Question about Lands Phones
Using seimens hipath 3550 phone system voice mail light stays on after messages have been deleted
Dial #0
This resets all handset features!
Posted on Oct 29, 2008
SOURCE:
I forgot how to clear the stored voice mails
Les,
If you want to delete the actual voice mails, you have to go through your phone company (using their keypad commands) since voice mail is only accessible through your phone (but the voice mail messages are stored through your phone company provider).
Info from the Uniden DECT 6.0 6035 Manual:
Using the Voice Mail Service If you subscribe to a voice mail service, you can use your phone to access your voice mailbox. The new message LED on the handset ?ashes and VM appears in the handset display whenever you have messages waiting in yourvoice mailbox. When you subscribe to the service, your voice mail provider provides you with the access number and the required voice mail signaling tone. You can use your phonebook to store the access number.
Resetting the Voice Message Waiting Indicator
When you receive a new voice mail message, the new message LED on the top of the handset ?ashes and
appears in the handset display. In the event your message alert tone gets out of sync with your phone company's voice messaging system, you can reset back to its original "no messages waiting" state. To reset, press and hold [?nd hs] on the base for ?ve seconds. A beep sounds and the message alert tone is reset.
Here is the manual:
Uniden 6035 1 Owner Manual
Nov 01, 2015 | Uniden DECT 6.0 Cordless Telephone...
How do I set up voicemail? New phone, mailbox says it is full, how do I delete messages?
  • Access the main menu of your Samsung Go Phone. Hold the #1 key down until you are connected to the voice mail system. If for some reason pressing the #1 key doesn't connect you to voice mail then call customer service at 1-800-331-0500. You will be connected with an operator who can help you troubleshoot the voice mail problems on your Go Phone.
  • 2 Follow the voice prompts and select "Listen to Messages" from the list of options. Bear in mind that checking voice mail on a Samsung Go Phone will count against your prepaid minutes.
  • 3 Once you have finished you can select the "Delete Message" option from the voice prompt if you wish to clear your voice mail messages. If not, you can simply press "clear" or hang up the phone to leave the voice mail system.
  • Oct 04, 2010 | Samsung Hue (SCH-r500) Cellular Phone
    Voicemail light flashing but no message
    This can usually be fixed by calling the phone number that the voice mail indicator light is flashing on from a different phone number. Leave a voice mail message and then go into the voice mail and delete the message that you just left. The indicator light should then go out.
    Sep 14, 2010 | Mitel 5212 IP Phone
    My PBX hipath 3550 restarts about 10 times daily,what can i do?
    please check your PBX's exost is work proper or not.
    if not, please change the your PBX place and check must be cooling will there.
    Mar 28, 2010 | Siemens HiPath (L28155H5100A402) IP...
    Hipath 3550 CLI on ADSL Line
    Try #86 on each handset to enable CLI and *86 to suppress CLI.
    From V3 to V7 is big. Motherboard upgrade.
    Sep 07, 2009 | Siemens HiPath (L28155H5100A402) IP...
    New Message Light won't stop flashing
    Don't know about other models, but I just called RCA small business phone support (800-511-3180) to find out how to clear the message light indicator on my 25210 2-line cordless phone when it continues to blink but there is no message.
    All you have to do is hold down the delete button for a few seconds and it will clear. Hope this helps someone else from going batty!
    Jun 02, 2008 | RCA 25414RE3 Corded Phone
    Msg light
    I need more information. Your phone can be connected to one of many different Toshiba phone systems and you can also have different voice mail systems. I'm assuming you are talking about voice mail messages.
    Can you verify that this is happening only on your phone? If you swap phones with another station does the light start to work? It's rare, but the light itself may be the problem.
    Does this same thing happen to anyone else? Is the voice mail not turning on any message waiting lights? or is it working for others?
    Not knowing all the details, you could try emptying all messages including saved messages. Then try to leave yourself a test message.
    If you know how, you could have your mailbox deleted and re-created. This would need administrative rights to voice mail programming.
    Most voice mails have an option to activate the MSG light or not when a new message arrives. Your's could have been turned off by mistake or glitch.
    Nov 13, 2007 | Toshiba DKT-2020 Corded Phone
    "New Voice Mail" stuck on screen.
    Hi, I have the same problem. I called the service provider, they left a voice message, which I accessed later and deleted from my voicemail box. This took care of it and I dont have that message on the screen now. I think you can just leave yourself a voice message and access it later and delete it. That should resolve it.
    Nov 13, 2007 | Lands Phones
    "new voice mail" display
    call your phone service and have them disconnect the voice mail and if they cant just remove that have them set there rings at like 9 since most phones only have up to 5 rings for the machine to answer.you will have to use there voice mail service to hear your message and then delete it but should be good after that. i have comcast and they said it would take 3 days to deactivate voice mail but told me how to get there so i can get rid of that flashing light, hope this helps you
    Oct 28, 2007 | GE 25942GE2 Cordless Phone System
    New Voice Mail
    I have FiOs and used some of the info I gathered from this page to get my voice mail working now! To set up my voice mail I called my phone number (from the house phone), then pressed * when the automated system picked up...Your prompted to use a 4 digit pass code, which is the last 4 digits of your phone number (worked for me). From there I listened to the prompts and created a new "4 digit pw" as well as a "name password" by the end of the cycle. It then allowed me to listen to the messages on the phone and delete them! Phone finally says ready on it.
    Oct 07, 2007 | GE 25952 Cordless Phone
    Lands Phones Logo
    228 people viewed this question
    Top Lands Phones Experts
    Ekse
    Marvin
    Marvin
    Are you a Lands Phone Expert? Answer questions, earn points and help others
