <p>6. Tap "Done" to connect to Wi-Fi network using the password you entered. When the Wi-Fi icon appears on the top screen of the iPod Touch, you'll know the connection is successful. <br />
on Aug 09, 2011 | Apple iPod touch
Tip
How can I go on Wi-Fi on my iPod Touch without a computer?
<p>Apple iPod touch Wi-Fi reception without using a computer. The device has a built-in 802.11 Wi-Fi receiver, which means that access to the Internet via a WiFi router that is in range. When connected to a WiFi signal on your iPod touch, you may be prompted for a password if you must know the password or ask the Wi-Fi to the administrator. Unsecured Wi-Fi does not require a password. <br /> <p><br /> <p>1. Press the "Home" button of your iPod touch and move the cursor to the right on the device. Enter the unlock code if you have programmed. <br /> <p><br /> <p>2. Touch the "Settings" icon on the home screen of the iPod touch Settings menu. <br /> <p><br /> <p>3. Play the "Wi-Fi" Network access to the names of all upcoming Wi-Fi to see. <br /> <p><br /> <p>4. Tap the name of a Wi-Fi to connect. If the network requires a password, you will be prompted to enter the password. <br /> <p><br /> <p>5. Touch "Join" to complete the connection. Now you can use any Internet-related programs on your iPod touch. <br />
on Aug 05, 2011 | Apple iPod touch
Password for wifi 2wire17
The iPod changed the face of the music industry.
Through Apple's device, the use of MP3 music players became a widespread phenomenon, and remains the standard mode of mobile musical enjoyment today.
Its interface was easy to learn and use, and you could store several gigabytes' worth of songs into the device.
Eventually, as new iPod models came out, mobile movie and picture viewing became much more accessible.
With the release of the iPod Touch, another feature was introduced--the ability to connect to wireless Internet.
If you own a 3rd Generation iPod Touch, it's easy to get your Wi-Fi working.
Go to "Settings" and find the Wi-Fi selection. Turn Wi-Fi on.
Wait as the Wi-Fi will detect possible networks connections within range.
Look for the network you wish to connect to and press it.
If it's not on the list, go to "Wi-Fi," select "Other" and type the name of the network.
If a password is required, click on the "Security" option, select the type of security, enter the password and press "Join."
You may have to pay a fee before you can establish a connection to a secured network.
Press the arrow button beside the name of the network to adjust the settings.
The network may have other requirements such as entering a client ID or static IP address.
The network administrator should be approached for these details.
Monitor the Wi-Fi icon at the top of the screen.
The more bars that are highlighted, the stronger the signal.
Get closer for a stronger signal.
Jul 26, 2013 | Apple iPod touch 3rd Generation MC086LL/A...
How can i update my iPod model # MC086LL
The iPod touch is not only a music player, but also your gateway to the world via the Internet. In order to connect to the iTunes music store and use the email and web-browsing features of your iPod touch, you must first connect to a wireless network.
Touch the "Settings" icon on the home screen of the iPod touch. The iPod does not require you to press down very hard to select an icon. Using your finger, lightly tap the application you want to activate it. Choose the Wi-Fi setting and turn it on. You may need to wait a moment while the device locates available networks. Select the wireless network you want to connect to. You may have more than one option based on your location. If you are prompted for a password, enter it and touch "Join." Opt to have your iPod alert you when there is a new network you can join. This can be useful if you are no longer in range of a network you have previously used. To receive these messages, turn on the "Ask to Join Networks" feature. Tell the iPod touch to "forget" a wireless network that you no longer want to use, so it will not automatically try to connect you. Under the Wi-Fi settings, tap the ">" button next to the network you want to delete and then touch "Forget this network." Expect that some wireless networks detected by your iPod touch will ask you to sign up for a fee-based service. If this is acceptable to you, open up the Safari application from the home screen. You will be taken to a website that explains the terms of service and accepts credit card payments for wireless Internet access.
When the iPod touch was introduced in 2007, it quickly became one of the best-selling portable music players on the market. What separated the iPod touch from its competitors was its ability to access the Internet through Wi-Fi networks. If you're ready to surf the web and send e-mail with your new iPod touch, it's easy to get connected. Just a few taps, and you'll be on your way.
Tap the "Settings" icon on your iPod touch's home screen. Tap the arrow on the far right of the "Wi-Fi" bar on the "Settings" screen. Move the slider on the "Wi-Fi" bar to the "On" position. Move the slider on the "Ask to Join Networks" bar to the "On" position if you wish to be notified before your iPod touch connects to a new network. Moving the slider to the "Off" position means you must select a Wi-Fi network manually before your iPod touch will connect. Press the "Home" button to return to your iPod touch's home screen. You will see the Wi-Fi icon appear in the top left corner of your screen with up to four bars illuminated to indicate that Wi-Fi is available and to show its signal strength. iPod touch Support
http://www.apple.com/support/ipodtouch/ and ios support http://www.apple.com/support/ios/apps/
Apr 18, 2013 | Apple iPod touch 3rd Generation MC086LL/A...
Tip
How to install a Wi-Fi in iPod Touch
<p>The iPod Touch is a portable media player, game console and personal information manager developed by Apple. The first generation iPod Touch was released in 2007, the fourth current generation was launched in 2010 at the time of publication. Among other hardware features, the factory setting of the iPod touch already has a wireless adapter 802.11b/g/n standards for all. The operating system runs on the iPod touch is set at the factory to take full advantage of this hardware. You can sign up for free Wi-Fi with iPod touch. <br /> <p><br /> <p>1. Tap "Settings," then "Wi-Fi." Push the "Wi-Fi" control "ON". <br /> <p><br /> <p>2. Push the "Request for new connection" control "ON". <br /> <p><br /> <p>3. Enter the radio band - usually at least 100 meters - the Wi-Fi is connecting. IPod touch displays a message asking if your network that detects the radio signal to connect. Answer "Yes". After a few seconds, you will see the Wi-Fi icon in the status bar of the iPod touch; iPod touch will be ready for the wireless network connection. <br />
on Aug 05, 2011 | Computers & Internet
Tip
What iPod to buy on Black Friday 2009 ? Buy guiding
From: http://www.convert-video-dvd.com/news/buy-ipod-discounts-for-black-friday.html
After about fortnight, the thanksgiving will be coming, followed closed by it is black Friday which is generally recognized as the start of the Christmas shopping season. This is the day when stores lure their shoppers to come even during very early hours of the morning so they can grab their much-awaited gadgets ahead of everybody. Apple also will Drop MacBook, iPod, iPhone Prices for Black Friday. So, if you want to buy a new iPod for yourself, your wife or children, just prepare yourself for shooting the favorite one.
This article will help you determine the model iPod you have. Basically, before you buying a new iPod ensure your Mac or Windows OS is compatible. Next, I will show you Apple iPod’s icon, Model, Year-month introduced, Navigation control, capacity etc. at a round. Hope that you guys could own the best iPod by contrast.
Before we get to the funny stuff, I want to share an applied conversion tool for iPod users – Daniusoft DVD to iPod converter which I stumble across. I have my eyes on two of its features:
1. Convert / Copy any DVD movies(including commercial DVDs) to iPod with excellent quality;
2. Provides many editing functions such as video cropping, movie trimming, and video effect adjustment (including resolution, bit rate, frame rate, brightness, saturation, and sound channel, etc.)
Free Download Daniusoft DVD to iPod converter >>>
How to tell iPod’s hard drive size
To determine your iPod’s hard drive size:
* Select Main Menu > Settings > About (iPod touch tap Settings > General > About).
* On some models, the drive size is engraved on the metal case near the bottom.
ipod-touch-size.jpg?maxw=400
How to tell which model you have
Several external features can help you identify your iPod.
iPod shuffle (3rd generation)
iPod shuffle (3rd generation) includes a single 3-position switch that toggles between off, play in order, and shuffle similar to the original iPod shuffle. It also includes a headphone port that also is used to for connecting to a computer’s USB port as well as a clip similar to the iPod shuffle (2nd generation). iPod shuffle (3rd generation) is smaller that either of the previous two models and has one status light compared with two on previous generations of iPod shuffle.
shuffle3g2.jpg?maxw=400
iPod classic (120 GB)
The iPod classic (120 GB) is a hard drive-based iPod featuring a large, widescreen color display, a Click Wheel, and the capability of displaying photos and videos. Like other models, it uses USB for syncing. The iPod classic is available in silver and black, and has an anodized aluminum and polished stainless steel enclosure.
apple-ipod-classic-120gb.jpg?maxw=400
iPod touch (2nd generation)
iPod touch (2nd generation) features a 3.5-inch (diagonal) widescreen multi-touch display and 8 GB, 16 GB, or 32 GB flash drive. You can browse the web with Safari and watch YouTube videos with Wi-Fi. You can also search, preview, and buy songs from the iTunes Wi-Fi Music Store on iPod touch.
The iPod touch (2nd generation) can be distinguished from previous iPod touch models by its contoured design and oval shaped antennae cover in the back upper left corner.
ipod-touch-2.jpg?maxw=400
iPod touch
iPod touch features a 3.5-inch (diagonal) widescreen multi-touch display and 8 GB, 16 GB, or 32 GB flash drive. You can browse the web with Safari and watch YouTube videos on the first-ever Wi-Fi iPod. You can also search, preview, and buy songs from the iTunes Wi-Fi Music Store on iPod touch.
ipod-touch-3.jpg?maxw=400
iPod classic
The iPod classic is a hard drive-based iPod (80 GB or 160 GB) featuring a large, widescreen color display, a Click Wheel, and the capability of displaying photos and videos. Like other models, it uses USB for syncing. The iPod classic is available in silver and black, and has an anodized aluminum and polished stainless steel enclosure.
ipod-classic.jpg?maxw=400
You can distinguish the iPod classic from the iPod (5th generation) by the last three digits of the serial number. The iPod classic serial number’s last three digits will be one of the following: Y5N, YMU, YMV, and YMX.
iPod nano (5th generation)
The iPod nano (5th generation) brings video to your music with the new built-in video camera.
And for that extra kick: a larger screen and a polished aluminum finish in nine brilliant colors.
The iPod nano (5th generation) features:
* The iPod nano video camera help you Shoot high-quality video in portrait or landscape ;
* The iPod nano now has a polished anodized aluminum finish in nine electrifying colors. And a larger 2.2-inch color display for your viewing pleasure;
* Genius Makes music mixes has never been easier;
* FM radio + Live Pause. Return of the radio star;
* Pedometer and Nike + iPod ;
* Note to self:Voice Memos are here.
ipod-nano-5g-camera.jpg?maxw=400
Finally words, after reading this article , I’m sure you’ve already been familiar with Apple iPod. Next, please focus on Apple black Friday discount/deal for its iPod products. And hope you could find the low cost and high quality iPod for Xmas.
on Nov 18, 2009 | YouTube Videos
Cracked screen
2nd generation is here: http://www.ownta.com/original-ipod-touch-2-mp3-player-reparing-lcd-display-screen-replacement.html
3rd generation is here: http://www.ownta.com/original-ipod-touch-3-mp3-player-reparing-lcd-display-screen-replacement.html
Good Luck !
Feb 24, 2010 | Apple iPod touch
Replace ipod touch 2nd generation glass
Please check the links:
http://www.rapidrepair.com/guides/ipodtouch2g/ipodtouch2grepairguide.html
http://video.google.com/videosearch?hl=tl&q=How+to+replace+the+screen+of+iPod+2nd+gen&oq=&um=1&ie=UTF-8&ei=K7x1S4jJKsLX8Ab4mfzzCQ&sa=X&oi=video_result_group&ct=title&resnum=4&ved=0CCQQqwQwAw#
Good luck and have a great day!
Feb 12, 2010 | Apple iPod touch
I can connect to my NETGEAR router okay with my iPod touch 2nd generation, but whenever i try to connect to iTunes or the App store, it says invalid argument, how do i fix this
On your Touch go to Settings -> General -> Reset -> Reset Network Settings. When it starts again go to Settings -> About and check to see if your Wi-Fi Address has been Reset.
Dec 29, 2009 | Apple iPod touch
Apple iPod touch Second Gen (8 GB, MB528LL/A) Digital Media Player Logo
108 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
