Question about GE Refrigerators
Profile refrigerator PSC23MGPB. Thru the door water stopped working. Ice is OK.
  • 10 Answers
SOURCE: GE profile refrigerator model # TBX25PR
See if ice is jammed up in the tunnel the ice is pushed through.
Will the motor turn the auger with all the ice removed.
Posted on Jan 25, 2008
  • 4 Answers
SOURCE: Water leaking - GE Profile Refrigerator, Model: TPX21PRX
Check to see if the drain at the bottom of your freezer is plugged. When the refrigerator goes on defrost, the water has to go somewhere. Look below the coils in the freezer section and see if there is ice in the drain.
Posted on Jul 15, 2008
  • 74 Answers
SOURCE: GE Profile Refrigerator Ice/Water dispenser not working
Check the connector at the bottom of the freezer door first , you should also be able to hear the micro switch click when you press the paddle
Posted on Aug 28, 2008
  • 247 Answers
SOURCE: kenmore refrigerator ice/water in door not working
welcome-
what type of kenmore do you have (brand and model number)? this way it is easier to find infomation for you.
thanks and happy holidays
Tom
Posted on Dec 19, 2008
  • 1218 Answers
SOURCE: Ice maker stopped working
Good day,
A step by step procedure should resolve your problem. If the dispenser is working, you can skip that step.
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
Posted on May 25, 2010
Kkitchenaid side by side refrigerator. The ice maker stoped working, but the in door water despensor works perfectly
TRY PULLING OUT THE "ICE AUGER" AND RESETTING THE ICE MAKING UNIT ITSELF,MOTOR SHOULD RESTART AND FREEZE...UNLESS YOU RARELY USE IT,IN THAT CASE YOU MAY HAVE MOTOR ISSUE?? STAY IN TOUCH,LET ME KNOW
Jun 06, 2014 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE profile side by side refrigerator wont defrost
Inside the fridge behind bottom drawers there is a heat element that has stopped working.You will see it is covered with ice.you will need to replace it and totally defrost both and restart.
Oct 23, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Ge psc25pssc ss
Ice maker - don't work anymore. Ice cubes are small and wet. Water running down the sides of the freezer. Water in ice maker won't freeze.
Apr 20, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Water works but ice will not dispense
Check the top of the fridge. The hinge on the left where the door is there should be a wire harness on the top, but on this fridge it might be at the bottom. Inspect all the wires to see physical damage of sorts. Then if you can, tug on them while someone holds the dispenser. You might need a whole new door if it's not the Mainboard.
Mar 15, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE Artica no water, no ice, Checked water supply to solenoid OK
did u check water line after solenoids. could be a vaccum or u could have bad solenoids, not opening to allow water to go into box, try ok.
Feb 12, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
I have model #TFX25PRYAWW. Ice maker is not filling with water. Water still operates through door dispenser.
NUMBER 800 is your water valve. It has 2 solenoids. One for water and one for ice. I suspect your ice solenoid is on the blink. It could also be dripping slowly like a faucet and clogging like a stalagmite the ice maker fill nozzle. The only other thing in the ice box that controls that water valve is the ice maker itself. if the water valve is ok then the ice maker ain't getting the power to that water valve solenoid.
Dec 17, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Does not make or dispense any water or ice
Check the connector at the bottom of the freezer door for corrosion
Jul 11, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
152 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
