Question about Samsung LN52A550 LCD TV
I have a Samsung LCD TV and it won't turn on - Samsung LN52A550 LCD TV
    Scholar:
  • 67 Answers
A common problem with samsung flat panel tv's is that the capacitors on the power supply fail.
You will need to remove the back and check the power supply pcb for puffed caps. To do this you will need to lay the tv face down on a cushioned surface and remove all the screws that secure the back of the tv. You will need a surface large enough to support the whole tv. This is to protect the panel. DO NOT place tv on surface where the front of the tv is not supported by the frame.
Remove the back of the tv and check for puffed caps on the power supply pcb. This is the board that the power cord is attached to.
If there are any puffed caps, you will need to replace them with equal or slightly higher valued caps.The value ratings are printed on the capacitors in mfd and voltage.
You will need a soldering iron to remove and replace them.
After reinstalling the power supply and before you put the back on, hook up a power cord to the tv and try turning it on. If you see a backlight come on, the tv is working. Try hitting the meny button and see if you have an on screen display. If you do put the back cover back on.
If tv doesn't power up, then the power supply pcb is probably bad. Try checking the voltage outputs from the connectors on the side of the pcb. Use a digital multimeter, connecting black lead to chassis ground and read lead to check voltage on the pins of the connectors. There should be voltage levels printed next to the connector on the pcb. Let me know if this helps you.
Posted on Apr 04, 2011
Samsung 13 tv can't get it to run what can I do?
As you and I don't know what the problem is, certain basics have to be first covered. Here is a link describing basics for any TV.
TV Power Light Comes On But No Picture Or Sound
As I don't know if you have an active led power light, here are a couple of videos:
EASY HOW TO FIX SAMSUNG TV NO POWER
Samsung TV Won Turn On How to Repair Bulging Capacitor for Clicking Noise
Samsung TV Won Turn On Has No Power No Standby Light Samsung LCD TV...
If the set is powered up, you can try resetting it to factory defaults. Yes, any of these suggestions may not work but one of them might fix your problem. You might try searching for tips by including the model number in the search. Bear in mind you are dealing with a high voltage device and your next repair may be at the hospital if you are not exceptionally careful.
Feb 28, 2018 | Samsung Televison & Video
I have Samsung UN55EH6050 TV with sound but no picture
check this out..
Samsung power defect causes some TVs to fail and class action suit follows
Watch this video.. ( I did mine - three times - before I bought a LG).. its not hard.. just a little time... the local TV repair shop can install these for you..
watch the + and - sides when installing..
Samsung LCD Plasma TV Capacitor Repair Kit Replacement Parts
Sep 08, 2017 | Samsung Televison & Video
I've replaced every board on the samsung plasma and still clicks
What do you mean by clicks? Plasma televisions are hot cathode ray, there is thermal expansion that takes place due to heat.
Nov 04, 2016 | Samsung Televison & Video
I got samsung tv ln32a330j1d it won"t turn on even
You have a bad power supply.
You can get get parts for this tv at www.interliquidparts.com
Aug 28, 2011 | Samsung LN32A330 32 in. LCD TV
Samsung no picture
There are several capacitors that are known, in Samsung TV's that go out.. ( I replaced mine until the board was burnt through.. bought a new board, they went out again.. BOUGHT A LG TV!!)
Samsung settlement warrants older TVs with faulty capacitors
replacing these is not hard at all.. if you can use a soldering iron, you can do it..it just takes time..
Repair Samsung LCD TV Relay Clicks Shuts Off Won Come On
WATCH THESE VIDEOS FIRST.
My Repair of 46 Samsung LCD TV with Bad Capacitors
Jul 18, 2017 | Samsung - Projection TV replacement lamp...
Samsung LN52A550 LCD TV Logo
206 people viewed this question
Jerry Greenberg
Jerry Greenberg
